Results 1 to 40 of 49
    Veteran Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens
    Question Intercooler fan?
    Ok so I had an idea, let me know if I'm being stupid .
    I was thinking of putting a fan on my oem side mount intercoolers. Something like a radiator fan such as This on the back of the intercoolers as puller fans.
    ok so my logic is most of the time we are driving at low speeds where there is not sufficient cooling from air flowing over them the fans should be capable of this and at higher speeds the natural flow of air should take over.
    I know i should just get a front mount but thats not in the budget for now.
    -Theo
    2018 S4,Florett Silver, Magma
    2014 Q5, Phantom Black Pearl, Chestnut, 2.0T,Moms Ride
    2015 S4, Daytona Gray, DSG,Gone
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic.
    Oct 14 2009
    Okinawa Japan
    There might be more electrical draw than they are worth. But any help is good help
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Admittedly not a bad idea, drawing air in it would provide more coolong to the intercooler
    I guess at thr end of the day it would come down to total cost
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Senior Member Three Rings dirtyb5a4's Avatar
    Jan 02 2010
    99.5 1.8t 5spd quattro(rolled) 97 1.8t 5spd quattro
    lowcountry, sc
    I don't see it using more juice than some of these rediculous audio systems people install
    RIP 99.5 1.8t quattro, test pipe, full 2.5 exhaust, 17" rs4 reps, forge splitter DV, drilled and slotted rotors, redstuff pads, and finally running GIAC
    NOW- 97 b5 a4 1.8t quattro, 17" rs reps, and forge splitter, test pipe and 2.5in straightpipe with no muffler and now with clear corners, clear smoked side marker lights, and facelift tail lights.
    the gf- your breaking up with me over a car??
    me- yes i like it more
    Co-owner and automotive tech at Flying Wrenches Automotive
    Veteran Member Three Rings jayphil82's Avatar
    Apr 05 2008
    Quebec, Canada
    Those fans would restrict the already poor air flow our stock ICs get at hight speed.... I would not loose my time doing so.
    2006 DG Audi B7 A4 2.0T 6spd
    • Performance: APR Stg2+ 93oct using 94oct gas / AFE Dry Filter/ 034 HFC/ APR HPFP/ Treadstone TR6 IC / OBX Cat-Back
    • Handling & Braking: Stasis SS Coilover / RS4 Sway / Carbotech Bobcat Pads
    • Look: Drop / 19" VMR V713 / OEM S4 mirror / DDM 6000k bi-xenon
    • Other: Evolution skid plate/ Ross Tech VAGCOM/ Snub Mount
    Oct 14 2009
    Okinawa Japan
    I guess if you are a city driver than this would be a good investment, I would spend my extra dough on a water/meth kit. But this coupled with an intercooler sprayer system could be a lethal combination :-)
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    But honestly if you've got a FMIC than you have two birds in the hand, instead of one in a bush? Idk lol
    I'm trying to say the radiator fan is right there.
    -Shane Drake-
    >DRAKLOREs Build<
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    It would need to go behind the intercoolers drawing air through not worth it though
    Veteran Member Four Rings GarrettReid's Avatar
    Oct 26 2010
    Orlando
    They might draw air through too fast that the air doesn't have time to adequately cool the IC.
    2014 Audi SQ5 Black w/Lava Gray and Magma Red
    SOLD: 2007 Land Rover Range Rover Sport Supercharged Black w/Black
    IG: GarrettReid
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Quote Originally Posted by GarrettReid View Post
    I dont think that is actually possible the faster air is drawn through at the same time you are increasing the volume of air drawn through
    Oct 14 2009
    Okinawa Japan
    ^is that possible? I'm not a physics geek but it reminds me of an old question someone once asked "is it possible to submerge a paper towel in water so fast that it comes out completely dry?" hmmm
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2009
    Okinawa Japan
    Lol at the simultaneous doubt to the possibility of "to much airflow" hehe
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 26 2010
    Orlando
    Quote Originally Posted by martin0079 View Post
    Some teacher mentioned it to me. Could very well be horribly wrong. There's been a lot of teachers that haven't always been right. haha.
    IG: GarrettReid
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Quote Originally Posted by DRAKLORE View Post
    no the paper will always come out wet
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Found it. If you can get it moving fast enough you can to more harm then good but for the application you cant unless your car is hitting mach 1 or the fan can pull air at mach 1 just not gonna happen I could do the calc but I am too tired and dont have all the data. Also finally figured out why I dont like the design of the awe fmic a thin intercooler will be come heatsoaked faster
    Jul 08 2010
    tucson
    danbury
    challenge accepted!
    [CENTER]Scott
    2011 S4
    Jan 02 2010
    lowcountry, sc
    Can't wait to hear results on this one
    Jun 09 2010
    Queens
    ok so I think I have it figured out. I think I'm gonna do one fan on the driver side inter cooler probably just use the one I posted above and wire it into the radiator fan so it kicks in when the radiator fan does. Also should I mount it straight to the inter cooler or build a shroud. the thing about the shroud is that it could restrict air flow at higher speeds. The stock inter cooler dimensions are 8.6"x8.5"x2.6" so I think I'm gonna get an 8 inch fan.
