Results 1 to 17 of 17
    Jan 13 2010
    Orange, California
    Question B8 s4 vs. 2012 A7: How are 0-60 times so simular?
    Recently I have been reading about the 2012 A7 and all of the aesthetic and performance accolades that have been bestowed upon it by reviews of the vehicle ranging from Car and Driver to the Wall Street Journal. Personally the car does not really appeal to me, although I am proud of Audi for making such a more attractive car in this segment in relation to Porsche and BMW. However, my questoin is about the engine and the 0-60 times reported of each car. B8 0-60 times are right around 5.0-5.2 where as Car and Driver reported a 0-60 time for the 2012 A7 of 5.1 seconds. Although each car as the same engine, the A7 weighs nearly 400 pounds more than the S4. How is this possible????
    Veteran Member Four Rings riegeraudi's Avatar
    Apr 16 2009
    the S4 0-60 time is more like 4.9-5.1 and the A7 is more like 5.4-5.5 and the A6 is 5.1-5.2 from most of the reports I have read. You are taking the higher S4 times with the lowest A7 time. It was also possible that the A7 time from C&D was a rolling start. You really need to take the times from the same source for it to be more accurate because each magazine has it's own way of launching the car.
    Feb 13 2004
    Silicon Valley, CA
    Simple, gears.
    AudiUSA website gives 5.4 0-60 for the A7 and with the 8 speed, you get the following gears
    1st 4.714
    2nd 3.143
    You won't use third getting to 60mph, so that is some pretty tall gearing.
    They give the S4 a 0-60 time of 4.9 on the website with the following first two gears
    S tronic® Manual
    Gear Ratios:
    1st 3.692 3.667
    2nd 2.238 2.158
    They both have the same torque (325 lb ft), but the S4 has about 23 more HP. That torque is what is amazing though, that in first gear will get you to 30mph real damn quick.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Not to mention the A7 is bigger, heavier, and has a slushbox, not a manual.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Feb 13 2004
    Silicon Valley, CA
    That slushbox is nothing to laugh at, not like the slushboxes of the old days
    Senior Member Three Rings Psalm40's Avatar
    Jul 14 2011
    2011 MB GL450, 2011 BMW 135i vert, 2012 Range Rover SuperCharged
    Western Wisconsin
    InsideLine generated their own numbers for both cars. S4 was 4.9 and the A7 was 5.4. Both off the line with no roll-out.
    2012 Phantom Black, Black Silver Nappa, 6MT, Prestige Audi S4 - Built 8/26/11, In port 9/23/11, Delivery 10/3/11, pick up 10/21/11
    Alu Kreuz, APR/Carbonio intake stage I&II, CF splitter, CF Diffuser, R8 engine caps, Laser Interceptor Dual, Hardwired V1, Front PPF, WeatherTech Mats, interior and plate LEDs, VAG-Com, Stratmosphere short-throw shifter, Hoen xenon-match fogs, MORR VS8.2 20"x9 et 35brushed with double tint finish, Ventus V12 255/30/20, H&R OE Sport springs.
    Dec 22 2010
    ny
    lets analyze here
    OP is mag draggin
    OP is quoting 0-60 times
    OP doesn't like the A7's style
    ... simular
    Jan 27 2010
    Cayenne%20X5
    Long Island, Queens, LA
    I remember reading a recent CLS vs. A7 comparison somewhere, forgot which magazine it was. The A7 did standstill to 60 in 4.7 and the writer actually questioned how it was a couple tenths of a second faster than an A7 they'd tested a couple months before that.
    ig: gs.autogram
    Jan 27 2010
    Cayenne%20X5
    Quote Originally Posted by Stubek View Post
    this.
    i drove a tiptronic s5 a couple of times and the shifts are very quick and smooth. even blips the throttle on downshifts. definitely not your typical slushbox.
    ig: gs.autogram
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    This with 4 doors would make the ultimate crazy daddy family sedan, Panamera beater LMFAO:
    Shown here with the correct number of pedals.
