Hey guys-
I brought my car in to audi to get my oil topped off before going on a road trip yesterday. (Btw, the oil meter for max to min indicates when you are down one quart of oil. After, a yellow warning light comes on. After, u have a second bar to burn a second quart of oil. If u manage to burn thru this one as well, then the light turns red. That is when you need to get ur oil topped off immediately.)
I complained about my clutch pedal squeaking and being a little rough when it is fully engaged and u start to let it out a little. I asked them to grease the clutch hinge, but they confirmed there is a tsb to replace the throwout bearing (apparently this is a common problem). Im going to lose my car for two days due to labor :(. Just a heads up if anyone else has a squeaky clutch pedal.
