Problems I ran into
Turbo bracket bolt(stripped)
Fan clutch pulley(stripped)
Fan clutch sawzalled off, bolt drilled out
Found my pcv breather hose was damaged
Installed
EFK
Fan Controller
High flow manifold
Franken turbo
Shorter belt and clearance
mocal thermo
Oil cooler
034 Breather block
Catch can
If you are installing a oil cooler the part number for the shorter fitting is 059115721
Video of test drive. recorded with go pro hero, 720p, crappy sorry
Mods are stock aeb, franken turbo, forge 007, porsche bbk, 300mm rear s4, ebay intercooler, atp 3 inch tp. labree downpipe, vibrant 1762 resonator, magnaflow 14815 2.5" fronm tp back.
