Originally Posted by
a4_bob
Thanks for your feedback @jordancl. As I understand this the front O2 sensor and MAF contribute to air trim calculations while the rear O2 sensor is simply monitoring the cat? i'm new at this but based on the trim readings varying with the presence of the spacer, it almost sounds like you're putting the spacer on the front sensor. ?? does the rear O2 sensor contribute to trim calculations? if so, how would a spacer or disabling it via APR stage2 actually work right?
I'm quite curious to fully figure this out as I just received my HFC and 90* spacer and am wanting to run this w/ the rear O2 sensor active+no cel and no faults.
This is the way I understand it. The front O2 sensor reads exhaust gasses going into the cat for hydrocarbon levels. The rear sensor reads exhaust gasses coming out of the cat and reads for hydrocarbons also. If the cat is functioning, there is a decrease in hydrocarbons in the exhaust gas at the rear o2 sensor because the catalyst has converted them into CO2 and H2O.
With no spacer and a high flow cat, the rear o2 sensor is seeing more hydrocarbons than it would w/ the stock cat because the gas is passing through the cat more quickly and it is not converted as well. Of course the car doesn't know or care that you put in a higher flow cat; all it knows is that its seeing too many hydrocarbons after the cat and it throws a P0422 ** cat below efficiency threshold. The car essentially thinks your catalytical converter is broken.
Putting a spacer in steps the o2 sensor back out of the cat so its not right in the middle of everything. The idea behind a spacer is to not let the rear o2 sensor see some of the hydrocarbons in the exhaust gas so it thinks everything is OK and it doesn't flip out as above. However, as I stated originally, the rear sensor does expect to see SOME hydrocarbons because even the stock cat isn't perfect. So if you space it out too far, and it doesn't see ANY hydrocarbons it figures there must not be enough gas getting to the engine (running lean).
As far as I can tell, I'm the only one who has had a problem like this on the forums thus far, so if you have a spacer in your hands I'd just throw it on and try!
xstwin
jordancl, I've got an extra 1/4" spacer (more like washer) that will thread onto the 02 sensor. Should leave about 2.5 threads left. I'm in NJ, will gladly drop it in the mail. Send pm if interested.
I will definitely try this and paypal you shipping $$ ** PM sent
