Originally Posted by
walky_talky20
I guess I was unclear (as usual!). I was trying to confirm with the OP that those were the numbers he used. From his first post, it seems as though he was trying to log in as Automatic, then recode as Manual - which is incorrect. But then he said he used the coding "from the ross-tech website", for which they only directly give the 40168 login (for steering adaptation). So I was just trying to see what he actually he used. The numbers I gave should be the stuff.
I didn't realize you were referring to me with your previous post...
Let's review:
-my car was a TipTronic
-I have since swapped in a manual transmission
-everything in the car is coded for a TipTronic transmission and now needs to be recoded for a manual transmission (I have been successful at recoding the ECU and the cluster)
-I cannot recode my ABS module, the purpose of this thread is to find out if anyone has actually recoded an ABS unit. Every response here has been for a manual transmission, has anyone been able to recode the ABS unit in a TipTronic car?
My attempts at recoding:
-clear DTCs in ABS module
-confirm no DTCs present
-login with 09577 (no confirmation of successful login, ECU does confirm successful login)
-change module coding from 04277 to 04575 (TipTronic 1.8T with small brakes to manual 1.8T with large brakes; closing the coding window reloads the window and the coding reverts)
-login with 40168
-basic settings group 001
-close
-key off
When I go back in, the coding is still 04277.
Hopefully that clears things up a bit....
