Originally Posted by
Dynamite
I have seen a couple people on here upgrading their rear brakes with the A8 rear carrier to take the b5 s4 rear caliper. Is there any reason why the A8 caliper couldn't be used or why the s4 one is better? Also do both of them have the assembly to keep the handbrake on the same caliper like stock?
Both the A8 and S4 rear brakes are vented 22mm wide discs, versus the unvented far thinner A4 rotors. This is the primary reason to upgrade, and requires the S4 calipers. I do not know if the A8 utilize the same e-Brake, but the S4 calipers do.
The more popular upgrade is to now use B7 S4 300mm rear rotors instead of the 278mm of the A8. They are the same 22mm wide, but a full 2" larger then the stock, and about 20mm larger then the A8.
We sell these as a kit with or without calipers, although you can source used calipers for cheaper. We only offer brand new calipers with the kit. You keep all the factory e-brake system with the S4 calipers. I can't confirm the A8 calipers.
Our kit with Brand New calipers:
http://www.034motorsport.com/chassis...mm-p-1170.html
Minus $980 from the price if you source your own calipers. We also offer the brackets themselves for $75.
PS. Stainless brake lines with a banjo ARE required do the caliper position; stock lines (steel or rubber) will not work.
