Results 1 to 10 of 10
Thread: Turning off DRL
    Senior Member Three Rings Speedybrit's Avatar
    Apr 15 2010
    Turning off DRL
    I am trying to turn off the halogen DRL lights. I am currently running both my fogs and original DRL as my DRL setup but i have yellow fogs so they look stupid with two different colors. I have tried every single option in vag com, byte 03 in 09 cent. elec, that i can think of and have not been able to turn off the original DRL while just having the fogs on. Can someone point me in the right direction. I have searched on the forums but havent been able to find what i am looking for.
    Current Cars:
    2016 Sepang Blue S3 - Tech Pkg, Black Optics, B&O - Eurodyne Stage 2 ECU/TCU (Crackle Tune), Resonator Delete, CTS Intake, CTS Turbo Muffler Delete, CTS Turbo Inlet, USP Downpipe, APR Roll-Control Springs, APR Rear Sway Bar, and PowerStop Z23 Brake Kit
    Past Cars:
    2013 Monsoon Gray B8.5 A4 Prem+ 6MT
    2010 Meteor Gray B8 A4 premium 6MT
    2008 Subaru Legacy
    Oct 27 2009
    Miami, FL | Boone, NC
    I assume you know that you can turn them off in the car menu. However, because you want to run just the fogs, you are probably using the parking light setting which turns them back on at the dim setting.
    IIRC, byte 2 controls what constitutes a DRL. However, with the halogen lights, this is already set to 00... With the LEDs, it is set to 10.
    If there isn't an option to disable them as a DRL, you can set the dimmed DRL adaptation value to 0. You will have an error, but they will be off.
    [09 – Cent. Elect.]
[Security Access - 16] (enter security code. One of the default codes is- 20113)
[Adaptation - 10] -> Channel 3
Enter new value for LED brightness i.e. "100" If you want LED's at 100%.
Values bellow 5 turns the LED's off and generates an error code and warning in DIS .
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Apr 15 2010
    I know about the option of turning them off in the car menu, but i am not using the parking light setting. I have my lights set at off. If there is no other way of turning them off i will just live with it instead of having an error show up all the time
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
    Active Member One Ring Siggs's Avatar
    Jul 19 2010
    Westchester, NY
    So it looks like this thread has been dead a while, but maybe you've found a solution to this? I got my DRLs and Fogs to work together (sounds like you did too) but I want to turn off the DRLs and just leave the fogs. Any luck?
    Apr 15 2010
    Quote Originally Posted by Siggs View Post
    Sorry for the later response. No I never did find a solution for it and I don't have the car anymore to try and play with it again.
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
    Jul 19 2010
    Westchester, NY
    Gotcha. Thanks for responding!
    Aug 28 2012
    sydney
    I'm interested to know how can we disable the DRL. I just want them off all time.
    Sep 04 2013
    KTM 690 Duke, Ski-doo Freeride 800
    Norway
    I am sort of having the same problem right now, but i want to use the front turn signals as parking lights. I have been able to activate the turn signals as parking lights, but the drl is still on.
    [IMG][/IMG]
    Senior Member Three Rings DJ_AudiA4's Avatar
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    I'm thinking of just cutting the wire for the DRL. I have chosen to do a custom projector headlight retrofit and led stripping inside my halogen headlight. I know I'll have a warning light all the time so my other option is to take the wires and ground them out as to make the sensor think it's working.
    09 A4 6MT Quattro Frankenturbo, Eurodyne Tune,K&N intake , SPM TP, AWE catback, CTS FMIC, ST Coilovers, Roc-Euro STS, 034 Transmount, Apikol bushing, GFB DV+, H&R sway bars, AWE boost gauge, VMR 701's 19x9.5, RS4 grille and fog light housings.
    289HP @ 6100| | 297ft lb @3900
    Senior Member Three Rings Vendetta44's Avatar
    Feb 27 2014
    2016 Jeep Grand Cherokee. 5.7L Hemi
    Sarasota, Flo
    This thread is dead but i have the opposite problem. I have i have disabled my Drl's all together and have no idea how i did. Want them back on. They do not come on no matter the selection
