No. On top of the sensor putting out a different voltage, the sensor itself is turned 90 degrees.
99.5 QM, 2.0 stroker EFR 6758 e85 at 7 bar, 413 Bosch fuel pump in 034 Surge tank. Miltek 2.75, CM 240mm fx400 x 6, koni CO's, Stoptech BB, stealth V8maf in stock airbox, VVT upgrade,
Concept, build and tune by Quattro motorsport
98 Passat Var,2L,IE/JE,ARP,034,SPA,50tr,3tbe,FX400,BigREDs,Uni440,Fuel ab,Sterns,Mocal,Bils,JHM
LINKS:2L Build,Further PerformanceHausOfHarnessD2 S8 40vQM
J.E. 9.25:1 coated sides and top
Manley H beam rods
Coated mains and rod bearings
Blueprinted
Rest is TBD
Manley H beam rods
Blueprinted
Rest is TBD
Manley H beam rods
Blueprinted
Rest is TBD
Manley H beam rods
Blueprinted
Rest is TBD
If you can read this thank a teacher, since its English thank a veteran...
Audi make a great car, but their heater cores are, well $h!t.....
Manley H beam rods
Blueprinted
Rest is TBD
99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
Next up E85, efr 7163 or gtx3071r?
01 allroad 2.7t 6mt, GIAC stage 1
Manley H beam rods
Blueprinted
Rest is TBD
