Results 1 to 15 of 15
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Fog Machine to find boost leak?
    Hey guys,
    I have a question for ya...
    Does anyone know if it would be safe to use a fog machine to check for vacuum/boost leaks? I know the pressure would have to be monitored, but my main concern is the fog itself. Would it cause any issues if I'm using a water based fog machine? I would rather do the test myself (and can't afford a professional kit) because the last time I had it done at a shop, they couldn't find any leaks (which I found myself the next day using just compressed air). I'm not loosing any vacuum (22-23 inHg at idle) but I'm loosing 8psi of boost.
    lmk what you guys think...
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Mar 17 2008
    Just build your own boost leak tester from home depot.
    It costed me ~10$ and i found all my boost leaks.
    http://www.a4mods.com/index.php?page...tml&category=5
    Jan 24 2008
    Pennsylvania
    as antekaudi said, just use air, it works really well.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Oct 03 2012
    CA,US
    Fogg machine are not enough Liquid used that count
    Fogg machines are not enough for using purpose .Its liquid that makes it count.Now a days small fogg machine are in market
    Oct 03 2012
    CA,US
    Fogg machines are not enough for using purpose .Its liquid that makes it count.Now a days small fogg machine are in market.
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Quote Originally Posted by mcasey View Post
    and btw...wtf does that even mean?
    02 A4 Quattro 1.8T
    Veteran Member Four Rings daihashi's Avatar
    Apr 03 2010
    houston, tx
    Re: Fog Machine to find boost leak?
    You can make your own smoke tester with a quart paint can, a rag, mineral oil, lighter, air fittings, and an air compressor or bicycle pump.
    I'll look for a DIY already written somewhere and post the link.
    Sent while taking an "on the clock dump" using Tapatalk 2.
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Quote Originally Posted by daihashi View Post
    I'd be interested in this Rich... have recently run into two separate instances when a boost leak test yielded nada but a smoke test did.
    Apr 03 2010
    houston, tx
    couldn't find the method I use, but this one works too and is probably a better setup than mine. The only difference between mine and this link is that 1. I use a quart paint can that you can buy at lowes/home depot; 2. I just kind of soak a rag with baby oil, let it burn for about 30 seconds and then and then drop it in the can while it's kind of "ember'ing". Set my regulator to a super low psi and let it saturate the intake tract. Also included a video I found on youtube of basically the same general idea as the DIY link and my method.
    Personally I like my method.. it's super simple and smokes forever and I don't need all that extra clutter laying around. Super portable. I prefer the KISS method... but I've done the glow plug thing and it definitely works well also.
    http://www.theturboforums.com/smf/di...chine-tester!/
    http://www.youtube.com/watch?v=RhLDR5x-89I
    note: You want the bare minimum amount of air pressure to push the oil smoke through the system. You get a denser smoke this way.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    those are some great links right there! thx for sharing.
    Oct 03 2012
    CA,US
    I don't think that it would be safe. I guess you can use haze machines instead of fog machines.Though, it will be a bit costly but it will fill in appropriately for fog machine.
    fog machines
    Sep 10 2011
    None
    I made my own leak tester for use with my air compressor. Used a fog machine with good results. Just put the fog machine up to the TIP for a minute then capped it with the leak tester. Voila, smoke test.
    Sent from the Wretched Hive of Scum and Villainy using tapatalk 2
    Apr 03 2010
    houston, tx
    It's entirely safe, people have been doing this since before you or I were born.
    Jul 30 2012
    Nashville, TN
    Sorry to resurrect, thinking of using a fog machine to the intake of my air compressor to check for boost leak. Anyone tried? Will be trying later. It won't be touching the MAF so I think it should be reasonably safe.
    Veteran Member Four Rings freeloader700's Avatar
    Mar 23 2012
    '03 A4 1.8TQM
    The Hills, OR
    You can make your own tester less than $5. Male compressor fitting and 2" PVC cap. I just made mine and going to find a leak I have tonight
    I like the idea of the smoke test
    2003 A4 1.8TQM // Motoza // GTRS // 550cc // TR18T // Forge Splitter // 034 RSB & End Links // V710 Gunmetal 19x8.5
    →→FrankenTurbo F21 BUILD←←
