Results 1 to 20 of 20
    Established Member Two Rings dogdr.'s Avatar
    Feb 19 2011
    Boston, MA
    A/C cold when car is moving, warm at a standstill???
    just noticed this tonight as I was sitting in traffic. A/C works perfect when the car is moving but comes out warm when the car is at rest. Any thoughts?
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    the movment of air through the condensor is why your getting cold air and warm at rest. check refrigerant level first and go from there.
    Established Member Two Rings asullivan's Avatar
    Jan 06 2011
    Wichita ks
    ive had the same issue, also when its cold outside my heater wont kick on till i start driving...thank god for heated seats
    May 25 2011
    Chandler, AZ
    Make sure your fans are working properly. Otherwise, this may just be a symptom of the design. I haven't noticed this in my B6 however my B5.5 Passat wagon was guilty of this, especially in 100+ temps.
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Your auxiliary fan might not work or spin at the high speed.
    Active Member Two Rings sbatqmi's Avatar
    Sep 14 2010
    2003 BMW 325i, 2003 Saab 9.3, 2001 F150 4x4
    Chandler,Az
    Mine does the same thing. It blows the same but the temp is different at a stop light vs moving. But its 100° plus here.
    Veteran Member Three Rings gray6spd's Avatar
    Jan 18 2009
    is nonexistent
    texas
    check fans and fan control module.. had this problem.. twice. im on my third and fourth fans..
    PREVIOUS:
    2004 1.8T Dolphin Grey- Quattro - 6MT - Sport Package - K&N - 35% - Stage: still in college and broke -
    2015 S4 3.0T Sepang Blue Pearl - DSG - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber - Totalled by a damn F150
    CURRENT:
    2015 S4 3.0T Daytona Grey Pearl - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber
    2012 Infiniti G37 Sport 3.7L Obsidian Black - Eibach Springs - K&N -
    Proud of my pink coolant.
    Veteran Member Three Rings sxman69's Avatar
    Oct 04 2009
    08 CRF250R, BLKMRKT Mob, Giant Glory DH
    Auburn, CA
    How can you tell the fans aren't working? Should they be spinning at idle w/A/C on?
    -Sam
    New: 2009 Mazdaspeed 3 GT
    SOLD!!!! Staggared AMG Monoblock // Podi // Magnaflow // Forge // Kicker // Kenwood // JHM stud conversion // Tint //15mm H&R spacers // Hardwired Passport 8500 X50 // 034 Wiring Harness // Hawk HPS // 034 Blockoff Plate // MKIV Euro Switch
    Veteran Member Four Rings BUSAfREAkA4's Avatar
    Dec 17 2009
    08" Evo X, 11" GSXR 750
    LVPA
    when i bought my audi i just assume that i have a car without AC, every a4 ive ever been in has had the same issues. i dont even use my ac. but that heat. OMG, gotta love it!
    -Nick
    REDRUM
    seph: who's ricky and why were you at his place with all those dildos?
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    Quote Originally Posted by BUSAfREAkA4 View Post
    Um....What? My AC blows like a blizzard. If your a4 doesn't have good ac, its probably because something isn't working. Not because all a4s have bad AC
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Jan 18 2009
    is nonexistent
    texas
    Quote Originally Posted by sxman69 View Post
    yes, they're very loud. you cant miss them
    PREVIOUS:
    CURRENT:
    Feb 19 2011
    Boston, MA
    Thanks guys. Good info.
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    also having this problem...and it seems like the passenger side is warmer that the driver side. The car will throw a code ( NOT CEL) for a malfunctioning fan control module, correct?
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Dec 31 2010
    Berwyn,IL
    its probably low on charge. Bring it to a shop and have check the charge. Also make sure when using your A/C to have it in recirculation mode for max A/C. And don't use the stuff from the parts store with the sealers and crap in it.
    Dec 17 2009
    LVPA
    Quote Originally Posted by alpinestar180 View Post
    congrats??
    im speaking out of personal experience. I have a few friends with A4's and 9 out of ten dont blow that cold. I cant speak for anyone in ACE, but i realize that not ALL audis dont have good AC. i never siad that so dont put words in my mouth. i said every audi i have even been in. I dont think i have sat in every audi in the world.
    -Nick
    REDRUM
    Established Member Two Rings Colombian2nv7's Avatar
    Apr 27 2011
    NY/NJ
    My car does the same. When its moving even in summer, it blows super cool air but when its idle, its only like a fan. not sure why, but the ac seems to work only while in motion
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    Maybe it's because your belts (serpentine) isn't spinning as fast at idle (engine speed)? That makes the most sense.
    Registered Member Two Rings chrisisbeef's Avatar
    Jun 22 2011
    2003 VW Jetta 1.8T, 2004 Audi A4 1.8t
    Denver CO
    Would almost put money on low refrigerant. Every car I have had this is what happens when the refrigerant starts getting low. Top it off and you will be g2g
    Mar 07 2010
    Sherbrooke, Qc
    Low coolant also make sense since the coolant lubricate the seal and seals leak over time.
    Dec 04 2006
    Los Angeles, CA
    these symptoms are common for a compromised cooling system.
    Ideally, you need to hook up the vag com or obdII reader to see your exact engine temps during these events while driving.
    It could be that you are overheating and hitting the A/C cutoff. Once moving, enough air flows to cool down the motor and A/C will kick back on.
    The problem is a weak fan clutch (on cars w/ clutches) or broken/faulty electric fan(s) (on cars w/o clutches).
    It could also be a old radiator, old coolant, etc.
    A/C system-
    low/high pressure readings are needed
    condenser may be freezing up
    check your drain to make sure it's not clogged- A/C on, you should see it dripping water from the drain after a short time.
    B8 2.0T QTip
