We are proud to announce our new BFI Performance Snub Mount! After a lengthy design, testing and production process, we are finally able to offer the best snub mount available to B6 / B7 Audi owners.
The factory snub mount is a well known weak point of the engine isolation system in your B6 or B7 chassis Audi. Made of a soft foam rubber, the OE piece is great for initial comfort, but lacking in longevity and performance. The factory rubber snub mount is notorious for cracking failing causing those mysterious and annoying clunking sounds coming from your drivetrain.
http://store.blackforestindustries.c...aub6b7pes.html
Our Performance Snub Mount is constructed of noticeably stiffer polyurethane (75a) vs. the factory rubber mount. Our parts are designed to stand up to the abuse of hard or even just spirited street driving. Reduce your engine movement and improve shifting with this economical upgrade!
Available now at a special introductory price – Pick yours up today!
Also, stiffen things up even further with Factory replacement or aftermarket RS4 mounts! The hardest durometer rubber available, these will further help to reduce engine and drivetrain movement:
http://yhst-1918367471896.stores.yah...emrs4enmo.html
