For the discussion, here are the 7 kits FCP Groton offers:
1. Audi S4 Control Arm Suspension Kit 1998-2003 (Meyle 13 piece kit) $575
Upgrade your Audi S4 suspension today with a new Audi suspension kit! Your Audi suspension system plays a critical role connecting your vehicle to the road. Upgrade your Audi S4 front-end with a new Audi S4 suspension kit. Keep reading for more details.
The four-link front suspension in the above vehicles has been highly praised by the experts for its dynamic driving properties. This does not quite tie in with the recall campaign in spring 2004 which affected approximately 870,000 Audi and Audi vehicles.
TIf your hear a squeaking noise coming from the front end when braking, you may need to update your Audi S4 control arms with a new Audi S4 suspension kit. Find more great deals on replacement Audi S4 parts here at FCP Groton!
*Note: Audi S4 Control Arm Suspension Kit.
This Kit includes the following items:
1. Front Right Upper Front Position Control Arm Updated
2. Front Left Upper Front Position Control Arm Updated
3. Front Right Upper Rear Position Control Arm Updated
4. Front Left Upper Rear Position Control Arm Updated
5. Left Updated Sway Bar Link with Bolts and Hardware
6. Right Updated Sway Bar Link with Bolts and Hardware
7. Front Left Lower Front Position Control Arm
8. Front Right Lower Front Position Control Arm
9. Front Left Lower Rear Position Control Arm
10. Front Right Lower Rear Position Control Arm
11. Front Left Outer Tie Rod Full Metal Version
12. Front Right Outer Tie Rod Full Metal Version
13. Control Arm Hardware Kit
Fits the following models:
Audi A4 1996-2003
Audi A4 Quattro 1996-2003
Audi A6 1996-2003
Audi A6 Quattro 1996-2003
Volkswagen Passat 1998-2003
Volkswagen Passat 4 Motion 1999-2003
Manufacturer Meyle
FCP Reference Number 8D0498998S1
OEM Number 8D0498998S1
Our Price $575.00
2. Audi S4 MEYLE Control Arm Suspension Kit (2000-2002) (Meyle 11 piece kit) $514.95
Audi A4 A6 VW Passat Control Arms
The quality of your Audi or VW driving experience is directly related to the condition of your steering and suspension systems. At the core of both of these systems is your vehicle's control arms. Upgrade worn-out tired control arms with top-quality brand-new Meyle-manufactured control arm replacements. Feel the difference in your drive today. Keep reading for further details about your new control arm kit.
ALL PARTS ARE MANUFACTURED BY MEYLE
With the new seal, MEYLE is accenting the quality of its products and guaranteeing the package contains an original MEYLE part.
WE GUARANTEE ALL PARTS ARE GENUINE MEYLE
MEYLE Quality, Right Down to the Seal
Genuine Meyle HEAVY DUTY Front Control Arm Repair Kit 11 Piece Kit
Auction is for the following items:
Manufacturer Meyle
FCP Reference Number 8D0498998B
OEM Number 8D0498998B
3. Audi S4 Control Arm Suspension Kit (2000) 13 piece Aftermarket kit $379.99
Audi S4 Front Upper Control Arm Kit
Upgrade your Audi S4 suspension today with a new Audi S4 suspension kit! Your Audi suspension system plays a critical role connecting your vehicle to the road. Upgrade your Audi S4 front-end with a new Audi S4 suspension kit. Keep reading for more details.
*Note: Audi S4 Front Upper Control Arm (Forward or Front position of vehicle). **Includes Left and Right control arms.
This Kit includes the following:
5. Left updated sway bar link with bolts and hardware
6. Right updated sway bar link with bolts and hardware
13. Control Arm Bolt Kit
Audi A6 2002-2004 V6 4.2L
Audi A6 Quattro 2002-2004 V6 2.7 / 3.0L
Audi S4 Quattro 2000 V6 2.7
VW Passat 2003-2005 L4 1.8L
VW Passat 2003-2005 V6 2.8L
VW Passat 4 Motion 2003-2005 V6 2.8L
VW Passat 4 Motion 2003-2005 V8 4L
Manufacturer Aftermarket
FCP Reference Number 4D0498998M
4. Audi S4 Control Arm Suspension Kit 13 Piece S4 Upgrade $319.99
Audi Volkswagen Control Arms Suspension Upgrade Kit
Your car is a fine driving machine, so why not treat it that way? The way your Volkswagen or Audi handles on the road is going to define your experience with the vehicle. Replace tired and worn-out suspension parts with new replacements. This is a simple yet comprehensive solution to increase your vehicle's on-road handling and performance. Feel the difference in your drive today. Keep reading for more information about your new suspension upgrade kit.
