Hey guys... I have experienced the same thing on more then one occasion. Here are some things that were causing my "sluggishness".
1)
Broken diverter valve. If you're not holding boost, obviously the car will feel sluggish.
2)
Heat soak. This should be self explanatory. However for those you are unfamiliar here is an explanation;
Heat from the hot side of the turbo transfers to the cold side of the turbo (or the head itself can heatsoak as well). This increases the Charge Air temps from the Turbo/supercharger (Charge Air Temp = Ambient Temp+ Cold Side Temp + Compressed Air Temp, we normally assume Cold Side Temp = Ambient Temp). When you heat soak to the cold side, you have effectively created a turbo operating in a heater, this creates lower density > higher charge air temps pre/post IC. This is also a natural phenomenon, when cold and hot side temp differentials get large enough. Water and oil in the bearing housing absorb this in normal boost and driving conditions.
Heat soak obviously occurs more in the summer.
3)
Driving habits. Our computers "learn" the way we drive. If you have been using cruise control/a.c. during the summer, the computer learns that driving habit. Best way to clear this up is by resetting the throttle body;
key in ignition
press gas pedal
turn ignition to "aux" (do not turn car on)
wait 10 seconds
take foot off pedal
remove key
OR, you can just jump on the nearest highway and floor it!!!
If any of those don't work, I would highly recommend;
Ultimate Service Kit (A4 B7 2.0T)
