Page 10 of 10 FirstFirst ... 8910
Results 361 to 397 of 397
  1. #361
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Why am I getting this? I am trying to run an AutoScan and my VCDS locks up at this test, the only way I can get back to VCDS is to kill the app. I do not have a OEM phone installed in my car, is there a way I can disable this test from AutoScan?
    Also, is there a way to test the washer fluid pump through VagCom? I tried to use my pump today and got nothing.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
  2. #362
    Jun 27 2011
    The Official B7 A4 VAG-COM Modification Walkthrough
    I haven’t done an auto scan in ages. You can set scan profiles in some config file. Ross tech has a page on their site somewhere. I made profiles for each of my cars just by doing an initial autoscan, copying the autoscan controller list and eliminating the ones that weren’t present. Speeded up the autoscan by like 4-5 minutes.
    As to why it’s hanging at that controller? No idea. Could be a bad config? dodgy laptop USB ports? Hard to know. Honestly sounds more like a hardware/windows config issue than a VCDS issue.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  3. #363
    Apr 08 2016
    Mission Viejo, CA
    Not sure if it's a port or bad config, but I do know it's the only test it hangs on, every other non-existent component just passes through. Could it be that since my PR came with the phone option that my ECU is coded for it and therefore wants to run the test? I will check with Ross-Tech to see if there is a way to disable the phone test.
  4. #364
    Jun 27 2011
    Quote Originally Posted by mgfranz View Post
    Just delete the module number that is hanging from the b7 line in the autoscan.txt file in the Ross tech directory.
    -CP
    2017 Q7 3.0t
  5. #365
    Veteran Member Three Rings GTA_G20's Avatar
    Jan 25 2018
    2004 Boxster S 550 SE
    St Catharines
    Got a new laptop last night and tried to install VAGCOM, I got the 18.2 installed sucessfully but its saying my cable is on 1.92 interface firmware and needs 1.96. However when
    i try to update it errors out and wont let me update. Any suggestions?
    2005 Audi A4 1.8T Quattro(Gone), 2006 Audi A4 Avant 2.0 Quattro(Gone), 2004 Porsche Boxster S 550 Spyder SE, 2012 Audi A4 Quattro
  6. #366
    Senior Member Two Rings Snert's Avatar
    Apr 15 2016
    Minneapolis, MN
    Been looking all over, where can I find the right cable for an 08 A4?
  7. #367
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Quote Originally Posted by Snert View Post
    https://store.ross-tech.com/shop/cat/VCDS
    Also look at the distributor list on their site to find someone close by your location
  8. #368
    Mar 20 2019
    Sydney
    Hi Everyone!
    Joining the Audi family as I bought a couple of months ago my first Audi ever.
    It's a 2009 Audi A4 B7 S-Line convertible and I'm a really happy owner.
    What prompted me to sign up is because I my ECON button won't turn off anymore. I actually already did some digging and found out that it could be
    - blown fuse
    - Low gas level
    - faulty pressure sensor (g65)
    - leak or part of the AC system broken
    In order to pinpoint what's causing the system to go in safe mode I need an ODB2 reader in order to read the system's faults (it could be as simple as a low gas level).
    I've read on this forum that you can either buy the more expansive official Ross Tech ODB2 cable to do modifications to the car or buy a cheap generic ODB2 cable that only allows you to read faults.
    That's the one I would like as I just need to figure out what exactly is causing the AC system to in safe mode and avoid being ripped off. (also if it's just a low level gas I can get a refill somewhere for cheap)
    Would anyone be kind enough to point to the correct cable for my car? If you got an Aliexpress or ebay link that would be really perfect :)
    Many thanks in advance. I'll see you around and I'll be posting pictures of my convertible soon :)
  9. #369
    Junior Member Two Rings
    May 08 2015
    Houston, Tx
    Quote Originally Posted by Arese View Post
    Hi Everyone!
    - blown fuse
    - Low gas level
    A dongle like that would be no good for you. It will only tell you that you have a problem, which you already know that. If you really want to take care of that baby, get a VCDS that can erase codes. The ECON mode means that compressor is off. You could be low on freon and low on pressure. If you add yourself, you need to know how much is already in or you risk to overfill it and blow the compressor. You better save the $ and go to an AC shop and look into problem. If there is a leak, they should be able to find it and problem is solved. Even if you add some and you get it right, you still need to reset fault to work again because it will not go away by itself when problem is removed. So you still need the VCDS and can do any other diagnostic that you will need in the future.
    Doc
    And if I could ask how, check twice, do it once and use it forever...
