Results 1 to 24 of 24
    Veteran Member Two Rings pigpen's Avatar
    Aug 20 2004
    Tie rod end nightmare! DIY = not worth it.
    I posted this on AW, but their picture posting options are lacking... so I'll share my pics here:
    My driver side tie rod end was dead, so I ordered a new one and began working on Saturday. The DIY guides say you simply unscrew it from the 18mm nut. Ok, easy enough. Little did I know, it would take me until Monday night to get it off (not working non stop obviously).
    What a nightmare. Totally not worth DIY unless your B5 has been stored in a climate controled art gallery. Rust sucks. These hints probably apply more to people who live in areas that use tons of salt in the winter...
    Pic 1: notice all the marks? You know I had fun.
    pic 2: you can see how far the pentrating oil got... the chewed up part was where I was turning it by with vice grips and pipe wrenches
    pic 3: DONE.
    So here's what I did:
    1) unbolt everything like the guides say. Don't listen to the guide after getting the tie rod end out of the spindle.
    2) I then cut the thick shaft part off with a grinder for more room. I don't recommend doing this unless you know FOR SURE you can take the rest out.
    3) Soak the crap out of the bolt over night with pentrating oil. I cut a pop can open and filled it with some pentrating oil and let it soak.
    4) wrap everything up in wet rags that can melt and slowly heat the 18mm nut, turning it every 2-3 mins. I used a normal propane torch.
    5) put your 18mm wrench on the nut and grab a small plumbers wrench (vise grip will NOT do) and put all your might into it and hope it starts turning.
    If this fails, give up and call a tow truck.
    Former: 99.5 A4 1.8T, 2001 TT 225
    Current: 2011 S4
    Veteran Member Four Rings marked001's Avatar
    Feb 17 2004
    08 Subaru Impreza WRX; vr
    South Philadelphia
    yeah... just did this a couple weeks ago.. the passengers side (the bad one) came right out...driver's side wouldnt budge.. no room to do anything in there.. plus nowhere to grab since the end just flexes if you grab that..
    F the Jersey Jerks
    Jersey Jerk hata #1
    99.5 t28 A4 ....bye bye.
    www.REVI21ON.com
    Feb 15 2004
    2009 M.B. C300 Sport 6Sp
    T.O. Canada
    I had to change out my inner tie-rod too...b\c the outer one just wouldn't move
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    Congrats on getting that thing out Pigpen, but you may have damaged the socket on the inner tie rod from heating it.
    For future use: after cutting the larger part away from the 'shaft', use a 14mm bolt extractor on a large breaker bar to get it out. Its a pain, but it'll go.
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    What were your symptoms of the bad tie rods? Just curious, I think mine might be going out.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Registered Member Two Rings
    Nov 07 2004
    99 Audi A4 2.8 Tip
    Bay
    i wish i knew how to do taht stuff.. i just paid to get my tie rods replaced
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    When I had my alignment done last weekend at the Audi dealer they found one of my tie rod ends to be bad (ball joint part) and it was seized on there too. Luckily it's still under warranty so it cost me $0.00.
    Really kinda bizare so many people have problems with Audi suspensions...never heard of this many problems on the Japanese cars I've owned.
    Oh well...price you pay for having a German car I guess. No biggie...car more than makes up for it in other areas.
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    Registered Member Two Rings skaterjay85's Avatar
    Feb 27 2005
    1990 CQ, 1993 URS4
    Springtown, Pa
    not many japanese cars have the 4-link suspensions like the audis
    '90 CQ
    '93 URS4
    Dec 12 2004
    07 Honda CRV, 02 Inifinity QX4
    Raleigh, NC
    both sides of mine were out... its mostly... the steering feels loose... then when you are driving maybe 60+ mph you notice vibrations...but make sure its not like your wheels or tires or whatever... but the best thing is having a good local friend mechanic to take a look at it... thats what i did... damn Audi charges 100 for just diagnosing it...
