Results 1 to 33 of 33
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    Simple solution to broken battery cable?
    My car wouldn't start this morning and a peek under the hood revealed a surprise.
    Is there any other way to fix this other than getting a new positive battery cable for $210?
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Do you have enough slack to just put a new terminal on?
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Established Member Two Rings chitownsports's Avatar
    Mar 28 2010
    I need $$$ for cars
    Houghton, MI
    Just go to your local parts store (i.e. advance autoparts, autozone, etc.) The should be able to hook you up with a replacement for like 20 bucks or so. That's what I would do at least.
    !!!Denim Blue Baby!!!
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    I do and that was my first thought but I couldn't find a terminal at any of the local stores' websites (autozone, pepboys). Where would I find one. And I don't think they would sell them apart from the entire cable at the dealer since it's all one part number.
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    I'll go and see what I can find at PB.
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Any local parts store would have them. The terminal itself shouldn't be more than like $5
    02 A4 Quattro 1.8T
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    They sell female to female adapters. That cable is a little larger than 8 gauge. Another option if you cant find those adapters is to get a fuse holder to use as a female to female adapter. Instead of using a fuse though just put a piece of wire of equal size in its place.
    DG '02 A4 1.8TQM
    My Build Thread
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    or you could replace the terminal with something like this
    http://www.sonicelectronix.com/item_...PN3-BTPN3.html
    you would just need to strip off 1/2" or so of shielding from each of your cables and stuff it in the little holes. Much cleaner setup than stock.
    -06 A4 2.0T
    -97 A4 1.8T
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Quote Originally Posted by urban96 View Post
    That looks pretty cool...any experience with them?
    02 A4 Quattro 1.8T
    Mar 20 2008
    Belmont MA
    Just a heads up that the two factory wires are a little larger than 8 gauge. They won't fit into 8 gauge holes and are a pain to trim down because it is made of thick stranded wiring. If you go that route I'd suggest getting something that has a 4 gauge terminal that you could squeeze both factory wires into. From the looks of it you'd get one with 2 to accomodate what looks like an amp wire there. Another idea is to just get a ring terminal to crimp onto the factory wire and then swing the little extension that the amp wire is connected to right now and attach it there.
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Of course it couldn't have been the negative cable, that is only like $35. That is a nasty bend on what I am guessing is your blue amp wire.
    Veteran Member Four Rings airjordan223's Avatar
    May 04 2009
    Ohio
    just replaced the terminal on my other car.
    got it at napa for like 3 bucks
    2013 S4 | B&O | Sport Diff | Magma Red | DSG | LED Fogs| Stance SF03 | Michelin PSS | Gyeon Ceramic Coating | EPL Stage 1 | Maxton Design V2 | H&R OE Sport Springs | ECS Diffuser
    2002 A4 3.0 Quattro | 17" BBS RK | ST Coilovers | LED DRLs | Hardwired V1 | Alpine 12" Type R | Pioneer 800W Amp | eDead 80 | Dice iPod Integration | Power Slot Rotors | Hawk HPS Pads SOLD
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    simple solution...
    bring it to the dealer. drink all the free coffee and eat all the cookies, beat the piss out of the loaner, and make sure they detail it for you.
    thats simple!
    Jun 30 2008
    Erie, Pennsylvania
    You just need to strip that wire, and crimp one of these on the end:
    Or one of these, and you just tighten it down:
    Then take the nut off at the battery post (where your little 2-way duplexer deal is connecting) and bolt it down.
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    All is fixed. Thanks for all the help!
    The amp wire had that nasty bend because of the stock terminal style and my own inept installation skills. The new terminal alleviated that problem.
    Interestingly, the universal terminal wouldn't open wide enough to slide easily over the battery post and it required some forceful coaxing. And those stock wires really are a pain in the ass size.
    And now my keyfob wont work. I'm hoping its just a matter of time with the car to become reacquainted with it.
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Stick your key in the door, lock it, then unlock it, then start the car. Then shut it down, step out and give it a whirl.
