Results 1 to 22 of 22
    Mar 04 2011
    Kitchener/Ontario/Canada
    how much to stretch tires and what are the drawbacks
    I am buying a set of wheels that are 19x8.5 et 35 amd 19x9.5 et 40 staggered, and i am lowered on ST coilovers. What size tires should i be going with???
    Much appreciated...
    2013 Q7 TDI S-Line Graphite Grey on Black
    20" Porsche Cayenne Turbo wheels Black/Polished Lip
    OEM Dual DVD Entertainment
    Panoramic Roof
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    Falken FK452 tires are perfect for stretching.. Or so I've heard and read.
    B8.5 Audi SQ5 | APR Stage 1
    Mar 04 2011
    Quote Originally Posted by kristokes View Post
    Thats what i'll be getting as a friend of mine works for a Falken distributor and i can get them for a great price. I am buying staggered Avant Garde M368's.
    Was thinking of 215's in the front and 235's in the rear.....
    Panoramic Roof
    Active Member Two Rings rbleka's Avatar
    Mar 14 2011
    Chicago
    Not too much of a stretch on my Continental Extreme Contact DWS's but they are holding up great and have overall great performance all year.
    98 30vQM -Bambus Metallic/Cognac - Anthrazite|18" A8 Flat Fives|Continental DWS|H&R 5/10mm|
    |6000K|50% Tinted '01 Tails|Debadged|35% Tint|Bilstein PSS9|Reiger Illuminated Shift Knob|Illuminated Engine Start|Roach Custom Intake|AEM Dryflow|Borla Cat-Back|Hardwood Trunk| Double Din Conversion|AVIC-D3
    Mar 26 2007
    Colorado
    I won't run anything smaller than 225 on an A4....
    CURRENT:
    2021 Atlas
    Veteran Member Three Rings funky_snowman's Avatar
    Dec 31 2010
    US
    two things...first, regardless of what you might read on this forum, you might want to rethink running a staggered setup on a car w/ a mechanical center diff. secondly, why not just fit the tires the way they are supposed to fit? tire manufacturers tend to make available information regarding the size of wheel that a particular size of tire can accommodate, in addition to the abundance of tire size calculators that you can find on the net.
    Veteran Member Four Rings ryanworth's Avatar
    Nov 16 2009
    Los Angeles, CA
    I would go with a 225/35 up front, 235/35 for the rear.
    I had that before and was fine running staggered. Plus I had way lower offsets.
    I'm currently running 215/35 on a 19/8.5" right now, and it's still no problems. Just not as soft/comfortable as say a larger tire would be.
    Ran Hankook V12's before and those were great tires, just not as nice of a stretch.
    I now have Falken 452's, louder tire but stretches very easily and looks great!
    Ford Focus - 2.0 Gray Four Banger Bad Ass Hatchback - Current
    B7 S4 - 6MT Dolphin Gray Avant - Old
    B7 A4 - 2.0T 6MT Quattro Brilliant Black Titanium S-Line - Old
    -Ryan
    F.T.W.L.T.B.D.W.I.C.T.W
    Veteran Member Four Rings dumpedb5's Avatar
    Nov 22 2009
    B5 Imola Avant and a MK4.
    City Of Roses
    I am going to be running 215/35 on a 9.5 all around. 235's on a 9.5 is barely any stretch at all. As long as you keep the tires aired up to spec at all times you shouldn't have a problem.
    This should help you a bit.
    http://tyrestretch.com/
    SQUISHEDTWINKIE
    Veteran Member Three Rings ipop07's Avatar
    Jun 09 2009
    Kitchener, ON
    you have to run staggered setups that maintain the circumference of the fronts the same or +/- 0.5% difference only.
    I would suggest you use this: http://www.1010tires.com/tiresizecalculator.asp
    something like 225/40 and 255/35 would work...
    '18 Golf R / '21 Atlas R-line / '09 A4 Wagon
    instagram: ipop07
    Nov 16 2009
    Los Angeles, CA
    Quote Originally Posted by ipop07 View Post
    Wrong. 5%, not 0.5%. There are plenty of guys on here running way heavy stretch on 35's.
    -Ryan
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    I'm on Avant Garde M310's 19x8.5" et35 with 235/35/19 and 19x9.5" et40 with 265/30/19 hankook Ventus v12 tires, and I love them. No stretch really but I kind of like more of a muscle kind of look vs the stretch look that everyone else is going with. I'm not that low either so stretch wouldn't look as good as if I were slammed.
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    I've read on tyre manufacturers' sites that a 225 is designed for up to a 9" rim & a 215 is up to an 8.5.
    I had no problems running 225/35/19 front on an 8.5 and 235/35/19 on a 9.5 at the rear. I'm now running 215/35s on 9x19s all round.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    Veteran Member Four Rings VegasAIV's Avatar
    Feb 25 2009
    B7 A4
    Las Vegas
    Quote Originally Posted by RAudiB7A4 View Post
    this still kills me lol
    Turbo lag is just foreplay...
    Established Member Two Rings JPthaJedi's Avatar
    Jan 15 2010
    vegas
    go with a 215 front if you want a stretched look.. i regret going with the 225 up front..not much of a stretch at all.
    Established Member Two Rings TMK's Avatar
    May 24 2011
    Finland
    225 front and 235 rear.
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Quote Originally Posted by felondnb View Post
    this is correct. my hankook ventus v12 225/35's actually show the widest tire they're recommended for are a 9" wide wheel.. which is what i run:
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Mar 04 2011
    Thanks for all the info guys. Not sure what i am going with yet - but likely the 2 scenarios:
    If i get the staggered Avant Garde m368's i will be running 215 fronts and 235 rears. If i get the VMR V710's they are 8.5 all around so i will run 235's all around or 215's all around.
    Still debating one wheel over the other, the AG's are gunmetal with machined face, the VMR's are all gunmetal. Not sure what will look better on ibis white.
    Panoramic Roof
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    215/35/19 on an 8.5 and 225/35/19 on a 9.5
    they are the falken fk452s
    i probably can find some better pictures if you want them though
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    New wheels already?
    Pat
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Mar 04 2011
    Quote Originally Posted by pw211 View Post
    New wheels already?
    LOL, do you want me to say "you were right"? I wont be doing that hehe.
    I bought a set of 19x8.5 et 35 VMR V710's in gunmetal and used 235/35 tires all around. Looks good will post pics soon.
    Panoramic Roof
    Nov 08 2010
    Damn. :(. I was hoping I'd get to see the m368's on a b7. I almost ordered those. Went with the 310's instead. VMRs are always a safe choice though.
    Mar 04 2011
    Panoramic Roof
