Results 1 to 40 of 48
    Sep 11 2011
    norway
    Increase ground clearance on a4?
    my 2009 a4 with standard suspension is a bit too low for my taste. Is there any way to increase the ground clerance, like an audi allroad? Suspension springs etc?...
    Veteran Member Four Rings A3 Guy's Avatar
    Apr 01 2011
    Charleston SC
    I have never seen anyone ask this but Id image you can stitch your springs or something, I have no clue if that would work.....
    ~Brennan
    2014 allroad Premium Plus
    Flickr
    Veteran Member Four Rings Bsix3.0's Avatar
    Feb 08 2009
    lots of bicycles..
    Aurora, Colo
    sell it and go buy a truck!
    audis aren't meant to be lifted
    -Lee
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Seriously confused, most here find OEM suspension too high.
    Thinking if you need higher clearance, you need an allroad.
    Cheers
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    blake will not be pleased.
    Senior Member Two Rings TJN0923's Avatar
    Aug 21 2010
    1994 jeep wrangler
    Shippensburg, PA
    does not compute.
    Veteran Member Four Rings TofuShop's Avatar
    Aug 24 2010
    swap springs with someone who has oem-nonsport. unless you already have that.
    Apr 07 2007
    Mountain View, CA
    Quote Originally Posted by mmaroney View Post
    Moved to A4 truck thread - oops, Audi doesn't make a truck
    OP check GMC forums
    Feb 08 2009
    lots of bicycles..
    Aurora, Colo
    Quote Originally Posted by Greg Nelson View Post
    OP check GMC forums
    haha that made me lawl
    -Lee
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    the only reason he hasn't replied yet is because he had a brain aneurism after seeing it, someone head to his place and get help!!!!
    Signar, no offence, but are you 500lbs or do you like hopping curbs?! lol
    you can buy rubber spring-raisers, they just wedge inbetween your springs to lift 'em up. but the ride comfort goes to absolute garbage, and i couldn't imagine it'd be great for your suspension.
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    you could just get a higher profile tire?
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
    Apr 05 2011
    Pacific Northwest
    That Allroad actually looks pretty cool...but of course it is not the right face for the pending model year.
    Highlander's Build Thread
    Sep 11 2011
    norway
    The a4 allroad is way too expensive, thats it. Any HELPFUL tips would be great, and not the rubbish about gmc trucks...
    Senior Member Three Rings EuroEclipse's Avatar
    Dec 30 2009
    2012 Evolution X GSR / 2012 Volkswagen GTI
    Germany/Colorado Currently
    Anybody know if there is a difference between the ROW standard springs and the NA standard springs? Kind of like the sport and s-line spring difference with the ROW and the NA cars.
    That could be a partial solution to his issue if there is a difference between the 2.
    2012 Evolution X GSR - Loud Noises!
    Sep 11 2011
    norway
    what about audi a4 allroad springs? if they fit the car will be raised 37 mm whwich would be perfect
    Senior Member Three Rings Nison_Li's Avatar
    Mar 05 2011
    '15 Q5 3.0T S-Line
    Baltimore, MD, USA
    how about the Q5 suspensions?
    2015 Q5 3.0T S-line Premium Plus
    Done: LED interior bulbs, S7 Steering wheel, RS5 Pedals, warning tri angle, VCDS mods.
    Planned: Tune, Alu Kreuz, Sway bars, under seat drawers
    Sep 11 2011
    norway
    totally different model, with air suspension...
    Mar 05 2011
    '15 Q5 3.0T S-Line
    Baltimore, MD, USA
    Q5 doesnt have air suspensions
    and they are based on the same plateform
    Jul 07 2009
    Lebanon
    Quote Originally Posted by dracolnyte View Post
    +1
    SOLD: 2010 A5
    Senior Member Two Rings rebelbowtie's Avatar
    Aug 20 2011
    2008 Audi A4 2.0T
    Mobile, AL
    Quote Originally Posted by Signar View Post
    Watch your mouth about GM trucks!!!!
