Hello all. My 2004 A4 1.8T Quattro recently exhibited some driving issues. The throttle began to have a mind of its own both at idle and when driving, it wouldn't go any faster than 40 mph, the idle would bounce between 800 and 1600 rpm, and the car would shake during idling. Three lights came on: check engine, traction control, and EPC.
I connected my scanner to it and retreived the following codes:
P0638: Throttle Actuator Control Range/Performance (Bank 1)
P0221: Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
P0507: Idle Air Control Systems RPM Higher than Expected
I have been doing a lot of research on various VW and Audi forums and would just like to get some idea for the most likely cause of this problem without throwing parts at it that it doesn't need. From my reading, there are many people with similar symtoms--and hence, a whole slew of different fixes--but unfortunately they rarely post their DTCs, so I don't know if it's exactly the same problem as mine.
It seems to me that it is either the throttle body or the accelerator pedal sensor. (I believe that the last code--P0507--is only a result of the RPM swing at idle and not a separate issue.) I have removed both of them. The throttle body, while it had some oil buildup in it, wasn't overly dirty. I popped the cover off the electrical box and the contacts were very clean. The contacts of the accerlerator pedal were also clean.
So, what do you think: throttle body, accelerator pedal sensor, mass air flow sensor, fuel filter, vacuum lines?
Thanks.
