Results 1 to 4 of 4
    Veteran Member Four Rings 1dopea4's Avatar
    Aug 03 2010
    joliet IL
    b6 passat roof rack mod fairing size and fitment?
    simple question, i fitting my a4 with the b6 passat roof rack, now im looking to get a fairing for it as my sun roof is useless when i drive because of the annoying howling. so i figure a fairing is in need. im not sure which to get, and if they will fit. im looking at thule 872xt and yakima 7048. but im not sure if they mount to the stock square bars of the passat kit. anyone know or have fitted a fairing to the passat roof rack?
    Sep 16 2010
    Central Wash
    You can rig it up and make it wort of work, but you may be limited on what rack attachments you can mount, since the fairing can get in the way. I had a Thule fairing on a Yakima rack, it didn't work well. Eventually got the right fairing and it helped alot.
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    theres different attachment hardware made for different base bars. you would most likely have to custom mount the fairing on the passat rack if the base bars are similar to the oem audi one.
    heres the diy for mounting a thule fairing on oem base bars which is what i did. you can do your own variation but it gives you an idea of what you need to do to mount it. http://forums.vwvortex.com/showthrea...tex-Roof-Racks
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    You have to custom mount it. No choice. Just buy any fairing that is as wide as the rack and bend some metal so you can screw it into the bottom of the front roof rack bar.
    I have an old style yakima one. It was really cheap so i got it, cut it to the right width, and bent some strips of sheet metal and screwed one end to the rack, and one end to the fairing.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