    Other than larger profile tires this seems to be a logical solution. I know imprezza guys swap forester suspension onto their cars and mount truck tires on them.
    Something similar could be done to your Audi?
    Mar 04 2010
    Vancouver
    not sure if serious... as if audi stock suspension isnt ridiculously high already lol
    Veteran Member Three Rings allroadstomtl's Avatar
    May 25 2009
    '12 Avant P+, '16 GSW
    Montreal
    will the grille of A4 Allroad fit the the new B8 hood?
    '12 A4 Avant P+, S-Line 3 Spoke, S-Line Stone Guards,
    Veteran Member Three Rings MYFASTA4's Avatar
    Sep 03 2009
    C7 A6, A4 B7 AVANT, B8 ALLROAD & BOX-SPYDER
    Florida
    Quote Originally Posted by EuroEclipse View Post
    i think its 10mm
    2014 S4 6MT, B&T, sport dif., MMI+
    2015 A3 8V
    2001 TT MK1-225
    Sep 03 2009
    Florida
    Quote Originally Posted by allroadstomtl View Post
    if you have sport sus i'll sell you my stock springs, thats about 10mm higher, if your on stock and need to be higher you might want to just trade your car ;-)
    2015 A3 8V
    2001 TT MK1-225
    Feb 13 2004
    Silicon Valley, CA
    I think this is a first on Audizine, but a valid question.
    Three serious options here
    go to coil overs and set them high, I think these can go about 1.5 inches higher.
    go to airbags so you can adjust the height (not sure how much heigher these can go)
    trade in for a Q3 or Q5. The Q5 uses the same chasis and most the same interior as the A4.
    Kevin - Moderator, Audizine
    Established Member Two Rings musky hunter's Avatar
    May 13 2009
    time to get a Q5 or Q7!
    Mar 02 2007
    Fresno, CA
    It's coming...
    Sep 09 2009
    09 RDX
    Rhode Island
    Really is that what it is going to look like? or is that a custom made model (thats what it looks like)
    AEM Boost Gauge * Eurocode FMIC * JHM Shiftier * AMR Tune
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    It's coming...
    Wow, I thought I seen it all. Wow
    Sep 13 2009
    2010 A4 2.0T
    Quote Originally Posted by linet90 View Post
    no, you won't see that on their lineup...lol.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by hender View Post
    Keep hope alive! We could use a fleet of those bad boys out here "on the farm".
    Feb 13 2004
    Silicon Valley, CA
    To be honest, I could almost see Audi doing a smaller version of a Chevy Avalanch/Cadilac what ever type thing on the Q7 platform. Four doors (back suicide style) open truck bed back.
    I hope they don't, but I won't be surprised.
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by Stubek View Post
    I swear to God, if AoA quits bringing avants and starts bringing pickup trucks to the US, I'll never buy another Audi as long as I live.
    Feb 13 2004
    Silicon Valley, CA
    At that point I would probably open a business restoring various Avants and reselling them. Take an order from you for a B5 Avant, put in a new motor and trans, suspension update, clean the chasis if needed and sell it. Could be a good business.
    Mar 02 2007
    Fresno, CA
    I'm sure that would pull at the heart strings of hard core Audi fans, but I like new tech too much...
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    I don't think CO's go much higher than stock if at all. Best bet is probably an air set up. Maybe get in touch with the suppliers?
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Every coilover kit I am aware of drops a minimum of .75" from stock
    Mar 02 2007
    Fresno, CA
    Hydraulics are what you're looking for. Not only can you raise and lower the car with the flip of a switch, you can also pull a cool 3 wheel motion to impress the ladies in your hood...
    [/thread]
    Veteran Member Three Rings vtheman's Avatar
    Jul 09 2011
    Crown Vic Interceptor
    California
    Since you're near Europe you should be able to put your hands on some A4 allroad springs. I pretty sure they should fit just fine.