    Aug 26 2005
    Quote Originally Posted by Kamin View Post
    To reinitialize your remote, put the key in the ignition, then turn the key ON, next press one of the buttons, unlock or lock, then turn the key OFF and remove the key from the ignition and test the remote function. Should be working again now.
    Vorsprung durch Technik
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    Thanks for the suggestions! In the process of manually unlocking and locking the car it started working again.
    Jun 14 2005
    Anaheim, CA
    Looks like all the questions were answered here! Hopefully this thread will stick around so someone who searches will stumble across it in the future
    Brandon @ VMR Wheels
    Jun 30 2008
    Erie, Pennsylvania
    Any pics of the repair?
    Mar 26 2015
    Bump from the dead..
    Didn't want to start a new thread. I am having the same problem. Not entirely sure how OP fixed this and was needing some advice. I also PM'd him earlier today. Thanks in advance!
    -Dave
    Established Member Two Rings Northern_B6's Avatar
    Feb 20 2013
    CANADA
    Quote Originally Posted by David813 View Post
    -Dave
    I used something similar to this:
    http://www.mysolarshop.co.uk/battery...set-p-230.html
    to fix this problem when it happened to me.
    Mar 26 2015
    Quote Originally Posted by Northern_B6 View Post
    But how would I connect the master fuse box to it?
    BTW, thanks for the quick reply bro.
    Feb 20 2013
    CANADA
    Let me go take a picture of my setup...
    Edit: I removed the black "jumper box" and connected it directly to the new female battery terminal.
    Part cost me $2.99
    Temporary fix, I will do a permanent fix when I get the time.
    Mar 26 2015
    Part cost me $2.99
    Awesome! Thanks again bro! I really appreciate it.
    Established Member Two Rings DansB6's Avatar
    Aug 02 2010
    2006 B7 A4 2.0T Avant 6MT, 2017 Q7 4M 3.0T
    Roseville, CA
    The simple solution is to buy a new car :)
    Feb 20 2013
    CANADA
    No problem.
    Any auto parts store should carry these
    Mar 26 2015
    Quote Originally Posted by DansB6 View Post
    Haha, but I love my b6! :) ...even though it's been a pain in the ass these last two months!
    Aug 02 2010
    Roseville, CA
    I'll help you feel a little bit better :)
    Past 2 months i had to replace.
    Cylinder head w/ head gasket
    Catalytic converter
    o2 sensor
    both headlight bulbs (xeon :( )
    all 4 tires
    all front control arms, upper and lower
    motor mounts
    transmission mounts (today)
    main window switch
    battery
    And on Sunday on the freeway i was driving behind a pick up truck going about 80 mph and a piece of plywood flew out of his truck bed, smashing into my front right corner of the car. Destroyed my fog light, tow hook cap, head light washer cap, fog lamp, and fog lamp grill, and scratched my bumper pretty badly.
    Mar 26 2015
    Catalytic converter
    o2 sensor
    all 4 tires
    motor mounts
    main window switch
    battery
    Damn!
    I just had to replace
    That connector (which I just finished now and works!)
    Passenger side front window regulator
    Few misc lights
    Oil change
    So ya, I feel a lil better haha. Still have a few odds and ends, but they will come soon enough! :)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Catalytic converter
    o2 sensor
    all 4 tires
    motor mounts
    main window switch
    battery
    There is sooo much more that will be replaced, just wait.
    2019 SQ5 Prestige
    Feb 20 2013
    CANADA
    Catalytic converter
    o2 sensor
    all 4 tires
    motor mounts
    main window switch
    battery
    How many miles are you at ??
    Aug 02 2010
    Roseville, CA
    Quote Originally Posted by texasboy21 View Post
    Oh i know, its only expected, waiting for the fuel pump to go or the turbo to explode.
    167k miles. Also forgot to add i did a transmission service at 165k because it started to shift hard/down shift hard (auto tranny). Transmission fluid came out black. Drives perfect now.
