Just thought I would post this if it ends up helping anyone. I know the aux fans not working properly or at all is a problem for b5 S4s. I had mine go out recently and went through hell to find out it was a simple fix after spending money I shouldnt have and yes you all can laugh at me but I bet youve done it before as well at somepoint. I started by researching this on the forums and found a multitude of could be's. I started by checking all my visible dash fuses and looked for number 42 bc a tech told me that has something to do with the fans which I thought was weird because the panel said something different. I also took the battery charger and fired up the aux fans to make sure they werent the problem. I fixed the aux fan switch on the lower radiator hose with no help and finally ending with replacing the control module with no help. I was pretty damn pissed having no luck and went to my local performance shop for help and ended up printing out a aux fan circuit schematic and it said there where 2 fuses that hook into the cooling fan circuit. A number 42 thats 40amp and a number 198 that is a 5amp. The number 42 was no luck and I still think has nothing to do with the circuit and I finally got the idea that I didnt realize there where hidden fuses under the dash behind the main fuse box. I took apart the dash under the steering wheel and looked for a number 198. I saw a little fuse center up by the firewall and saw a little 5amp in the middle and assumed it was the number 198. I pulled it and saw it was not blown and was about to get in a fist fight with my steering wheel when i decided to check the rest of the fuses in this hidden spot. A 60amp fuse was to the right of the 5amp fuse and when i pulled it I saw it was blown but figured it had nothing to do with the fans since I didnt see it on the printout. I replaced it and the fans fired right up!!!!!!! RIDICULOUS! After all that?! So there it is. Make sure you check the 60amp fuse under the dash and behind the main fuse box when your aux fans stop working or your S4 starts to overheat when at idle or when the ac is on and blowing hot air when not driving in the wind. So take it from me and dont waist money on the other stuff until you check this 60amp fuse. Hope this saves someone some trouble.
B5 S4 The Car You Love To Hate
Ryan B
