Driving home yesterday, boost dropped from normal 17-19psi to 3-4psi...under WOT in 3rd and 4th I can climb to 9 psi around 5500rpm...figured it was boost leak so I did check sure enough the pipe off the turbo was partially off...fixed it said hell yeah and went for a spin...boost still not back, did another boost leak check to ensure no other leaks, and there were none...took n75j valve off and I put the greddy profec back on...boost still not back...actually lower...when I was under there I noticed the SAI pipes intake was missing ( i had a small cone since I have a K&N cone)...unplugged SAI and still boost is gone.e flapping sound sounds like a card in a bicycle wheel.....this leads me to believe my turbo is bad (no smoke, nothing out the exhaust), wastegate is stuck closed, or SAI sucked something up since filter was gone...anything else anyone can think of??? No CEL except for turbo underboost code which I have had since i did the FMIC...turbo is a k04 off s3 i believe, and is about 2000 miles old...any help appreciated.
