Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Senior Member Three Rings jibatnes's Avatar
    Jul 07 2011
    Norway
    S3 injectors VS RS4 injectors? And some pictures
    Hi.
    Im doing a Turbo upgrade on my car, and im wondering what injectors to choose?
    Its gonna be a K04 upgrade size probably, hoping to develop 320hp in the engine.
    Any ideas on this? What is the difference between the two?
    Have been trying to search the forum to find out but nothing precise to be found :)
    Here are some pictures of my car btw, still building alot on this :) Thread about car soon to be updatet :)
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    No idea but I your avant looks pretty damn sweet.
    Mike
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    The difference between the 2 are as follows
    S3
    The S3 flows more than stock and most importantly it uses the correct spray pattern so no black smoke and good for roughly 300whp
    RS4
    spray more than the S3's but do not have the correct spray pattern so you end up with a cloud of black smoke and soot on your bumper from going wide open throttle and is good for roughly 450whp
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Aug 09 2007
    Mount Airy, MD
    ultimately your injectors will be determined by whichever tune you go with.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Markham, ON
    viziers, i'm guessing the injector's spray pattern is "made to work" with the shape of the top of the piston correct. I don't recall seeing how the piston on the RS4 is shaped but have read that the shape of the piston in the 2.0T is designed in such a way to help mix the atomized fuel from the injector properly to get a good burn.
    Mike
    Jan 27 2007
    NC
    Quote Originally Posted by Tanner View Post
    I belive so as far as the piston shape goes and mixing with the fuel, but the patterns are both pretty different.. The made to work part is true as far as the tuning goes it can be minimized at the hands of a good tuner....
    Take into consideration these were not run at full Psi but the same end result would be the same...
    vizi
    Active Member Two Rings Loud_Greg's Avatar
    Mar 10 2010
    Oregon
    If it's a K04 setup, go with S3 injectors. You'll have multiple options for a stock tune. If you're getting a stand-alone tune anyway, then I guess go for whatever you can find that the tuner can work with.
    Oct 14 2009
    Okinawa Japan
    Just keep in mind no one knows the flow rate of either injector, but no one has really been able to make the power with the s3 that has been made with the rs4... ultimately I would focus on getting the stg2 hpfpupgrade, rail check valve and in tank pump. Those right there and 350whp should have any fueling issues
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    Go s3 injectors, either one will flow plenty for a k04. The problem with not flowing enough happens up in the gt30 range, much much bigger than the k04. I believe the s3 injectors are cheaper as well. But you will be ok with either set of injectors.
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Oct 14 2009
    Okinawa Japan
    S3 are quite a bit more $$$ :-/
    -Shane Drake-
    >DRAKLOREs Build<
    Mar 10 2010
    Oregon
    Yeah, S3 are actually significantly more expensive, strangely enough. Most likely because they weren't a US part until the TT-S, and RS4's come in set of 8, so there's more supply.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by Loud_Greg View Post
    Truth spoken! S3's seem to be at least $100 more.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    May 06 2010
    Ellsworth AFB, SD
    then go with rs4, either way you will be completely fine with a k04. Its a little more tricky when you get higher in turbos.
    Jul 07 2011
    Norway
    Hmm ok :) thanx for all the input. Maybe i will hust phurchase APR`s complete K04 kit.. That includes S3 injectors.. I just know that after 4-5-6 months maybe. I want
    more. Maybe its better to leave those out and buy the RS4 instead due to future builds as long as they both work fine with the K04 :)
    Aug 23 2009
    Quebec City
    Quote Originally Posted by viziers View Post
    S3
    RS4
    vizi
    they are rated 600whp the RS4 fsi injector
    Markham, ON
    Thought - if you use the rs4 injectors on the 2.0T, would you expect to see buildup on the intake valves much sooner?
    Mike
    Jul 19 2011
    Northern Minneapolis, MN
    there is a thread around here somewhere where Vizi got that pic from and there was one hell of a debate about if he was using the correct pressure when doing his samples. That being said and from reading it, I got the same out of that thread as vizi did. S3 = cleaner but less flow than RS4's.
    Also, I have to add that I have no hands on experience with either :-)
    And on the note of fsi having a 'special piston'. All modern direct injection engines (gas and diesel) use a 'bowl' design on the top that splits the spray to atomize the fuel better. This bowl shape along with high pressure, spray angle, and number of holes/size seems to be a HUGE part of development for creating HP and better mileage.
