I would say this is a pretty easy job. Maybe a 2/10 on a difficulty scale.
Symptom:
I noticed the shifter on my car moving rearward during spirited driving. It progressively got worse to the point where it was happening for every shift. The shifter was moving up to 1/4".
This is when I decided it was a good idea to replace the snub mount.
Required Tools:
- flat head screw driver
- 13mm socket
- #6 torx bit
- ratchet
- jack & jack stands or ramps
First thing you will need to do is elevate the front of the car. I used ramps. You could also use a jack and jack stands. Either method should use the parking brake and chock the back wheels. Failure to do this could kill you!
Next grab your flat head screw driver and proceed to remove the screws from the skid plate. They should only need about a half turn to come out.
Once removed, have a look under for the snub mount assembly.
Use the ratchet and #6 torx bit to remove the bolts, and the 13mm socket to remove the nuts located in the picture below.
The brackets and OEM snub mount should come right out.
Here is what the front Snub bracket looks like removed.
Once it has been removed you should be left with this:
The OEM snub mount won't come off without effort, so try spraying some lube on it and it should make it a whole lot easier.
Here is how it looks removed.
Here is a comparison between the OEM snub mount and the 034 Motorsports snub mount.
This shot should give you an idea how soft the OEM snub mount is.
Now spray the new snub mount with a bit of lube and push it onto the mount.
Now line everything up where it was removed from and screw in the #6 torx bolts where we removed them from. Then screw the nuts back onto the front bracket. (You should be able to see from the wear on the bracket how it was aligned previously).
Once installed it should look like this:
Now start the car and run it for a minute or so to ensure there are no rattles of anything out of the ordinary. Turn off the car. Now go back under and re-install the skid plate. Remember the screws only need about a half turn to tighten. Don't forget there might be a few hot parts under there so don't burn yourself.
Put the car back on the ground and take it for a test drive. You should immediately feel little to no movement in the shifter while driving around and going through the gears.
