    Veteran Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant, '06 Toyota Tundra
    San Diego, CA
    Need pic of alternator connections from '00 or '01 1.8T.
    Trying to make this fit cause I want 120 amp alternator. However, they use two different connections. If anyone can get me pics of their alternator leads it would be great. Maybe I can solder the two pin connector to my wires.
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/AWE DTS/17" Enkei/Bridgestones
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    Rieger RS4 bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
    Jun 30 2008
    Erie, Pennsylvania
    On my 01 it has that 2pin D-shaped connector for the regulator. It only uses 1 wire, though. So I would think you could just splice it up and make it happen.
    May 08 2004
    San Diego, CA
    awesome, that is good to know. If it's not too much trouble can you see if there's a part number for the connector and/or snap some pics of it for me?
    99 A4 1.8TQM Avant
    Jun 30 2008
    Erie, Pennsylvania
    I can look tonight. Just PM me so I don't forget.
    Veteran Member Three Rings dowsett6's Avatar
    Sep 10 2008
    99.5 1.8t BT, 97 1.8t
    Ontario
    I'm just updating this post with some information I came up with while swapping in a newer alternator into an older alternator car.
    The old style alternator has 2 terminal posts. One is marked B+ which is the battery connection, and the other post is marked D+ which is for the ignition wire.
    The new style alternator has 1 terminal post, and a connector with 2 more terminals inside of it. Again the one terminal is marked B+ for the battery connection. The connection terminals are labeled as L, which is pin 1, and DFM which is pin 2. The new style alternators only use one of those two pins.
    So L (pin 1) is the connection you would use instead of D+.
