Results 1 to 13 of 13
    Apr 27 2011
    montreal quebec
    convert spedometer from miles to kms
    i resently imported a 2009 audi cabriolet from the usa to canada and absolutly love the car except for the fact that the spedometer is in mph . i was woundering if there is a way to do the conversion to kms with out changing the whole speedo , at first glance it would look like i could just change the facia of the speedometer but i doubt its that easy . also when i tried my friends 2011 gti the display in between the rpms and speedo had the possibility of showing live speed so i figured that would be fine for me but i checked every possible setting in the menu of my a4 and was not able to get live speed , only an average speed
    any help would be appreciated
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    Your speedometer shows MPH and km/h at the same time..
    B8.5 Audi SQ5 | APR Stage 1
    Jun 08 2008
    Calgary AB Canada
    You could take the cluster apart and replace the facia but you will need a custom one as the canadian ones speed markers are at different points, thus a canadian facia would indicate an incorrect speed
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Established Member Two Rings BladesBravo's Avatar
    Aug 25 2009
    I think hes talking about the dials themselves, and yes it can be changed. I'm not sure where you could get the piece. But the face plate for the speed/tach/warning lights can be easily swapped out. Check out the 4th pic in this post
    http://www.audizine.com/forum/showth...l-Color-Change
    Apr 27 2011
    montreal quebec
    i know it shows both but i would like to have the larger white numbers to be the kms and the smaller grey numbers to be mphs
    Quote Originally Posted by kristokes View Post
    Apr 27 2011
    montreal quebec
    maybe there is a company out there that could replace the front facia and calibrate the speedo
    Veteran Member Four Rings Cottonmouth's Avatar
    Jan 02 2009
    2016 Jeep Grand Cherokee Overland
    Burlington, Ontario
    Mine only shows kph...
    2006 S4 25quattro SE - #159 of 250
    2006 B7 A4 2.0T STAGE 2+ RIP
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by Cottonmouth View Post
    [IMG]
    Same on mine
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Apr 27 2011
    montreal quebec
    good for you
    Apr 27 2011
    montreal quebec
    what about the live speed display in the centre menu display on the cluster , is that something that i can have also like my friend in his 2011 gti , i guess thats a vag code too ???
    Senior Member Two Rings mpower's Avatar
    Feb 02 2008
    01.5 Nogaro B5S4, 2012 B8S4 Glacier Prestige, 09 Q7 S-line TDI
    Chicago
    New KPH face is needed and speedo value (cluster EEPROM) re calibrated to match the new face... That's all. Specific tools are needed to read and re write/modify EEPROM values associated with speedo values.
    Odometer and info display can be easily changed to Km/metric with VagCom.
    Apr 27 2011
    montreal quebec
    wow thanks for the great info , now are you able to point me in the right direction for me to get this done , I mean the changing of the face and recalibration
    sorry I just re read your post , so where would I be able to buy the kmh faceplate
    thanks
    Feb 02 2008
    Chicago
    Here is what you would need, but from cabriolet, which might or might not be interchangeable with B7 sedan Bosch RB4/RB8 instrument cluster... Here is one example, but obviously not the part you need:
    http://cgi.ebay.com/ebaymotors/AUDI-...Q5fAccessories
    Also, you might not have much luck finding just the dials and have to pick up a complete used KPH cluster for part swap or complete cluster swap.
    Hope this helps.
