Results 1 to 9 of 9
    Veteran Member Three Rings judeisnotobscur's Avatar
    Apr 22 2009
    America
    The link between o2's and throttle body.
    I've been having a hell of a time tracking down an electrical issue. turns out that the o2 sensors and the throttle body run off the same 5v reference signal from the ecu. In some instances, bad o2 sensors can affect that reference signal causing the ecu to see faulty readings from the throttle body. This has even been known to fry ecu's.
    after a phone call to ross-tech, I simply unplugged my o2 sensors and bam, throttle body came in on adaptation after a couple months, and 1 throttle body later of not doing so. I only unplugged the front o2's because i don't have any rears, but you would want to unplug all of them when diagnosing this issue.
    I'd like to give a big shout out and thanks to Ross-Tech. The guys over there are top notch.
    Timing is Everything
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    The weirdest shit is interconnected on these cars!
    -Darrick
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    S4s do some weird shit sometimes.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Are you sure that the O2 sensors are running off of the 5V reference? It's been a while since I've looked at the schematics but I'm almost positive they don't, and that they're fed 12V and tied into either the injectors or coil power.
    That the O2 sensors (if they're shorting/damaged) might cause other issues with the ECU because of back-feeding, that is entirely possible though.
    Apr 22 2009
    America
    I didn't check the schematic again but that's what Ross tech said.
    After unplugging the o2s the tb aligned right away... either way the o2s were causing the tb issue.
    Jun 14 2007
    2000 S4
    Connecticut
    Great group of guys.. That's why I bought my first HEX-USB cable from them, and then recently just bought a HEX+CAN USB to do all VW/Audi's to date. Nothing beats the real thing and customer service
    Jan 29 2009
    Quote Originally Posted by judeisnotobscur View Post
    Yeah going by every O2 sensor I've ever seen, they're always supplied 12VDC and not 5...
    But since the driver and heater circuit inside the ECU is what controls the ramp of the heater and nernst cell(s) a short could cause any number of unpredictable issues
    Sep 17 2005
    Fremont, California
    While almost anything can cause shorts and weird behavior, the O2 sensors in our cars don't use a 5v reference; O2 sensors create their own voltage. Their heaters are 12v.
    Sounds like you got something weird going on; I personally don't believe they are directly connected to eachother in anyway, but you perhaps were having a short due to crossed or cracked wires or something of that sorts.
    Regardless, sounds like its getting fixed!
    Feb 02 2009
    Cars other people killed
    capital city wastes
    a dirty throttle body will throw off the fuel trims and set boost leak codes and lean/rich trim codes. its stupid weird but it does happen. if you clean the electrical portion of the tb and the motor it will magically go away. This usually happens on 1.8ts though but the throttle body internals are all the same so i guess it can happen to anyone.
