Results 1 to 6 of 6
    Veteran Member Two Rings audi_state9's Avatar
    Sep 20 2004
    2010 S4
    "ESP Fault! See Owner's Manual"
    Driving back from the airport today after a 3-day trip and suddenly get this message on the driver's information display: "ESP Fault! See Driver's Manual". I was driving around 75MPH when it suddenly felt like the brakes were being applied for a split second (not by me)...and at the same time that message popped up on the screen. No other warning lights after that and the car is now driving normally.
    NOTE: I do not have rear differential.
    Anyone ever experience this?
    Veteran Member Three Rings mdma2004's Avatar
    Aug 24 2008
    GCC
    Did you look at the drivers manual?...like it said?:)
    Page 13 and page 222...
    B8.5 A5 S-Line 3.0T
    Sep 20 2004
    2010 S4
    Quote Originally Posted by mdma2004 View Post
    Yes. I did not experience the addition of other warning lights (i.e. ESP / ABS / Brakes)
    Aug 24 2008
    GCC
    Well obviously the car had a fit, since you left her all by herself at the airport...its kinda sayin dont do that shit again, lol
    And other idicators dont have to be present:) you can always vag com it to find out what code it threw or just swing by the dealership for them to look at...i doubt its anything
    B8.5 A5 S-Line 3.0T
    Senior Member Three Rings SM_ATL's Avatar
    Jan 25 2011
    2013 Porsche 991S, 2012 GTI, 2014 Infiniti QX60, 1995 E36 M3
    Atlanta
    Got a weird experience recently too when I got my new wheels installed. While the car was on the lift, guys from the shop started the engine and made the wheels turn fast and checked balancing, alignment etc. Back on the ground, the car threw me a bunch of warnings regarding ESP, ABS, brakes, TPMS, etc. No big deal, everything was working fine, the car had just been confused to ride "in the air" while wheels were being checked individually. I erased the codes and everything is normal (and works well!).
    It could be that the S4 nannies are a little too quick to jump the guns!
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    I second the notion that she was mad you left her alone outside next to inferior models
    500AWHP/500AWTQ
    @Driven_Not_Hidden
