Results 1 to 36 of 36
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    2.0 stroker FSI or AEG crank?
    Yeah, we are having this discussion.
    I'm 99.9% going with the FSI crank, but is anyone using the AEG? The price difference is nuts between the two (obviously would be). Ever heard of the AEG failing? Opinions?
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Everyone says the FSI is overkill. And you have to have the gear for the oil pump changed.
    I have never heard of an AEG failing in a stroker application..........ever.
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Feb 01 2008
    SLC, Utah
    Correct me if I'm wrong, but I think you have to have the oil gear on the AEG changed out also....
    -Tyler-
    Sep 12 2008
    South Central PA
    I think the oil gear needs swapped, and I know you have to have the trigger gear swapped on the AEG. but I think the trigger gear on the FSI is the same as ours
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Feb 01 2008
    SLC, Utah
    Really, trigger gear? I knew that about the TDI cranks but not the AEG... hmmm
    -Tyler-
    Sep 12 2008
    South Central PA
    wait... maybe I'm wrong. there's too many cranks that work in this block LOLOLOLOL
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Feb 01 2008
    SLC, Utah
    Well, I'm about to pull the trigger on my stroker, and need to figure out which crank to go with. I'm not sold on either one. FSI is obviously premium, but at 3.5X the cost. If I can get away with the AEG with no ill effects then why not?
    -Tyler-
    Sep 12 2008
    South Central PA
    I'd get a AEG, nothing wrong with it
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Feb 01 2008
    SLC, Utah
    I'm really changing my mind on this, might go AEG. Anyone been running one for a good amount of time that can chime in....?
    -Tyler-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by nein-reis View Post
    negatory.
    the oil gear and trigger wheel will work as-is.
    I am using an AEG crank, Clint used one and David has one. David and I have quite a bit of mileage on ours. Mine was brand new when we built my motor. I bought it from Issam.
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    I got mine from an AEG motor with like 100k on it lol
    - Clint
    Oct 22 2005
    Reppin the Mitten.
    AEG crank as well...but obviously no where near the power levels you guys have...But probably one that drives the most in and out...
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    I got my FSI from IE
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    The real question is can you find an AEG. I wanted to use an AEG in my build but couldn't locate one so I opt to purchase a new FSI crank.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Feb 01 2008
    SLC, Utah
    IE can get me an AEG crank. Nice, well I don't see any reason not to go with the AEG and save a bunch of cash. sweet.
    -Tyler-
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    AEG is heavier, but can hold more power than anyone is making on this forum
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    exactly... nothing wrong with the AEG crank. I have never heard of anyone breaking or messing one up with too much power. cheaper also of course. I have an AEG crank in my new 2liter... which I have yet to install.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Sep 20 2006
    MD
    Good deal. i had to waste money and purchase a FSI crank
    Jan 24 2008
    Pennsylvania
    FSi is only a waste of money if budget is the primary concern. If you want less rotating mass go FSi, if budget is more of a concern then go AEG. Either way you can make lots of power and wont have issues. I found my brand new fsi crank for $450.
    Have the entire assembly balanced as well.
    Quote Originally Posted by MmmBoost View Post
    Not true. Lots of people say 1,000 horsepower is overkill. Some would argue that too.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Feb 01 2008
    SLC, Utah
    Actually, finding a AEG is proving to be really difficult. IE does not have any right now. poop
    -Tyler-
    Aug 10 2008
    Denver, Colorado
    You can buy a whole AEG motor for the price of an FSI crank. Then you have a 2.0L block and crank. Don't get an AEG block though, they don't have oil squirters. Find a later DBW 2.0L 8V mk4 engine (AVH, AZG, BGD) and IIRC they all have oil squirters. You will have to machine the thermostat interface on any block other than an AMB though.
    -Cam
    Jan 24 2008
    Pennsylvania
    Quote Originally Posted by FORCE_FED_DUB View Post
    true, but how do you inspect the journals? would suck to buy a whole motor just for the crank and find the journals are scored.
    i looked for an aeg crank and also found them about as difficult to find as an fsi, maybe harder unless you buy a whole motor.
    as i said before, 450 is not bad for a brand new fsi crank. look around you'll probably find one as well. unless a few hundred is going to break the budget. then go AEG
    Feb 01 2008
    SLC, Utah
    450.00 for a FSI crank? That is a deal I have yet to see, they are for sale all over... for around 800.00
    -Tyler-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I think that is what I paid for my AEG crank. But it was brand spanking new. Talk to Issam@INA.
    -Doug
    Dec 05 2007
    Difference between the 2 cranks has to do with material. But I highly doubt anyone on this forum board will be pushing enough power to break an AEG crank. And if they have power goals they think would exceed the threshold of the AEG crank, I highly doubt that would even be an option on thier parts list.
    How much work will be done to the TDI crank to work on the 06A block (same 83mm bore and 144x20 rods for 2067cc of displacement)? There is one on ebay right now for $275 shipped.
    http://cgi.ebay.com/ebaymotors/VW-Je...item20bc130e1e
    Jan 24 2008
    Pennsylvania
    I paid $450. And I also passed up on a used one for $550. If you look you will find.
    Jan 24 2008
    Pennsylvania
    the real difference is in how the crank is made, and the resulting weight and strength of the crank, and therefore rotating mass of the motor assembly.
    neither crank is going to break.
    Feb 01 2008
    SLC, Utah
    I have a couple leads on AEG cranks, yay.
    -Tyler-
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    negatory.
    Just to confirm: when using AEB crank in AMB engine, everything works as is, i.e. swap parts over from AMB crank?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by vtraudt View Post
    Want to put the parts list together for AMB stroker:
    When buying a used AEG: have it polished?
    What else is needed? 144x20 rods, 83mm pistons/rings. What rod and crank bearings to use? What thrust washers? Oil pump/pickup tube? Front and rear seal?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Ditto: if going FSI crank.
    05 Golf TDI
    Dec 05 2007
    Same as awm block. I picked up an fsi crank for $150 shipped. I would also suspect the aeb and amb cranks to be the same. Look up part numbers. I also suggest a polish.
    Feb 20 2010
    Brighton, MI
    All bearings, seals, bolts, etc same for AMB and FSI crank then (for ordering purposes)?
    05 Golf TDI
    Dec 05 2007
    Not sure. Look up part numbers and see if they match.
    Feb 20 2010
    Brighton, MI
    Mine is from a BPY engine.
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Oil pump sprocket/gear: FSI (BPY) 21 teeth? AMB 19 teeth?. Just swap over?
    05 Golf TDI
