Results 1 to 15 of 15
    Senior Member Three Rings 4 black rings's Avatar
    Mar 11 2008
    West Menlo, California
    Rough price for a boost/vacuum leak test?
    I believe I have some sort of boost leak and I wanted to get a feel for what a boost/ vacuum leak test should cost me? Thanks in advance
    APR Chip, Painted calipers, Slotted rotors and stainless lines, clear bra, tinted tails, Vip modular 19in rims, KW V3, RS4 rear sway, Neuspeed exhaust, JHM short throw shifter. 034 hiflow cat and Aprikol snub mount, AWE FMIC, Custom Catch Can, APR HPFP
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    i paid a 1/2 hour of labor for my boost leak test (which included a smoke test which lets you know exactly where the leak is coming from and how much is leaking)
    so around 45-50$ very worth it imo
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Mar 11 2008
    Ok thank you.
    Veteran Member Four Rings freaksavior's Avatar
    Jul 06 2010
    Houston
    If this is what i'm thinking it is, I built a tool to test it out by following a4mods. It cost me $9
    Senior Member Two Rings Schmaud's Avatar
    Aug 02 2009
    St Cloud MN
    About $50 like shicka said.
    Jul 08 2010
    tucson
    danbury
    Freak built one, siliconeintakes.com has them pre built for about 9$ more too if u have an air compressor its worth it
    [CENTER]Scott
    2011 S4
    Jul 06 2010
    Houston
    Here is what I bought, it was all for 2" though.
    http://www.lowes.com/pd_23356-1814-P...pvc&facetInfo=
    http://www.lowes.com/pd_23302-1814-P...%2B&facetInfo=
    http://www.lowes.com/pd_23306-1814-P...lug&facetInfo=
    BUT you could probably get away with a 2" pvc cap and then drill the small hole, screw the air hose tap into that. The clamp you need is a 2.75"
    Assuming you have an air compressor
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by freaksavior View Post
    Is 2" big enough? Isn't the inlet pipe on the maf side 3"? I want to make sure, cuz I want to make one tonight.
    2021 Audi S4, P34 Intake
    Jul 06 2010
    Houston
    That's what I went with. I've used it a couple times and as long as you're less than 20psi running through it, you're fine. :) just take off the hose to the air box and use the same clamp and it'll hold.
    Ideally you want 2.5" but you won't find it, so I bought 2" thinking it would work and it does. i'll post a pic of it later when I get home (In about 2 1/2 hours)
    Registered Member Four Rings BoSNiaN's Avatar
    Jun 02 2011
    2012 Benz ML350, 2007 BMW 325xi, 2006 Audi A4 2.0T
    Quote Originally Posted by mr shickadance View Post
    Thanks for the link but what size do you think is best for my (engine wise) stock 2T?
    Isn't the one on A4 mods for something else tho? Those seem to connect to the turbo...not the airbox.
    2006 A4 2.0T 6 SPD MT // Dolphin Grey on Black // Sport + Premium Package // Quattro
    ==> Complete Mod List <==
    Dec 03 2008
    2018 SQ5
    Cool, thanks. Do you even need the elbow? Looks like it'll work without it.
    Jul 06 2010
    Houston
    Quote Originally Posted by BoSNiaN View Post
    Your question doesn't really make sense. if you are talking about the piping, then read one post above yours.
    I bought it then cut the elbow off to give the pvc a bit wider spot to stick in the hose. i'll show you what I mean later. :)
    Dec 03 2008
    2018 SQ5
    Oh, ok, I get it. Cuz the female end on the elbow has wider hips!
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I built the one off a4mods.com and use 2" just like they listed. I had no troubles inserting it in to the tube going to the turbo and using the factory clamp. It all sealed up just fine and I used my air compressor to test for leaks.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
