Results 1 to 23 of 23
    Established Member Two Rings The1nutwonder's Avatar
    Aug 10 2011
    Beaufort sc
    A/C randomly shuts off
    so my a/c will randomly just shut off i think its just the fan thats shutting off but either way it just stops blowing. Pauses for 2 sec and then starts again. There doesnt seem to be any kind of trigger that will make it do this. It just does it at random. The owners manual says that the fan will shut off during wot to give u a bit more power for acceleration. But it will do it while at idle or cruising speed. I dont have a need for wot so i havent tested that theory yet.
    Veteran Member Three Rings bora_1_8t's Avatar
    Sep 09 2009
    2004 B6 A4 1.8T Q6M, 05 Honda VTX 1300C
    Albuquerque
    Mine does the same thing
    mods: Koni coils, suede door and dash trim, BSR cat back, samco hoses, TT injectors Unitronic Stage 2, water/meth and brushed aluminum trim and badges
    "No bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country." George S. Patton
    Veteran Member Three Rings ReniA4's Avatar
    Jun 26 2009
    Clearwater, Florida
    same here, once in a while though
    "Reni"
    Maya Stm 19'',eibach pro kit,bilstein sport,magnaflow,K&N,Giac,Rai TP, Vent Awe,Hitachi-E,034 street density,full ABT,RS4 sway,EuroGear Boser..ect...ect
    Senior Member Three Rings jonnybravo's Avatar
    Nov 23 2009
    San Jose
    My buddy's does the same too...Any fix for it?
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    You are low on freon. The ac detects it's low and shuts off the compressor to avoid damage to the system.
    Correct solution:
    Have the system vacuumed out, checked for leaks, fixed if need be, and refilled.
    Cheap solution:
    Go to your local autoparts, get one of those freon cans with the hose and gauge, and top off the system. Read the instructions on the can very carefully and do not overfill it. ...this is a bandaid solution usually, eventually you will probably need to do the first option.
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Wouldn't it do it a lot more often if that was the case? This happens to me like maybe once every couple of months....and I live in Texas.
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Hmmm, that is very interesting I have been having the same issue. Eerie, what exactly do you mean by vacuuming out the system? Just a complete flush of the fluid?
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    mine does it also... although im sure ive seen it happen with the A/C off also, but I cant be sure
    its not vary often though, maybe 8 times in the 3 years ive owned the car, it happened once while I had two of my buddies in the car who are both Audi techs and they were both confused as well, I dont think its low freon as mine still blows cold, but ill check into it
    Please Drive Right
    May 30 2008
    Honda HRX
    Penna.
    If by "turns off" you mean the compressor shuts off and the "ECON" light comes on it's a low freon situation.
    My HVAC unit actually blips off then comes back on (t even retains its settings) every so often... And I don't know WTF that is. I'm guessing the unit itself is just going bad. I don't drive my B6 often and I kinda forgot it does that. It happens at random and probably once every 2 hrs of driving.
    Quote Originally Posted by evo_ski View Post
    Basically.
    A shop that does A/C work has a machine that pulls the old freon out and puts the system under a vacuum to see if your system leaks. If it holds the specified vacuum then they just refill it with fresh freon and send you on your way. (with a bill) If it shows signs of leaking they have to find and fix it. A/C systems should not consume freon. If they do it's from a leak somewhere.
    Mar 15 2010
    Bothell
    Quote Originally Posted by EErie B6 View Post
    Basically.
    Awesome, thanks for the info, thats what I thought. My situation is the same as yours. It is almost like it shorts out and just flips back on within a second of turning off. It never goes to ECON it just shuts of and instantly turns back on with the same settings every once in a while.
    Jun 26 2009
    Clearwater, Florida
    mine does it 4-5 times a year. i dont think it has to do anything with the frion since last time that it did was after i filled it up with frion. Like evo-ski said mine also it never goes to ECON it just shuts of and instantly turns back on with the same settings every once in a while. it only shuts of for 2 seconds. i thought was some type of safe mode or smth like that since i keep it on all day here in fla.
    "Reni"
    Established Member Two Rings swirls's Avatar
    Apr 28 2011
    2001 Jeep 2011 Jetta
    Red Lion, Pa
    Check this! Had AC then ECON light then this
    - Sent from my iPad bitches! Winning!
    Jun 02 2008
    hmmm mine sounds a little different than yours
    mine will be blowing a 5 bars (or level 5, what ever you call the fan speed) for example, then go down to 0 bars one bar at a time, stay off for a second, then start climbing back up to what ever it was set at before
    I usually have my climate control set to 60, so chances are the A/C pump is on most of the time
    Please Drive Right
    Aug 10 2011
    Beaufort sc
    Well im lucky my father inlaw has all the equipment for the ac unit so ill try the solution on sat and let you guys know how it goes. but mine does like most r saying. No econ light just fan shuts off 2 second pause then starts back up.
    Veteran Member Three Rings maurizio's Avatar
    Sep 23 2005
    '09 Pilot
    Lake county, IL
    hey mine does this too, can someone confirm if the fix worked for them ?
    "Are you actually asking that question.. Just don't even post on my thread. why do I need to lie on an Audi forum about me fucking two bitches at once. (not literally) yes i did, you are late to the party.
    and this thread has ran out of gas. I just wanted to tell people about my experience I had 2 nights ago and felt like sharing it with my fellow B6'ers. And I thank the people who didn't hate."
    Senior Member Two Rings jai5's Avatar
    Apr 09 2010
    canada
    Did anyone ever find a fix for this?
    Mods: Racing stripe+20hp, Neon underglow+20hp, Stickers+10hp, Altezza+20hp, Metal wing+30hp, 22" Rimz+40hp, total 500horses guyyy.
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    i just refilled my freon the autozone way and it hasnt done it, i think. im sure its that stupid auto adjust thing. i wish that crap would not mess with my frickin settings
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Veteran Member Three Rings travrach's Avatar
    Apr 13 2012
    This thread is very confusing, are people talking about your HVAC fan shutting off (as in no air at all blowing out of vents) or Vents stop blowing cold air (AC issue)?
    jai5, what is your issue?
    Mar 15 2010
    Bothell
    Basically you are cruising along and then the whole thing stops and no air is coming out at all. The lights even blink off for a quarter second and then turn back on. The fan speed indicator reads 0 and then it will one by one add bars to the fan speed window until it is back at what it was before it shut off. The whole thing happens in about 2 seconds.
    Apr 09 2010
    canada
    I definitely don't have that issue.
    Everything on the on the climate control stays on. But the A/C stops blowing cold air for a few seconds and then comes back on.
    My major issue that I'm trying to solve is that my car randomly turns off (whole car) with A/C on while in traffic on really hot days.
    Aug 10 2011
    Beaufort sc
    I ended up replacing most of the system so i dont know which part in particular actualy fixed it but i know i did not replace any mechanical parts only the electronics and it worked great until i traded up for my a6 avant. Which go figure has an a/c compressor issue. By the time im done i will have redone an entire a/c system on a 3.0 just on seperate cars lol. Worst part is here in sc its gettin close to being 9 thousand degrees outside on a daily basis. Or atleast thats what it feels like with no ac and 4/65 a/c lol.
    Apr 13 2012
    Have you been able to check for codes after that happened? Have heard about some blower modules overheating and turning off..
    Quote Originally Posted by jai5 View Post
    Have you had the AC pressures checked?
    The major issue is another story....crank sensor maybe.
    Jun 08 2007
    Orlando, Fl
    Replace your high pressure switch. Bad switch will cause the system to randomly shut off.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
