Results 1 to 19 of 19
    Veteran Member Three Rings NickZag's Avatar
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    Spring compressor #*^&!!!!
    I need to pull a front coilover off and I've bought 4 different spring compressors, all of the failboat due to the tight fit. I've seen a bunch of DYI threads, but nobody mentions what compressors they're using. Does anyone have a recommendation? The ones through VW/Audi is $300 and there is no way I'm spending that. Someone mentioned the one from Harbor Freight and it sucks. I can't find a good place to use a ratchet strap either. I'm going crazy
    Thanks
    2021 A4 | 2006 S4 Avant
    Mar 05 2009
    Earth
    Sorry Nick, I don't have any compressor advice but I'm curious to know what went wrong with the Bilsteins.
    Veteran Member Three Rings Gmoney's Avatar
    Jul 29 2009
    05 Audi A4TQM
    Charleston, SC
    Have you tried going to advance auto parts or auto zone etc and renting one of their strut spring compressors? They have always worked for me plus you don't have to buy them. Just rent them.
    APR stage 2+, CM FX400, LWFW, APR snub mount, JHM short throw, RAI TP, Forge DV, RS4 rear sway bar, Vogtland Coilovers, Thor belly pan. 19's staggered.
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    ..... are you trying to compress springs with the struts still on the car?
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Senior Member Two Rings wakerider137's Avatar
    May 28 2009
    San Jose
    I just put a Stasis coilover kit on over the weekend and it was a spring compressor nightmare until I modded the HF ones and figured it out. On the fronts I used the rented kit from Kragen, all you pay is a deposit. On the rear springs I went to Harbor Freight. They are only $10, so you can just cut them to size with a sawzall or hacksaw and customize the fit. Those are about the only options you have other than the VW/Audi ones.
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    We rented a spring compressor to do my spring install but realized that it wasn't necessary
    A second set of hands seemed to be more useful.
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Mar 20 2011
    I provide this with significant warning!!!
    worm gear hose clamps. Use at least 3 and ratchet each one no more than a couple turns before moving to the next.
    Good luck and wear face protection.
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    After a few weeks of the knocking going away, it came back with a vengeance and I couldn't stand it anymore. There are no issues with the Bilsteins, just the idiots who installed them. I had to tighten the top nut which was loose.
    I ended up cutting down the Harbor Freight compressor and it worked fine. Wish I would have done that initially, I could have DYI'd everything and saved $$$
    Mar 02 2007
    Fresno, CA
    Nothing worse than a chattery suspension. Glad you got it sorted out, Nick.
    Aug 20 2010
    toronto
    I changed my springs without using any spring compressor.....
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by mage0608 View Post
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    OMG! Cookie for you!
    Oct 15 2011
    around the world
    any info on the torque specs needed for the install?
    thank you in advance
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    I couldn't find any. I tightened everything down very hard with a ratchet and box wrench. I double checked everything when I installed the BBK and everything was tight and snug.
    Oct 02 2006
    Wadsworth,OH
    What exactly do you need spring compressors for? When removing the suspension as a unit its really not necessary. Unless you are changing out a shock where the spring needs to be removed.
    Ive known people who have un-done the strut mount bolt with the suspension unloaded and while in the car. Its not the smartest idea but it can definitely get the job done.
    Jason
    Senior Member Three Rings Speycaster's Avatar
    Aug 16 2011
    2006 Audi A6 Premium (Wife's); 2008 Chevy 3500 Club Cab Duramax Diesel; River Wild, Custom Jet Sled
    Roseburg, OR
    Quote Originally Posted by wakerider137 View Post
    I did the exact same thing. I almost hung myself after 2 hours of trying to fit the Napa spring compressor on the rear springs. Answer...cut the Harbor Freight spring compressor to fit. For $10 it is used as a sacrificial lamb.
    Glad you got it worked out.
    2010 2.0T 6MT, APR Stage 2 ECU flash, APR turbo back quad exhaust, APR Carbonio intake, Eurocode HFIP, Eurocode Intercooler Hose Kit, 034 Turbo Inlet Hose High Flow Silicone, E-Code Xeon head lights, Various Vag-Com changes, H & R Coilovers, Hotchkis H-Sport ARB's, Eurocode Alu Kreuz Billet Aluminum Drivetrain Stabilizer, Stratmosphere Hypershift short shifter, TyrolSport Brake Caliper Stiffening Kit, S-Line Side Blades, 19" x 8.5" Hartmann Euromesh 3-GS:ML wheels, 255-35-19 Toyo Proxes 4 Tires
    Oct 30 2016
    Lockport NY USA
    Quote Originally Posted by Speycaster View Post
    Can anyone, please, post a pic of the spring compressor they used for the rear? I can cut things, no problem there. I looked at HF, and they don't seem to currently offer anything which would work. I have the single beam strut compressor, for the front, but it's not working a bit for the rear. I also have one with a threaded rod, and hooks on each end. I think I need more of a plate. Only a enough room to grab 2-3 coils before arm and top recess get in the way. Even then, my threaded rod is too thick to get into the hole in the top coil bushing. The VAS 6274/10 is only $1499.00 on ebay!
    Thanks in advance!
    -Ryan
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Here ya go: Clicky click®
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    That is a good idea, I lowered the rear subframe and got old springs out and new ones in without compressing the coil spring
