Results 1 to 6 of 6
    Active Member Four Rings clochner's Avatar
    May 11 2010
    Chicago, IL
    Wheel Repair Kits?
    Unfortunately, I just nicked my left rear wheel on some raised pavement while entering a parking garage. It's driving me nuts. Here's what the damage looks like. Can anyone recommend any wheel repair kits (if there is such a thing)? Any other thoughts on repair would also be appreciated. Thnx.
    - Brandon
    B8 S4 - tuned.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Take it to a wheel repair shop or have a mobile wheel repair service come out and fix it. There should be plenty of both in Chicago. If you aren't sure who to use, ask a local wheel/tire shop or local forum who they recommend. It should run around $100 to $130. Most reputable places will do a good job and you won't even notice. It is not worth trying to do it yourself from my experience.
    I had some curb damage recently repaired on a set of Advan Racing wheels that had an anodized lip, and it turned out perfect. I was worried going in (the wheels cost $800+ each), but it turned out great. I actually sent mine to the repair shop through my local Discount Tire. They handled dismounting the tire, and sending it in. Most places can turn it around in a day or two, and the mobile services will usually do it on the spot.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Active Member Two Rings S4Android's Avatar
    Aug 14 2011
    Michigan
    This just happened to me actually too :( was going into a parking garage as well...
    2012 Ice Silver S4 Prestige | Sports Rear Differential | Silk Nappa Leather | Carbon Fiber Inlays | 19" Stock
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Easy to fix yourself if you have a minimal amount of paint and auto body skill. Did the repair on my 04 Avus wheels and turned out well. Check this out . Everything you need plus all instuctions of how to do it with pictures. http://www.autopia-carcare.com/realwhda.html. But in my experience, the Wurth paint did not match the Avus wheels very well. But Einszett Silber paint matched much better. Not sure how either will match the current Audi wheels
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    Do yourself a favor and hire a wheel repair shop or mobile outfit and save yourself a LOT of grief.Had worse damage on my 2 front rims with an 06 Lexus IS350 with 18s.For $200 they came to my home with a box truck,took off the 2 fronts,fixed them like new with no paint matching issues,put them back on my car and took off in less than an hour and a half.
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    May 11 2010
    Chicago, IL
    Thnx, guys. I like the idea of a DIY method, but ultimately I think it's probably best to just take it in to a wheel repair shop. I'd rather pay the $100 or so to make sure it's done right.
    B8 S4 - tuned.
