Results 1 to 9 of 9
    Veteran Member Four Rings AndyLien79's Avatar
    Jul 03 2011
    Fairfax, VA
    2012 a4 6spd manual vs 8spd tiptronic, 0-60
    Hello all,
    the A4 specifications on www.audiusa.com shows that the 2012 A4 as follow:
    Manual Tiptronic® Multitronic®
    0-60 MPH 6.5 sec. 6.3 sec. 7.2 sec.
    How is the 8 speed tiptronic faster? Is it a misprint? just curious :)
    2022 RS3 | Glacier White | Black/Black interior|
    Gone but not forgotten:
    2015 Nogaro Blue S4 P+ |
    IG: frs3sh
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    The new 8 speed tiptronic changes gears very quickly, quicker than previous iterations of the 6 speed tip. Gear changes take 0.2 seconds (per ZF) and match DSG shift times per Audiusa.com for the S Tronic gearbox. Though I miss my 6-speed manual, the new auto gearboxes have gotten much better.
    http://www.zf.com/corporate/en/produ...enjoyment.html
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Jul 03 2011
    Fairfax, VA
    Really? Interesting, I purchased a 2011 with the new 8 speed tiptronic and I thought it stated a 0-60 time of 6.6 seconds vs. the 6.4 with manual.
    I wonder if they misprinted last year? haha
    Quote Originally Posted by gdawg'05a4 View Post
    IG: frs3sh
    Feb 13 2004
    Silicon Valley, CA
    Check the gear ratios of the 8 speed. 1st gear is bigger than the 1st gear on the manual, then it shifts much quicker to second gear which is almost as big as the manual first gear
    Man Tip
    1 3.778 4.714
    2 2.050 3.143
    3 1.321 2.106
    4 0.970 1.667
    5 0.811 1.285
    6 0.692 1.000
    7 xxxx 0.839
    Kevin - Moderator, Audizine
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    I still don't completely understand what Audi did with the 8-speed transmission, because I had a 2011 loaner for 2 days and it did NOT behave like I expected.
    In my 2009 with 6-speed auto, I am turning 2500-2600 RPMs at 80 MPH. So if the first 6 cogs of the new 8-speed are identical to the 6 speed auto unit, then I should still be turning 2500-2600 RPM at 80 MPH when manually holding 6th gear. But that's not what I observed! It was around 3000 RPM. So was there also a corresponding change to the final drive ratio in cars with 8-speeds? Or is the transmission software showing its hand here?
    For the record, I was turning around 2000 RPMs at 80 MPH with the 8-speed.
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    May 03 2005
    Boston
    Gear 6-speed 8-speed
    1st 4.171 4.714
    2nd 2.34 3.143
    3rd 1.521 2.106
    4th 1.143 1.667
    5th 0.867 1.285
    6th 0.691 1.000
    7th ****** 0.8xx
    8th ****** 0.6xx
    Final 3.403 2.848
    It's not identical to the 6-speed 6HP gearbox.
    EPL S2 + TCU
    Previous Cars:
    Aug 27 2008
    Houston Area
    Quote Originally Posted by Stubek View Post
    Man Tip
    1 3.778 4.714
    2 2.050 3.143
    That's only half the story - what is the final drive? You need the product of gear*final drive to compare. Plus I wouldn't trust these numbers (from audiusa.com/a4-sedan/detailed-specifications) farther than you can throw a tip equipped A4 - they only list 7 gears for the tip (is this S-tronic which we can't get in the US in the A4?) - but the final drive is listed as 2.848 which would mean 60 mph would require 3rd gear vs 2nd gear in the 6mt.
    Other numbers I've seen show the new 8 speed using the same ratios as the 6 speed up until 6th and just adding 2 additional higher overdrive gears - but BMWBig6's info above seems to indicate that didn't happen...
    So - bottom line - I wouldn't trust the #'s posted on Audiusa - from my experience they are often inaccurate.
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    May 03 2005
    Boston
    Quote Originally Posted by B8_Jim View Post
    The gear ratios I posted, gears 1-6 are from Audiusa.com which matches ZF's PDF I have on the 8-speed 8HP gearbox. 7th is 0.8xx and 8th is 0.6xx.
    http://www.1point8turbo.com/8HP/8HP.pdf (right-click Save As)
    EPL S2 + TCU
    Previous Cars:
    Aug 27 2008
    Houston Area
    Sorry - I didn't see your #'s. I started my response, got distracted, and didn't finish until after you posted.
    So for the numbers that matter - gear times final drive ratio - the 6MT has about a 4% gearing advantage in 1st, 18% disadvantage in 2nd (3rd is 23% disadvantage). The new tip has to shift to 3rd to get to 60 - but that 18% advantage in 2nd, quick shifts, and perhaps a brake torque launch could be 0.2 sec advantage. (?)
