Results 1 to 9 of 9
    Jun 17 2010
    Long Island, NY
    How to Clean Inside of Fog Light Lens?
    Just had the dealer replace fog lights on my 2010 A4 Prem+ with the HOEN "whiter" color-matched bulbs. Asked them to clean the inside of the fog light lenses at the same time as they are all "fogged-up" and filmy. When I picked up the car the dealer said there was no way of cleaning them. Somehow I believe there must be an easy way of getting to the inside of the lens to clean them. The new bulbs look so much better but the cloudy lenses look horrible.
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Hope you don't blame me for saying, but i hope you had a good reason to let your dealer do the bulb replacement. Because if you can't do that yourself, i'm affraid cleeaning them won't be a job for yourself :p.
    All jokes aside, it is possible.
    Take out the foggrill covers.
    Remove the 3 bolts that hold the fogunit.
    Unplug the power cable of the fog.
    Remove the bulb by turning and pulling it.
    Take some paper tissue on a small stick or something simular and clean the inner side of the lense.
    Might want to leave the foglight unit open and keep it overnight in a hot place so any wet/water can vaporate.
    -> Reverse the above and install them back in.
    I never had fogged-up stock fogs, but maybe you want to put some silicone between the lense and housing. I had to do that aswell with my skoda led fogs. After driving throught a few rainy days the foghouse was nearly 1/4 filled with water . After dissembling it and cleaning it all and kit up the lens-housing, they are now dry and still fully working.
    Good luck.
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    I cleaned it with the method mentioned above.
    I am going to try it from the wheel well liner next time.
    My fog grills will not be able to take another removal.
    I bought led fogs bulbs that are error free and less heat.
    Let's see if that helps with frosting.
    -cW
    2023 X3 M40i Alpine White
    Active Member One Ring Malaka's Avatar
    Mar 27 2010
    Miami, FL
    Hi CW,
    Would you mind posting a link to the LED fogs you purchased?
    Nov 23 2009
    NYC, US
    Is it easy to remove foggrill? If I break it, it maybe a good excuse to get a new foggrill with the fog ring. :D
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by Malaka View Post
    Hi CW,
    I got the one from HID Concepts.
    http://www.audizine.com/forum/showth...?highlight=hid
    I am getting a bulb out on the right fog only when my low beams are on.
    So they are not 100% error free.
    Waiting to hear back from HID Concepts.
    -cW
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    Way too much work mentioned here! I simply dropped the plastic cover underneath the engine - like a skid plate plastic cover thing - 3 bolts on each side and 3 under the splitter. Then you can reach right up into the fog light area, pull the bulb/s out and THEN put some soft cloth material (rip up an old shirt or towel) put that on the end of a small metal stick (so it won't bend) and then push through the bulb opening and clean the lens. It takes some time and effort But I did mine and they look 100% better.
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Yeah, you can do the same through the fender liner method also.
    Forget messing with the fog grilles.
    They are just too easy to break.
    -cW
    Senior Member Three Rings PKaudi's Avatar
    Aug 21 2013
    Canada/ON/Oakville
    -cW
    Reviving this thread!
    Is the cleaning method you mention basically this?
    http://www.audienthusiasts.com/Proje...vinglight.html
    2010 A4 Premium Ibis
    2007 Civic LX Teffeta White - Sold