  10. #370
    Mar 20 2019
    Sydney
    Quote Originally Posted by doctorul_doc View Post
    Hey thanks for your reply.
    No I wasn't planning to add freon by myself, I just have a groupon coupon for freon refill but I'm just wary that they will take advantage of the fact that I have the ECON button on to come up with an imaginary problem to charge me extra.
    If I know what's the issue (G65 sensor dead, low on freon ..) I can go to the car shop and tell them exactly what I need to get done on the car.
    So ultimately I won't need to reset the fault myself either. I just need to know what the error the system is returning.
    Would one of these dongles give me a fault code?
    EDIT: What about that one? https://www.ebay.com.au/itm/OBD2-OBD...9/173263000341
  11. #371
    Dec 09 2017
    Vancouver
    Just got my cable and trying the basics but none of my numbers are ...well look at this one and let me know why you think it is telling me error 31 out of range. IMG_20190905_162140.jpeg1567726616907.jpeg
    I do..... what I can do..... when I can do it.
  12. #372
    Sep 28 2007
    @All Flash - what are you trying to change? looks like the your math when calculating a coding value is incorrect.
  13. #373
    Dec 09 2017
    Vancouver
    Tried the 0023259 for the seatbelt chime..... That number in there you see was what was in there already. Got the Euro headlight and remote windows w/ one click unlock to work but the seat belt chime is laughing at me.
  14. #374
    Sep 28 2007
    According to my reading of the instrument cluster label file 8E0-920-9xx-8EC.LBL, last digit should be 1, 4 or 8 - your's is a 9
  15. #375
    Dec 09 2017
    Vancouver
    Quote Originally Posted by a4audi4fun View Post
  16. #376
    Dec 09 2017
    Vancouver
    It seems no matter how I set my numbers using the guide from vcds everything is out of range error 31.
  17. #377
    Dec 09 2017
    Vancouver
    From this chart I read +1 for smaller fuel tank (Quattro) , + 16 for clutch switch in fis display so
    0017 then 3 for Canada 0 for no seatbelt warning and 1 for standard for option 2 ending up with
    0017301 .... But no bueno!
  18. #378
    Dec 09 2017
    Vancouver
    Kk figured it out..... Just changed the 2nd last number to 0 and I only changed the seatbelt chime.
  19. #379
    Sep 25 2019
    Uk
    Hi
    Does anyone know the coding for VAG COM Needles sweep on Audi A4 B7 TDi 2.0 and for Audi A3 2011 8p
    Many thanks
  20. #380
    Sep 28 2007
    @Nipperdog - needle sweep functionality doesn't exist for the B7; think it's B8 and newer only.
  21. #381
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Yeah no needle sweep on these.
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  22. #382
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Does anyone know if it’s possible to turn off the rain sensor and just have regular intermittent wipers with VCDS?
    It doesn’t matter what time of day, how clean my windshield is or how hard it’s raining. My auto wipers come on whenever they feel like it and it’s been that way since I’ve owned it. It was real close to punching my rear view today. 🤣🤣
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
  23. #383
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Can't stand this 'feature' either.
    Pretty sure VCDS coding is not an option, but you might be able to minimize or find a work around. Perhaps looking into disabling / covering the rain sensor gel pad... maybe vinyl wrap or something?
    https://www.audizine.com/forum/showt...t-wiping-delay
    Quote Originally Posted by EvolutionArmory View Post
  24. #384
    Jun 27 2011
    You could replace the gel pad. I did that a while back and it helped reduce the random wiper behavior. It didn’t fix it completely though.
    What did fix it was getting my windshield replaced. Mine had tons of putting and acid damage (or something) that played havoc with that sensor. Ever since I got a new piece of glass the sensor has worked perfectly. My insurance covers replacement for the deductible as long as you have a crack longer than 6” (which I did) so it was low cost to me.
    But I do believe there is a way to toggle between rain sensing and basic delay-based wiping. My b6 had the same stalk but was delay based (B6s never had rain sensing).
    -CP
    2017 Q7 3.0t
  25. #385
    Aug 19 2005
    07 A4 Avant S-line 6MT
    CNY
    My rain sensing wipers only operate when in the on position... Maybe move the wiper arm?
    '21 SQ5 Ultra Blue
    past: B7 Avant 2.0t S-line Manual [CTS K04, 034 K04 Tune, Golf R intake cam, CTS HFC, Stasis Exhaust, BFI Snub, 034 Street Mounts, Apikol Race Diff Mount, Hotchkis 29mm RSB]
  26. #386
    May 20 2017
    New Hampshire
    Quote Originally Posted by boostin20v View Post
    What?
