i am trying to debate on a flywheel for my car. car will be stage 3 frankenturbos with meth. car is a daily driver so i was debating a full face stage 3 clutch instead of a pucked clutch. from what i hear the aluminum flywheels are a little too light and the stock flywheel is 28 pounds. i feel that a solid steel flywheel is the best best since its in the middle of the two and should chatter less. i also read that the aluminum can get messed up from the heat transfer. lastly i read that somehow you can lose torque when you go with a lighter flywheel but it seems like thats only if you are launching the car. car is daily driver and i dont plan on launching it much if at all, but will definately be driven spiritedly. if anyone has input between these flywheels please let me know. i am debating between the 350 dollar fidanza and the ttv steel flywheel for 500 (every other steel flywheel is 850 or more which is crazy). thanks in advance...
