    Active Member Two Rings a5e4n's Avatar
    Jul 30 2011
    2000 Audi A4 1.8tqm FT'd
    Timbuktu
    H7 to D2S conversion
    I have a 2000 a4 1.8 that comes with a one piece headlight. I know they are projectors but I wasn't sure if they were HIDs or not so I took out the bulb and found they are halogen H7s. I want to get a black headlight housing and upgrade to HIDs but the one that I am looking at says it's compatible with stock b2s bulbs and stock ballasts...since I obviously don't have those can I still buy the headlights and get a conversion kit for the bulbs? Or should I look for h7 HID headlights?
    Jul 30 2011
    Timbuktu
    Stock d2s bulbs...sorry.
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    You will need to buy an aftermarket d2s HID kit. The d2s projectors have little fingers that hold the bulbs in along with the clip. h7's dont have the same projectors.
    I use DDM 55 watt d2s setup with 5k in place of my stock d2s ballasts/bulbs that went back on me.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Jul 30 2011
    Timbuktu
    Yeah from everything I've read my understanding is if you have h7 headlights then you need to get an h7 kit...although they do make h7 to d2s adapters that basically act as a spacer (I think) that will allow you to use a d2s set up in a halogen housing so that the bulb doesn't get too close to the projector housing. But why bother when they make h7 hid kits. Now if I do end up getting the headlights that are made for the oem d2s set up then that's another story like you said...
    Jul 30 2011
    Timbuktu
    Ok so I found out more answers. I was told by a hid kit manufacturer that inorder to equip aftermarket d2s headlights on a halogen b5 that I will need to get d2s ballast and bulbs but with h7 wiring. So they're custom making it for me :) why isn't a conversion kit like this available? I've read a few posts here at AZ with ppl complaining about retards who put HIDs in halogen projectors because they're not meant for them...so in case you are wondering this is why I am making the effort to get new headlights that are specifically made for d2s....