  27. #387
    May 20 2017
    New Hampshire
    B8’s can toggle between rain sensing and standard type intermittent modes through MMI. As far as I know there’s no end user way to toggle for us. I was hoping there was VCDS coding but it looks like I’m SOL.
  28. #388
    Aug 19 2005
    CNY
    The arm has to be one position up, and the little flip switch on the top of the arm all the way to one side for my sensor to take effect. If the small such isn't in that position the interval is timed regardless of the sensor.
    '21 SQ5 Ultra Blue
  29. #389
    Jun 27 2011
    What switch are you talking about? There are 4 stalk settings:
    Fast
    Slow
    Auto/Rain-Sensing
    Off
    Momentary wipe
    The small dial has 3 positions to control the rain sensing sensitivity. There is no switch on top.
    My b6 was identical, except it had “dumb” delay-based wiping instead of the rain sensing position and the dial controlled the delay timer.
    EA: have you looked though? it might not be a simple coding change but at the very least the electronics are going to have some sort of provision for a fallback setting when the rain sensor is disconnected or malfunctioning (or simply not equipped as would be common in Europe). I would be shocked if there’s not a way to code it back to delay based.
    -CP
    2017 Q7 3.0t
  30. #390
    Aug 19 2005
    CNY
    Dial, switch, what ever. Maybe it is the quality of glass, my windshield isn't that old and I've no issues with the sensor.
    '21 SQ5 Ultra Blue
  31. #391
    Jun 27 2011
    The glass clarity makes a big difference. My glass was in VERY poor shape. It had this awful acid rain etching (or something) that made even brand new wipers smear, it was like really bad water spots that wouldn’t come out. And the pitting was so bad it seemed like the previous owner used the car as a rally car on gravel stages only. I tried glass polish treatments, Nano-coatings, etc, but nothing really helped that much. A new gel pad helped quite a bit but it still wasn’t nearly as accurate as my q5 and had its occasional periods where it would wipe super slow in a downpour or hyper-fast when it wasn’t even raining. New glass (and presumably another new gel pad) and it basically works perfectly now.
    Though I’ll admit the only reason I got new glass was because I got a huge rock chip on a euro drive 2 years back and the resulting crack was huge and spreading all the way across the windshield by the next week so I just bit the bullet. Up until then I’d just sorta resigned myself to them being sorta wonky rain sensors. I wasn’t expecting the new glass to solve that issue but evidently it did.
    As with nearly every fucking thing that is wrong with my car, it was like that when I bought it and 100% due to the previous owner being a fucking baboon.
    -CP
    2017 Q7 3.0t
  32. #392
    Jun 27 2011
    Also, you can just unplug the rain sensor. It’s pretty simple to access, just pull the rear view mirror and it’s under there.
    -CP
    2017 Q7 3.0t
  33. #393
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Windows up and down mod wont work.
    It was working 3 months ago when I bought the car.
    2007 rs4
    Can someone please help me out
    I've entered 11884 just like the vg com walk through state.
    And I've tried 11886
    Made the mistake of not writing down the old code
    my adaptation is at 95
    I'm using OBDeleven by the way.
    I've done this mod on 5 other Audi's so I'm at a lost here.
    Sent from my SM-G955W using Audizine mobile app
    2007 RS4
    2000 B5 S4 stage 3
  34. #394
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    2007 RS4
    2000 B5 S4 stage 3
  35. #395
    Apr 30 2017
    2006 A4 Avant with tune, 1976 Ford (Mercury) Capri II, 1990 Vw Vanagon & a 2007 Toyo Sequoia
    Amherst NH USA
    HI bck in the first few post KRISTOKES mentioned the following
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###XY, where:
    X = DRL
    0 – Halogen without DRL
    1 – Halogen with DRL
    2 – Bi-Xenon with DRL
    3 – Bi-Xenon without DRL
    4 – Bi-Xenon with DRL / tail light / license plate light
    Can someone explain 4 over 2.
    Thanks
  36. #396
    Established Member Two Rings Br4nd3n's Avatar
    Feb 08 2018
    Montgomery NY
    Maybe 4 is keeping the license plate light on and the rear brake running lights on as a DRL? You could try both and test.
  37. #397
    Sep 28 2007
    @nij_tp - Option 4 is more like the B6 behaviour except not using foglights
    • front halogen bulbs are DRL (ones towards middle of car), city light is OFF
    • rear tail lights are always on, brake light portion glows brighter when brakes are applied
    • headlights on, DRL is OFF, city light is ON
    Option 2
    • front halogen bulbs are DRL, city light (small bulb) is OFF
    Option 3 - no DRL
