With the pins properly adjusted the hood is locked down very securely and doesn't move or get those speed wobbles at all. A huge part of the issue is the quality of the hoods. It takes more than $500 in materials to make a structural carbon hood and the Vis and even Vorsteiner just aren't made all that well. My Vorsteiner has a layer of carbon over a layer of hexcell. That hexcell reinforcement is not sandwiched between another layer of carbon which would increase the strength and rigidity tremendously. Carbon's strength comes from creating a sandwich layup that acts as an I or H beam and the way mine was done just doesn't close up the bottom of that beam.
One could be made with carbon over a few layers of basalt or knit bamboo (both are lighter, cheaper, and stronger than fiberglass) with another carbon layer on the bottom and it would be far more rigid than the current offerings. It would also keep it from cracking like my Vorsteiner. The hood latch should have aluminum, titanium, or stainless threaded inserts like you use in wood working. They would spread the load and if they were also held by a metal backing plate then pins would be completely irrelevant. Some fancy cars come stock with carbon hoods and they don't have pins because those hoods are strong and expensive.
Cheap, light, strong. <**- pick any two, you can't get all three.
To address the aluminum issue, I don't think one is available for these cars. My 01 allroad smacked a deer Friday morning and that aluminum hood is remarkably strong. It weighs almost as much as a steel one so I'll take the insurance check and buy a steel one with it. A half dozen pounds couldn't more irrelevant on a 4400 pound car.
As far as real performance gains go, you would be far better off with a battery relocation than with a carbon hood. The price is far more palatable as well.
This is the hood that jump started the sales of hood pins. Ouch.