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
    Veteran Member Three Rings MeteorS4Ti's Avatar
    Sep 24 2008
    Florida
    I've done 4.5s 0-60 in my S4 (only mod is intake).
    2016 S3 S-Tronic Sepang Blue/Black Sport Seats
    APR Tune|TAG Motorsports Gloss Black Rear Logos
    Previous:
    2013 S4 6MT Brilliant Black/Black Alcantara, Prestige, Sport Diff, B&O
    Stratmosphere Intake|Black Edition S4 Grille|Eurocode Meisterwerk STS|Hoen H8
    2011 S4 S-Tronic Meteor Grey/Black Alcantara, Titanium Package, Prestige, B&O
    Stratmosphere Intake|Hoen H8
    Apr 16 2009
    Quote Originally Posted by NWS4Guy View Post
    I got to agree the time difference is most likely due to the extra 200-250lbs plus the slushbox is a little slower than the DSG.
    Veteran Member Three Rings Brick Oven's Avatar
    Nov 03 2010
    SF CA
    Quote Originally Posted by Kandiru View Post
    The engine WOULD make a nice buffer between yourself and screaming kids in the back row...
    2013 Daytona B8.5 S5 : PP : Diff : Magma : DSG : Carbon : B&O ::: HRE P47SC 20x9.5 et20f et15r brushed titanium : Michelin PSS 265/30 : Bilstien PSS10 : SPC Control Arms : Eurocode Alu Kreuz : OEM Ecodes : OEM BO Grille BUILD THREAD: http://www.audizine.com/forum/showth...40#post7874340
    Aug 16 2011
    NC
    The S4's 4.9 seconds 0-60 manufacturer's number is conservative. Road & Track recorded the S4 at 4.4 seconds ... and going head-to-head with the fastest Porsche Spider (see link below). So, the A7s fastest at 5.1 seconds vs. the S4's fastest at 4.4 seconds is a 0.7 seconds gap. That leaves the A7 in the dust for sure. If you see an S4 number around 5.1, that's the S4's slowest. The A7's slowest test is I think at around 5.7 seconds, which I read somewhere.
    http://www.roadandtrack.com/var/ezfl...564774ca35.pdf
    Quote Originally Posted by Stone126 View Post
    Aug 16 2011
    NC
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    Quote Originally Posted by MeteorS4Ti View Post
    very believable...R&T has consistently achieved 0-60 times of 4.4-4.5 (with 1 ft roll-out) on stock setup
    definitely quicker than an A7 if you were really worried about it...
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Jan 27 2010
    Cayenne%20X5
    From MotorTrend
    The "little" engine in the A7 had us scratching our heads. It's down on cylinders and way down on power compared with the other two. Rated at just 310 ponies and 325 pound-feet of torque, the five-door four-ringer's supercharged V-6 bested the Jag by virtue of hitting 60 mph in a startling 4.7 seconds and flying down the quarter mile in a very quick 13.3 seconds at 103.5 mph. The slightly lighter and much more powerful Jaguar (385 horses, 380 pound-feet of torque) needed 13.4 seconds, though its trap speed was 106.3 mph.
    Like most other Audis, the A7 is AWD, but something smells slightly fishy in Ingolstadt, and here's why: Last month, we tested another A7 with the same engine and transmission (Audi's very nice eight-speed automatic) and recorded a 60-mph run in 5.3 seconds and a quarter-mile time of 13.8 at 100.9 mph. True, because of options or lack thereof, this A7 is nearly 100 pounds lighter than the car we previously tested (4140 pounds versus 4232), but 92 pounds does not explain away six-tenths of a second. Our testing crew complained about the A7's violent shifts, and we asked Audi if the transmission (or anything else) had been reprogrammed. They had no explanation.
    Read more: http://motortrend.automotive.com/164...#ixzz1W0c3OEfE
    i don't understand all the underrating bs that manufacturers do these days. if they're that afraid of stealing sales from the low volume top tier models then make those that much better too.
    ig: gs.autogram
