Results 1 to 28 of 28
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Source for rear axle?
    So I sheared a rear axle shaft this weekend and need a replacement asap. Does anyone know if the shaft is separable, so I could just replace that instead of the whole assembly. Also does anyone know of an aftermarket alternative, the OEM part is $500+.
    Also can anyone confirm that the 2.7t, 3.0 and 4.2 rear axles are the same, seems that way from digging around in ETKA.
    Thanks, any advice/insight is appreciated.
    Jun 18 2010
    16 Jaguar XF S
    Fort Lauderdale Florida
    Which car is it for? I doubt the axles are all universal. www.car-parts.com is a junk yard search engine. Shokan is another audi junk yard. and depending on the model you have audis4parts.com is another. ecstuning is another but the price tag will be worth an arm or leg.
    Jun 18 2010
    16 Jaguar XF S
    partsgeek.com is another good one
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    2001 A6 4.2 with a manual, the stock axles were retained though.
    Nov 13 2009
    usa
    just needed one of these myself. the 4.2 is the only axle that'll work. i bought a used one, pulled my old one and its being rebuilt for $100.00. prolly do the same with the other after i get the first one back. i get great discounts at a few audi dealerships if you want new, prolly save you close to $200 bucks
    May 16 2008
    South Texas
    I've got a few good used ones. Which side did you need and how the @#$% did you shear a rear axle?
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    I just had to order 2 new fronts ones last week, I think Raxles.com have the best.
    Just give them a call.
    2004 Audi A6 2.7T
    Veteran Member Three Rings pohsib's Avatar
    Jan 04 2009
    Vancouver, BC
    Rear axles are the same for C5's. When I replaced my 4.2 rear diff with the one from the 2.7, axles were the exact same part number. I have two rear axles if anyone needs them.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Pabl0 thanks for the info.
    Scott I'll email you momentarily. Broke the axle launching the car hard on the wrong kind of pavement.
    Frank, thanks for the recommendation. I emailed raxles last night to see if they had a rear.
    Shokan has one and they are close so I may go with that.
    I'll post pics of the axle once I get it out tonight.
    Nov 13 2009
    usa
    Quote Originally Posted by pohsib View Post
    wrong. the diff side is the same, the wheel side is not.
    Jan 04 2009
    Vancouver, BC
    The rear axles are identical. Proof would be my car. I parted an 01 A6 2.7T and swapped everything into my 00 A6 4.2. The rear axles had the exact same part number on it and I now have the rear axles from the 2.7T on my A6 4.2. Not sure what "wheel side" part is different. They are identical.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Senior Member Three Rings Audi4.2's Avatar
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    Quote Originally Posted by beemercer View Post
    damn, that is some shitt
    Jan 31 2010
    S-Line A6
    East Haven, CT
    YES!!! THATS EPIC!!!
    Saving this picture for sure
    Oh, and sorry for thinking this is cool, but c'mon now.
    Aug 11 2011
    Hubbardston, MA
    hey Beemercer, just realized you're down the road from me (i'm in Holden)...there's an EXCELLENT shop in Sterling, btw...should you need work done (beyond what you're obviously capable of).
    cheers,
    dave
    Veteran Member Four Rings redneck truck's Avatar
    Apr 22 2010
    2001 TTQ TDI Roadster 6MT, 2001 A6 4.2 6MT, 2005 Jetta Wagon TDI 5MT, 2006 CBR1000RR
    Plano, TX
    Pabl0, I used 2.7T rear axles in my 4.2. I'm glad you're certain they're not compatible - I've just put 14,000 miles on the wrong axles, and without this information, something bad might have happened.
    Beemercer, PM'd you, I've got a couple spares as well. You might consider having yours retubed - a local shop did that for my fronts for a very reasonable price. It added some weight, but ensured I don't break them.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    ^I definitely considered it, but from a quick look last night the CV looked bashed up too. There's a clip piece on the inner CV that kind of holds it all in I gather (not an expert on this stuff) and its was cracked it two. I'm gonna still look into it though, would be nice to have spares
    Bryan@audis4parts has one for me that just needs to come off the car, should hopefully have it tomorrow.
    Apr 22 2010
    Plano, TX
    Fair enough. For the record, I've got some spares as well, ready to mail if you break another.
    May 16 2008
    South Texas
    I have a few on the shelf did you get my email?
    The axles are the same left to right but from V6 to V8 they are not the same (this doesn't mean they won't retrofit however)
    4B0501203C drive shaft with constant velocity joints 6 cylinder
    4B3501203B drive shaft with constant velocity joints 8 cylinder
    Jan 04 2009
    Vancouver, BC
    Hmm..Both my 4.2 and the 2.7 had 4B0501203C rear axles and clearly states the part number on the axle shaft. Not sure whats going on there. Maybe my car had axles changed prior to me owning the car. In any case, it seems any C5 rear axle will work.
    Nov 13 2009
    usa
    Quote Originally Posted by redneck truck View Post
    well as scotty just said they are different part numbers. since you are trying to be a jerk i'll just say this...it took me a weekend to complete my 6spd swap. it took you over a year lol
    and i'm glad they fit and its been confirmed. makes everything easier
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Here's another good laugh; I was looking around for a 17mm allen to take out the axle bolt, figured I'd check sears. So I searched on their website to be sure, and look what I found
    hahah no worries, I'm keeping it as a trophy. I only laugh when shit breaks/lights on fire with my car.
    Quote Originally Posted by dave_graham View Post
    cheers,
    dave
    Nice, what are you driving Dave?
    Aug 11 2011
    Hubbardston, MA
    Bee,
    2003 Allroad Tiptronic
    Veteran Member Four Rings SteveKen's Avatar
    Jan 11 2005
    Pittsburgh, PA
    I can confirm this with the RS6 and S6 that Scotty is right about the incompatibility between the V8 and V6. This all depends on what was done for your conversion. Since your rear diff is fro an A6 (4.111:1) then whoever installed it cold have swapped the axles to match the diff flanges or they could have swapped the flanges to the V8 ones and kept the axles. What's the opposite hole to hole diameter of your broken axle? I'm curious whether it was impact damage that caused it to fatigue. The fracture doesn't look like torque was the root cause. Looks like it was sawn in half. I've got two sets of A6 ones lying around but you'd be better off getting a fresh reliable set from Scotty. I wouldn't recommend replacing just one either, as the rear diff probably transferred all the power to the other ale when the other one broke and it's probably in a not so good state either.
    Steve
    2013 S6 • 2012 Q7 TDI S-line • 2010 GTI • 2001 Honda S2000 • 1977 Honda CB750 F2 • 1965 GMC 1500 WideSide
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    ^Steve, I'll have to check the axles tomorrow, hopefully the A6 4.2 one works so I can get on the road again. Also agreed I think there were a lot of factors that went into the break, I'll have to inspect the shaft when I have time.
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    got the replacement in, all seems well. Pretty easy swap all-in-all
    Jan 29 2011
    06CLS55AMG
    Edmonton%2C%20AB
    ahaaahaaaahahahahaaaahahahahahahah rofl
    at first i was like what is that a wine opener and saw the pic in full size looool WTTFF
    May 29 2011
    2000 VW passat B5 2.8
    Bay Area,CA
    Quote Originally Posted by Audi4.2 View Post
    that sure is a wine opener
