Results 1 to 24 of 24
    Established Member Two Rings fcp4life's Avatar
    Dec 04 2010
    Massachusetts
    Dropping K&N Cold Air Intake into my 2002 1.8T Quattro A4
    I am thinking about buying this intake kit, along with it i will also purchase a heat shield is this a good buy? will i notice any difference in throttle response?
    http://cgi.ebay.com/K-N-Cold-Air-Int...item27b8a00369 w
    Senior Member Three Rings ggcrash's Avatar
    Nov 25 2008
    Orlando, Fl.
    I just can't help it , but I have to ask...Why are you doing that? The factory setup, has proven to be very efficient...
    Nov 25 2008
    Orlando, Fl.
    No, you won't feel anything. However your wallet dyno will say, "whoa dude" did you feel that? I felt that, where is that dude in the prius at now?
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    K&N and Carbonio Cold Air Intake don't help you, some have reported a loss in performance; like ING Direct says: "save your money".
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Three Rings MYFASTA4's Avatar
    Sep 03 2009
    C7 A6, A4 B7 AVANT, B8 ALLROAD & BOX-SPYDER
    Florida
    at the end of the day it's just an air filter dont expect to feel a big difference, the biggest difference with me it's the smoothness ! , less hesitation, the car its more enjoyable to drive ;-)
    2014 S4 6MT, B&T, sport dif., MMI+
    2015 A3 8V
    2001 TT MK1-225
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    on the A4 turbo , these things usually turn out to me more of a hot air intake because of the ambient heat. AEF makes a really great flowing dry filter that fits in the stock box, and that maybe a better option.
    Established Member Two Rings Nikovic's Avatar
    Jun 01 2011
    2012 Volkswagen Golf
    Toronto,Ontario
    So since everyone is saying K&N and Carbinio arent effective. In everyones opinions which intake provides the most performance with great sound? (Besides OEM)
    NIKOVIC
    Deactivated Two Rings
    Jul 12 2010
    MONTREAL
    Carbonia sure looks good..but that's about it! lol
    Stock is the perfect setup
    Veteran Member Four Rings CleanA4's Avatar
    Jun 23 2009
    B5 s4, 06 gsxr, lawnmower
    Chicago
    If you want to get that intake sound just buy a cone filter and put it on your Maf. That should keep you happy and save you $100.
    2001.5 S4 -GIAC stage 1, SSAC TWIN ll, OZ Superleggera
    2006 gsxr 600
    2004 USP- sold
    Lawnmower
    NEED A FENDER ROLLER? OR FENDERS ROLLED?-PM ME
    -Admir
    Dec 04 2010
    Massachusetts
    so the best thing to do is put a cone filter, and make a heatshield?
    Veteran Member Four Rings Saracen's Avatar
    Apr 25 2009
    PNW
    K&N panel filter, done.
    "A car can be a tool but it can also be so much more. It can be a heart-starter, it can be a drug, it can be a piece of art and it can stir your soul" -Clarkson
    "It's like being an ass man but there aren't any nice asses around so you go find a fat chick b/c at least she has something to hold on to. It's not the same and you just don't do it. #avantsforlife" -02silverbullet
    Veteran Member Three Rings CamrideA4's Avatar
    Jan 05 2011
    Raleigh, NC
    Quote Originally Posted by fcp4life View Post
    Thats what I did. The stock airbox works great but it's huge and (IMO) a PITA. There is no reason to spend money on a setup like the ones in the OP except for looks.
    Sent from my DROIDX
    2001.5 A4 1.8TQ Tiptronic - FrankenTurbo F4 - 440cc Green Giants - TT225 MAF - Borla exhaust - ST Coilovers - Malone Tuning - Garrett FMIC
    Dec 04 2010
    Massachusetts
    I feel ya, it looks like a fun DIY, for this weekend here is my Stock Setup
    What i find is that i remove the whole housing and connect the cone to the black hose that has the clamp on it, is it that easy? or am i missing something like where all the sensor wires go?
