Results 1 to 7 of 7
    Jun 14 2011
    cho
    Installing backup camera/ parking sensors on 2010 A5 Prestige?
    Is this expensive, and would it wreck the car?
    Thanks
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Since you're new here I'll be nice and post the results of the search I just did:
    http://www.audizine.com/forum/search...archid=1208834
    Short answer: yes/no
    Tschόί!
    Πave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hόper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/άSS • Hankook V12's • ST-40 BBK
    Senior Member Three Rings ms3008's Avatar
    Mar 05 2010
    Retrofitting OEM parking sensors will be more expensive than the aftermarket ones but it is worth every penny. The sensors are flush with the bumper and does not protrude like the aftermarket sensors and it is fully integrated within the MMI.
    I just finished fitting the rear parking sensors and if you don't mind doing the wiring by yourself, then it would be cheaper. Also, if you don't want to drill holes in your existing bumper, you are looking at a new bumper, 4xsensors, control module, sensor harness, central electric harness, buzzer, 1 control module bracket to hold the control module and a whole lot of time.
    There are some parts which you can source from ebay and that will save you a LOT of money.
    I can help with the rear sensor retrofit if you need any. As for the backup camera, maybe someone else can chime in. But as far as I know, it's not going to be cheap.
    SOLD - 2011 Brilliant Black TD1 A5, Light Grey Interior
    OEM Carbon Atlas Inlays • 30% ceramic tint • Facelift flat-bottom S5 steering wheel + Pedals • S5 grille + side mirrors • APS+ retrofit • S-line exterior upgrade • LED license plate lights • APR Stg I • Ecodes • Power folding mirrors • Advanced Key
    Mar 05 2010
    Also, there is an aftermarket parking sensor set that Audi offers as part of their genuine accessories. Be aware that this is different from the factory installed system and will mostly likely be cheaper but I think the sensors do not line up flush with the bumper.
    Jun 14 2011
    cho
    argh, maybe I should just avoid the rear backup camera altogether since it sounds like so much work. I bought a 2010 A5 Prestige and the seller mistakenly advertised there as being backup camera but I found out on Google later that backup camera doesn't exist on this model. Stupid Audi decided to mix and match such that even the Prestige trim didn't have all the bells and whistles
    Junior Member Two Rings
    Mar 31 2011
    denver
    Quote Originally Posted by jayk View Post
    TOTALLY agree with you here.
    i have an s4 that the seller did the same thing to me; now im looking to get the backup camera installed at least.
    (i have mmi 3g, b+o, and NAV)
    not sure why, but its a PITA to back this thing up.
    Jun 14 2011
    cho
    Quote Originally Posted by soundsubs View Post
    but how are you installing the backup camera? Won't it cost a lot of $? Are you getting a simple OEM installation? (do they look ugly on the car?)
