Results 1 to 10 of 10
    Veteran Member Three Rings rollaphillie's Avatar
    Jan 12 2009
    B6 A4
    speedometer and odometer not working
    Rpm's are fine, same with the gas and temp gauge. Just the speedometer is stuck at 0 and odometer isn't counting.
    What should I look for? anyone know what fuse I should try replacing? I'm hoping I don't have to replace the whole cluster I know it's expensive.
    Any help is appreciated, tried searching but came up with nothing
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by rollaphillie View Post
    Could be the cluster its self or a speed sensor. Have access to vag com??
    Jason
    Jan 12 2009
    B6 A4
    For those who might search this I replaced the speed sensor and the problem went away
    Veteran Member Three Rings Lornnn's Avatar
    May 01 2011
    Pe
    curious if the odometer started where it left off?
    mine hasn't worked for months and i've put a few miles on it..
    Jun 08 2008
    Calgary AB Canada
    My bet will be that it started where it left of as the computer had no idea how far the car has gone
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Jan 12 2009
    B6 A4
    Quote Originally Posted by onceover View Post
    Nope the odometer went up a few hundred km's after things started working again. I was surprised thought the same as you
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    damn.....there goes my plan of trying to keep low miles
    Please Drive Right
    May 01 2011
    Pe
    do you recall the part number?
    also where is the other end of the sensor in the engine bay?
    Senior Member Two Rings RawrItsCris's Avatar
    Jul 23 2009
    88 Alpine E30, 06 E92 325xi WAGON
    Spanaway WA
    Quote Originally Posted by Pothole View Post
    haha if only there was a mod to keep it stuck!
    db.DirtyBirds
    "Magazine feature in Japanese, of a German car, in America.
    Legit."
    May 04 2010
    Had a SV650 with streetfighter modifications
    Asheville, NC
    When you say you replaced the speed sensor, do you mean the Engine Speed Sensor (by the oil filter) or the ABS sensor behind the front driver's wheel? I'm having a similar problem, but just replaced my Engine Speed Sensor a month ago. The speedometer will go up and down and sort of work sometimes, but be at 0 others.