    Veteran Member Four Rings Wholsea's Avatar
    1998 Audi A4 1.8tqms
    Blacklick, OH
    Hmmm, I just did min this weekend, both came out without a fuss...
    90,000+ miles through some nasty winters here in Central Ohio
    Used two wrenches, one on the tie-rod assembly, and one on the "loose" nut shown in the picture.
    Pinched them together (with a lot of force) and the loose nut broke loose from the assy, and the rest came free...
    I'd say, if all else fails, grab the end of the tie-rod end with a pair of vise grips, and the nut on the steering assy with either a wrench, or another pair of vise grips and spin it out that way...
    The hardest thing on the entire suspension assy is the long bolt that holds the two upper control arms into the wheel bearing housing!
    1998 A41.8tqms
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    PB Blaster and 30 mins, the bithces fall right out.
    Veteran Member Four Rings quattroanillos5's Avatar
    Feb 13 2004
    2004 S4 MT6
    Jersey
    I did mine too last fall... along with my control arms and my suspension..... they were a pain in the a$$ but i didn't have that much trouble.... the major problem i had was getting out the the bolt that hold the two upper control arms in place.... they were so rusted that i had to drill the entire bolt out.... took about 4 hours per side and i went through about 9 drill bits...
    sold:
    1999.5 B5 A4 1.8T quattro MT5
    current:
    Moro Blue 2004 B6 S4 MT6
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    I did mine last month and had no problems at all...the ends unscrewed with very little force. I have over 90K in NE winters too...but there was no rust on it at all.
    Hopefully you got the HD Meyle replacements, which are notably beefier!
    Feb 17 2004
    South Philadelphia
    yeah..its pretty hit or miss with these things..either you're lucky, ore you're not..
    F the Jersey Jerks
    Jersey Jerk hata #1
    www.REVI21ON.com
    Veteran Member Three Rings Kurzer's Avatar
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    WOOHOO!!!! We get to add a tie rod end to the cams, more cams and EFK kit... might as well tighten the DTS while all our cars are up Nate! Where you at mang?!? It's time for that BBQ
    Thank you: MatrixIntegrated
    Blacklick, OH
    Two words: AIR HAMMER.
    Mine were in there HARDCORE, wailed on it with a claw hammer, and I finally pounded it out.
    Used an air hammer on the other side, took all of 2 minutes to get it out, and it was *IN THERE*
    1998 A41.8tqms
    Veteran Member Four Rings Hassmeister's Avatar
    Feb 12 2004
    2015 GOLF R APR Stage 2
    Do they use Salt or chemicals on the roads there in Toronto?
    Click here for AMSOIL - Superior Protection!
    Wholesale pricing and delivery to your door - ask me how!
    Aug 20 2004
    there's more salt on the roads then in the sea in the winter
    Current: 2011 S4
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    oh man do they ever use salt up here
    just did my arms and rods this weekend
    no problem with the pass, but drivers was a bit of a bitch
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    correct but shouldnt be the excuse for the tie rod problem
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Blacklick, OH
    No, tie-rod ends go bad on all cars. Its the control arms that are the real issue...
    I think it is pretty safe to say that most other cars don't have the same issues that we do as far as control arms and such...
    But then again, look at the wheel angle when you turn your wheel to the lock, and look at the angle of say, a dodge magnum.
    The tire actually moves to an angle, whereas your audi holds the tire flat on the ground, giving you more grip in the turns.
    Its a sweet setup, just not made for a long lifespan :-(
    1998 A41.8tqms
    Nov 17 2004
    Northern New Jersey
    ^^ agreed :)
    Mar 03 2005
    us
    next time try soaking whatever you are going to be working on in pb blaster or something of equal quality, it has been a life saver for me.
    Aug 20 2004
    I'm using the industrial version of PB blaster.... safe to say its BETTER then PB :)
    Current: 2011 S4