    Dec 04 2010
    Massachusetts
    will this break anything on my car?
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Yes. Possibly everything.
    CEO and General Manager of the AZ Pedal Responce Team
    Established Member Two Rings Scubasteeve's Avatar
    Aug 28 2009
    Audi A4
    Mnneapolis
    OKay, I will explain turbocharged car basics here:
    The reason your "turbo" gives your engine more power is because the air is PRESSURIZED (aka, more air to blow up/combust therefore more power), and very DENSE. Cold air is dense. Hot air isn't as dense. There are two simple equations for this actually! (PV=nRT, Q=mCdeltaT)
    Believe it or not, the audi engineers made sure the air going into the engine was as COLD as possible. That is why it is intaking air from an external system (atmosphere, not a hot engine bay) and then subsequently combusting it and throwing it back out through the exhaust pipes. It is the most efficient way of combusting the air fuel mixture! K&N "cold air intake" i guarantee will intake hotter air than the stock setup. The only reason to use an intake like that is if your are space restricted (aka very big turbo.)
    Edit: I lied, actually you'll probably use enthalpy to calculate the difference in PE between a cold air intake and hot air intake.
    dU = TdS − pdV
    Yay partial derivatives!
    I are an engineer. I like make cars. i speak to english good. engineer don't need to good be talk. because race car.
    Dec 04 2010
    Massachusetts
    so i should just leave it as is then... and just drop a normal k&n filter, any other cheap options to increase some throttle response
    Established Member Two Rings Snooter's Avatar
    Oct 05 2010
    Farmington, CT
    Why not just get yourself a tune? I'm assuming you are completely stock, and as such a tune is one of the best ways to gain some power. Search around to find out what dealers are in your area, think about where you want to go with your car (aka how much performance to you want in the long run), and make a decision from there. You can pick up some injectors fairly "cheap" in the classifieds usually as well, but you want to pair them to a tune. Example APR 1+ and i think 2+ uses TT225 injectors.
    Established Member Two Rings A4b61.8t's Avatar
    Mar 30 2011
    poole dorset england
    Yes, you will go from 0 to a numpty in 3 seconds!! Also top speed will raise to 1000,000 mph lol;) Keep your stock air box, put a K&N panel filter in job done!! Spend your hard earned cash on something useful! (manifold, bigger injectors, big turbo, fmic you get the picture waste of money.
    Sorry didn't realise if your not already!! Go stage 1, 1+ ect you will feel night and day differences;) good luck!!
    Established Member Two Rings Bimpfin's Avatar
    Jun 01 2011
    '04 a4 1.8tQ, '69 Charger R/T hemi 440 (restoring)
    Morehead, KY
    listen... you are always going to have hundreds of people on this site with different opinions.. this airbox/intake imo has been the most repetitive.. whether you use the factory air box, cone filter clamped to TIP, or aftermarket CAI, after a few hard pulls in the blistering summer heat, you will suffer somewhat of a loss due to heatsoak... you should mod the way u want to mod not the way everyone tells you.. ive switched my set up from airbox to cone filter a dozen times.. not much of a difference honestly besides sound.. the cone filter allows you to hear the turbo spool a bit more thats it.. you however will want to fab u up a heat shield with the cone and place it in between turbo/cat and air filter whatever you do... it gets hot as fuck.. cone filters cost you like 50 bucks for a good one (AEM, K&N, etc). get one if you dont like it stick the airbox back in.. very easy DIY.. goodluck
    as for what buddy said above me, yes get a tune you will be much happier with ur ride
    Sep 11 2009
    Usa
    Quote Originally Posted by Bimpfin View Post
    x2
    Dec 19 2007
    York, PA
    ninja edited posts?
    Jun 11 2012
    ocala fl
    what would be considered going stage one?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    lol
    2019 SQ5 Prestige