    Im really hopeful this works.It shouldn't be more than $50 to do.
    -Theo
    Oct 14 2009
    Okinawa Japan
    Good luck, don't be a bum, and keep us posted! Do u have vaccine where u can monitor your temps pre fan and then get a comparison after?
    -Shane Drake-
    >DRAKLOREs Build<
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    I think If this was a good idea someone would have already thought about it. But I'm definitely interested for the results. If their are any...
    Jul 08 2010
    tucson
    danbury
    i think the fan is going to deliver less then stellar results honestly, the idea is good in concept, but i think for a similar price, you could rig a system that could spray water onto your IC to better cool it down (think 2005 subajew STI) i know that for serious BT applications, like the some of the unitronic show cars they even have a CO2 nozzle on the IC to cool it down from the outside
    [CENTER]Scott
    2011 S4
    Jul 17 2011
    san jose ca
    its not going to make the air any cooler while the car is moving. the only reason the radiator has a fan is when the car is stationary.
    Oct 14 2009
    Okinawa Japan
    I believe OP does a bit of city driving, that is the only place I see this really being beneficial, at speeds above whatever the tiny fan can muster say 20+mph I think the fan would be more of a restriction than anything :-/ I Lena how fast can a fan suck air through the intercooler! Especially an 8" fan... Now someone email Dyson.. And youll see results!
    And another...
    -Shane Drake-
    >DRAKLOREs Build<
    Established Member Two Rings bruddha's Avatar
    Apr 20 2012
    Tulsa/Ok/USA
    so what ended up of this? Thinking of doing a dual 7" fan setup behind SMIC, fins flipped to draw air in.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    The idea is as bad now as it was then 😀
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    hopefully the understanding of some very basic thermodynamics has improved tho
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    plug it to the a/c , just like the s/c from the dodge demon. lol
    May 20 2017
    New Hampshire
    This whole thread can be put to rest with one question. Why does anyone care if their factory intercoolers are being as efficient as they can be when you’re driving around town from stop light to stop light or sitting in rush hour traffic?
    Who cares? The intercooler fan is a solution to a non existent problem. 😀
    Nov 03 2011
    All Over!
    There are better ways to cool the intake air.
    An 8” fan pulling through the intercooler will achieve absolutely nothing, even in city driving. It makes no sense.
    At city driving speeds, the car is unlikely to be making any appreciable boost pressure, so heat soak won’t really be an issue here. On the other hand, at highway speeds, fans behind the intercooler would hurt airflow. They would impede the exit of air produced by ram effect.
    1986 Type 85 Audi 90 quattro
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    An 8” fan pulling through the intercooler will absolutely nothing, even in city driving. It makes no sense.
    They wouldn't hurt airflow if they move fast enough. The real problem is that the air passing through the SMIC has nowhere to go since there's the wheel well behind it.
    A channel that diverts the air from the intercooler area would do more help for free
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Aug 17 2015
    California
    Quote Originally Posted by jayphil82 View Post
    This. The fan could act as a restriction and block airflow at highway speeds.
    This! Water/meth kit is $400 and will drastically cool your intake temps. Great mod for sure.
    This is wrong. The faster the better. However like above, I would be concerned that the fan would block airflow at high vehicle speeds.
    IMO ditch this idea and install a water/meth kit.
    May 20 2017
    New Hampshire
    Water/meth is always the best answer 😀
    Apr 20 2012
    Tulsa/Ok/USA
    Quote Originally Posted by EvolutionArmory View Post
    Water/meth is always the best answer ��
    Water/Meth FTW!
    May 20 2017
    New Hampshire
    Quote Originally Posted by bruddha View Post
    Water/Meth FTW!
    I can’t wait to have the time to install my kit. I’ve had the Devils Own kit sitting in a box for a couple months now. 😞
    Feb 15 2016
    Cambridge,Ontario
    ok for the clueless, what does the water meth kit actually do ? I know its to cool intake air, but how ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 17 2015
    California
    You inject it through a nozzle into the intake air stream (intercooler piping). The nozzle produces a fine mist, and a controller controls the pump's spraying pressure usually based on the MAF signal. More MAF = more spray.
    The water/meth mixture is very easily evaporated. Since evaporation is an endothermic process, it absorbs heat, thus cooling the intake air. Drastically.
    I get sub-ambient intake air temps running stock intercooler and K04 turbo on a 90+ degree sunny day with meth spray.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by A4x View Post
    cool thanks
    1976 Yamaha XS 360
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Thanks, always wondered about that one.
    is it something you need to constantly refill tho?
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
    Aug 17 2015
    California
    Yea, you need a reservoir to hold the fluid. I tapped a hole in the windshield washer tank and it works perfectly, dual purpose now. Standard windshield fluid is 30% meth. I use Snow's boost juice which is 50% meth, so a little harder on the paint but still works well to clean the windshield! I generally try to avoid spraying it if I can tho.
    I could probably get away with using standard blue windshield washer fluid but I am afraid there might be some additives in there that I don't want in my engine.
    BTW I'm doing this to increase my effective octane and run APRs 100 octane file on 93 pump gas. Cooling is a secondary benefit.
    May 20 2017
    New Hampshire
    It’s science and shit.