    ^^Just some fun facts
    Jan 27 2007
    NC
    Quote Originally Posted by OOOOS4 View Post
    Lmao thats funny!!! Nice one!
    vizi
    Feb 06 2009
    328d, Tacoma
    If you plan to go no further than a K04, then stick with the S3.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Oct 14 2009
    Okinawa Japan
    Good question- no, because the fsi is a direct injection motor. The injectors sit inside the head, and spray directly into the combustion chamber. Most conventional motors spray pre intake valves and the fuel gets atomized before entering the chamber, the fuel can (depending on additives and conditions) actually prevent carbon buildup. Because the fsi is post intake valve (direct injection) there is no fuel to "wash" over the valves and thus any oil introduced by the PVC system or turbo seals, gets burned onto the valves...
    -Shane Drake-
    >DRAKLOREs Build<
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    Quote Originally Posted by DRAKLORE View Post
    Do you have links to the rail check valve and an upgraded in-tank pump?
    I'm going to save up for RAI's EFR turbo setup and it seems like I'll have to go with the RS4 injectors based on their recommendation.
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Veteran Member Three Rings Satummoo's Avatar
    May 04 2009
    Boulder, CO
    ebay.uk used to have (may still have) S3 injectors for 250$ shipped. It took 2 months to get, but sure beats paying over 600$.
    There was a thread on here or mkvforums.com that concluded (bench test) that the rs4 injectors were tested and didn't flow more than stock injectors and that s3 were the best
    2014 Jetta 1.8t 5spd
    Just OEM+
    Oct 14 2009
    Okinawa Japan
    Quote Originally Posted by jerseybrian View Post
    Hpfpupgrade.com seek out John
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Quote Originally Posted by Satummoo View Post
    OMFG STFU everyone talking bout that effing bench test, im sorry that was ever attempted because it's just poisoned the water with miss information. If you don't know.... Please please ppl stop posting misleading comments that will have new and old memers alike thinking things that simply are unproven/untrue... [/ENDRANT]
    And jerseybrian pm [email protected] and I'm sure he can hook you up with a drop in dw-300 for a really good price. I think D1 just did a review on the deutsch werks pumps and found them to flow better and out perform some of the higher priced pumps and be quite a bit smaller :-)
    -Shane Drake-
    >DRAKLOREs Build<
    Aug 23 2009
    Quebec City
    vizi
    LMFAO THAT'S FUNNIER!!! Then if you are still not really sure about that. juste give a call to Unitronic ;)
    2.0T FSI Big Turbo Injector Set, OEM RS4 FSI $625.00
    These OEM RS4 FSI injectors are perfect for 2.0T FSI big turbo applications. Tested to over 600 WHP.
    http://www.034motorsport.com/fuel-in...i-p-18722.html
    Jan 27 2007
    NC
    I'm almost possitive that is nothing more than an advertisement ploy! As if you look at any BT build here no one is making close to that on pump.
    And if 034 says thjey are doing it then id like to see data proof posted here to show that it is possible and i'm pretty sure they can't. IMO!
    vizi
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Best place to buy s3 injectors? and by best I mean cheapest
    Dec 23 2011
    CTSTurbo has them on sale for $469.99 instead of $549.99.
    S3 Injectors x 4
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    S3
    RS4
    vizi
    wrong, RS4 injectors only flow 4% more than S3 injectors. So how would you get 1.04 x 300 = 450 ????? Talk about bad math.
    epy
    Epy
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Just keep in mind no one knows the flow rate of either injector...
    hehe, except those of us that sent them in to be flow tested.
    Epy
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by ericpaulyoung View Post
    epy
    proof?
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    proof?
    I am over in the mountains at a cabin right now, but you can do it pretty easily by comparing the injector constants. Divide the RS4 constant and S3 constant and you will have your answer to the difference in flow rates :)
    epy
    Epy
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    epy
    Right, but I mean if you supposedly had these flow tested surely you have some sheets to show us the flow rates
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    I posted the S3 flow sheets before, so to get the RS4 flow you just multiply the ratio of the injector constants times those numbers. Very simple math :) I will go look for the flow sheets when I have time and re post them here. A set of RS4 injectors was also sent to the same tester but by a different guy. So I will need to go look for that sheet to prove the injector constants are correct. I think I saved a copy of it, but if not I can send an RS4 injector in for testing (I have a set sitting in the shop collecting dust).
    EPY
    Epy
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    EPY
    Please and thank you!
    Jan 27 2007
    NC
    Ummm, thats what I was quoted back in the beginning of 2011 by APR.
    vizi
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    vizi
    That doesn't make sense, did you mean to quote Eric?
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    That is what CTS quoted me back in the beginning of 2013!
    epy
    Epy
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    epy
    If I lived closer I would go remove your fuel pump fuse so you're car wouldn't start and you wouldn't know why
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    hehe
    epy
    Epy