The Kit includes the following items:
Front Right Upper Front Position Control Arm S4 RS6 (came stock on S4 and RS6 Models but can be used on Audi A4 A6 VW Passat as an upgrade- List $112.55 OEM Reference 8e0407506c)
Front Left Upper Front Position Control Arm S4 (came stock on S4 and RS6 Models but can be used on Audi A4 A6 VW Passat as an upgrade- List $112.55 OEM Reference 8e0407505c)
Front Right Upper Rear Position Control Arm Updated S4 (came stock on S4 and RS6 Models but can be used on Audi A4 A6 VW Passat as an upgrade- List $112.55 OEM Reference 8e0407510c)
Front Left Upper Rear Position Control Arm Updated S4 (came stock on S4 and RS6 Models but can be used on Audi A4 A6 VW Passat as an upgrade- List $112.55 Oem Reference 8e0407509c)
Left Updated sway bar Link With Bolts and hardware (Updated version, prevents excessive noise. Includes 2)M10x62x45mm Bolts /VAG # N104 253 01 & 2)M10 Shouldered Self Locking Nuts VAG# N102 861 02)
Right Updated Sway Bar Link with bolts and hardware (Updated version, prevents excessive noise. Includes 2)M10x62x45mm Bolts /VAG # N104 253 01 & 2)M10 Shouldered Self Locking Nuts VAG# N102 861 02)
Front Left Lower Front Position Control Arm (Heavy duty version manufactured with thicker aluminum base and heavy duty ball joint)
Front Right Lower Front Position Control Arm (Heavy duty version manufactured with thicker aluminum base and heavy duty ball joint)
Front Left Lower Rear Position Control Arm (stock OE Version)
Front Right Lower Rear Position Control Arm (stock OE Version)
Front Left Outer Tie Rod (hd version with rubber dampner in shaft)
Front Right Outer Tie Rod ( hd version with rubber dampner in shaft)
Control arm bolt kit (complete set of mounting and installation hardware that includes cinch bolts and self locking shoulder nuts, and much more-manufactured by FEBI-Bilstein)
1 Year full warranty on all parts
* Resilient Bushing material for Improved steering input,
handling and durability.
* Improved rubber dust boot material. Prevents cracking
and exposure of ball joint.
* Better moly grease, Less wear, More Miles!
* Exclusive German Design!
IMPROVED Front Sway Bar Links
* New heavy Duty Hemi Joint replaces ball joint end.
Audi A4 1.8, 2.8 1996-2001
Audi A4 Quattro 1.8, 2.8 1996-2001
Audi A6 2.7, 3.0, 4.2 1998-2002 with 15†or 16†rims
Audi A6 Quattro 2.7, 3.0, 4.2 1998-2002 with 15†or 16†rims
Audi S4 2000-2002 only after production date 11/1999
Volkswagen Passat 1.8 Liter and 2.8 Liter 1998-6/2002
EXCEEDS OEM SPECIFICATIONS
Condition New
5. Audi S4 (2000-2002) Control Arm Suspension Repair Kit 12 piece Aftermarket $310.00
Audi A4 A6 Volkswagen Passat Control Arm Kit Upgrade
The condition of your Audi or Volkswagen steering and suspension systems directly relates to how your vehicle will handle on the road. Do you want more responsiveness and tighter control around corners? Upgrade your Audi or VW with a new control arms kit and start driving the way should. Keep reading for more details on the kit.
This is an S4 UPGRADE.
The Kit includes the following items: Front Right Upper Front Position Control Arm S4 RS6 (came stock on S4 and RS6 Models but can be used on Audi A4 A6 VW Passat as an upgrade- List $112.55 OEM Reference 8e0407506c)
Retail Price $1,916.70
Audi A6 2.7, 3.0, 4.2 1998-2002 with 15 or 16 rims
Audi A6 Quattro 2.7, 3.0, 4.2 1998-2002 with 15 or 16 rims
Additional Notes:
FCP Groton now offers a Lifetime Warranty on all of its products. Please visit FCP Lifetime Warranty for more info. All of our parts meet and or exceed the rigorous standards set forth by the vehicle manufacturers. Looking for the equivalent OEM product or particular brand you don't see listed here? Email us for a quote.
Condition New
6. Audi S4 (2000-2002) Control Arm Suspension Kit 13 piece Aftermarket $309.99
Audi A4 A6 Volkswagen Passat Control Arm Kit Upgrade (13 Piece)
Improve the front-end performance of your Audi or VW with this brand-new 13 piece kit. The quality and condition of your steering and suspension system defines what your on-road experience will be like. Upgrade and rebuild your front-end today. Keep reading for kit details.
The Kit includes the following items: Front Right Upper Front Position Control Arm Updated (original units are straight- our updated design has a bend for added strength)
Front Left Upper Front Position Control Arm Updated (original units are straight- our updated design has a bend for added strength)
Front Right Upper Rear Position Control Arm Updated (original units are straight- our updated design has a bend for added strength)
Front Left Upper Rear Position Control Arm Updated (original units are straight- our updated design has a bend for added strength)
Additional Notes:
7. Audi S4 Control Arm Kit 2000-2002 (Aftermarket) $275.00
Audi A4 1996-2001 1.8L, 2.8L
Audi A4 Quattro 1996-2001 1.8L, 2.8L
Audi A6 1998-2002 2.7L, 2.8L, 3.0L, 4.2L
Audi A6 Quattro 1998-2002 2.7L, 3.0L, 4.2L
VW Passat 1998-6/2002 1.8L, 2.8L
