Results 1 to 40 of 40
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    AC smells funny?
    Air conditioning smells funny. Only when on cold air. Smells normal on bypass and heat. Does this have anything to do with the cabin filter, or is there somewhere else I should be looking?
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Have you ever changed the pollen filter? I change mine every 6 months and run the charcoal filter.
    Dec 03 2008
    2018 SQ5
    I think it's been changed once in the 3years I've owned it? That's what I meant by cabin filter. The one above the stock airbox, opposite the ECU under the hood. I was thinking of going to the dealer to get one tomorrow if that would help.
    Mar 24 2007
    Yes that could help, but you can get the charcoal aftermarket ones for $15-20
    Dec 03 2008
    2018 SQ5
    The OEM ones aren't charcoal?
    Sep 27 2008
    Phoenix
    Jim you need to turn off your AC a few minutes before you shut your car off. The rotten egg smell is notorious with the B7. There are also air freshener kits that kill the mold that grows in your AC as well. It kills me here in Phoenix where we have to run the AC like crazy and I'm already getting the smell.
    Dec 03 2008
    2018 SQ5
    I try to. I turn the ac off, but blow all the cold air out until its wam again when I can.
    Sep 27 2008
    Phoenix
    If you run the heat full blast for 30 minutes it should clean out any bad smell. Obviously that isn't the easiest thing to do when it is burning hot outside.
    Dec 03 2008
    2018 SQ5
    Really? I got time tomorrow, I'll give it a shot.
    Established Member Two Rings Ramathorn's Avatar
    Feb 01 2009
    my feet, mountain bike, & a snowboard
    Newport/Jersey City, NJ
    Does the smell go away after running the AC for a few minutes, if so there is mold on your condenser... I had a similar problem with my old GTI.
    VW/Audi makes a special cleaning kit for it, or if you are still under warranty/certified they will clean it for free. There may be an aftermarket kit that is cheaper too.
    XBL: vdub337
    '07 Audi A4 S-line with APR Chip, Tein SSD Coilovers, H&R Spacers, 15% tint all around.
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    I think I might have to do that klima-cleaner thing. I've smelled some weird stuff in the past few days too.....at first I thought it was just the food i ate -_-
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Dec 03 2008
    2018 SQ5
    Can you get stuff like that from like auto zone, or internet only?
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    Remove the cabin/ pollen filter and spray some lysol disinfectant spray down there. While doning this put your AC on heater at full blast for about 10 to 15 minutes. Should do the trick. Bad news is you'll have to do this about once every 6 months due to the infamous mould build up in our AC systems.... The upside is the car smells great every time you tun on the AC.
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    It's made by the German-based company, 1Z. They make incredibly good products btw. You can pick some up from Detailer's Domain: http://www.detailersdomain.com/carca...maCleaner.html
    Dec 03 2008
    2018 SQ5
    I'm changing the pollen filter and trying out the lysol method since I am impatient. If that doesn't work, I'll be ordering the crazy german shit next.
    Jul 27 2009
    '15 S3
    Boston
    You're probably better off installing an OEM charcoal-lined filter. Although more expensive, the purpose of them are to eliminate odor causing particles.
    Another link for ya Jim: http://audi.bernardiparts.com/Produc...819-439-C.aspx
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by mr_esmit View Post
    ^^ This
    Along with changing the cabin filter regularly.
    We have them available below.
    Click HERE to order or for more information.
    Jason
    Dec 03 2008
    2018 SQ5
    How often should this filter be changed?
    Mar 24 2007
    I dont know what they recommend, but right at 6 month is where I can tell it smells different. I normally change it now in late Spring/Early summer and early Winter.
    Veteran Member Three Rings 9Hooker's Avatar
    Feb 24 2009
    06 A4, 10 4Runner
    Virginia
    bought the klima cleaner on ebay for $13.00 shipped.
    Detailers domain wants $14.99 plus $12.00 shipping. No thanks.
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    Literally was googling this today at work!
    Also a good idea is to check the ac drain for a plug. If you do not see a puddle of water under the car after running the ac for a period of time this indicates a plugged drain.
    That backed up water festers in the car causing it to smell. I haven't found any b7 specific threads but its more or less unanimous that the drain tube is located on the passenger side foot well. Its a black tube connected to a small box.
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    Jul 27 2007
    Orange County, NY
    Charcoal filter on amazon for 15.51 with free super saver shipping:
    Clicky
    (same mfg# as on Europa Parts)
    I saw my car pissing on the ground the other day so I would guess my drain plug is fine lol
    Sep 27 2008
    Phoenix
    Quote Originally Posted by Coderedpl View Post
    Clicky
    Thx for the link. Getting one myself.
    Feb 24 2009
    06 A4, 10 4Runner
    Virginia
    Quote Originally Posted by b7kevin View Post
    good idea to check it. does anyone know exactly where it is?
    Oct 02 2006
    Wadsworth,OH
    I think the recommended replacement interval is 15k miles.
    Jason
    Feb 26 2008
    OK so I have a bad smell coming through the vents but it isn't only when its on ac but also when the heat is on
    I've done the following
    Cabin filter
    Lysol down where the cabin filter is
    Klima klean (twice)
    A HVAC cleaner from advance auto parts
    I let the car run with the ac on and checked 10 min later and there was liquid under the car so there isn't any clogs.
    If anyone has any ideas thatll help please let me know. Its disgusting and embarrassing with passengers
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Quote Originally Posted by Dirtyylicous View Post
    Cabin filter
    Klima klean (twice)
    Use Lysol or Ozium and spray into the outside air intake with the heat on high. The hot air will help kill the bacteria which is causing the smell. Make sure you roll down the windows and run it for about 20 min and then spray some more if there is still an odor. Do this until you have "fresh" air coming out the vents. BTW on the second dose spray and then put on the recirculation mode. This will circulate the Lysol back through the inner intake vents too.
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
    Feb 26 2008
    Obsidian, I did what you said with Lysol 3 different it days.
    It works while you do it, the heat or ac smells like and fresh but the next day or later on that day when I start my car it'll smell again.
    I tried hurting econ 5 min before I reach my destination and even tried blasting the heat to dry everything up but nothing seems to work because next time I start the car it will stink for the first couple min of driving
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Re: AC smells funny?
    So you sprayed both in the outside intake under the hood and into the blower? To spray into the blower u need to drop the glove box. I would try with some Ozium if you used Lysol first. I used Ozium and it worked for me without having to use Lysol. You can pick Ozium up at ur local Walgreens. Try that and see what happens.
    Feb 26 2008
    I'll give it a try tmrw, I sprayed under the hood but didn't spray in the glove box. I have sprayed into the vent with kilma klean tho. Thanks
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Keep the AC off. You want to run full heat when you are spraying it. Take out the cabin air filter and spray into the intake. After you have sprayed quite a bit in there turn on the recirculation button to cycle the interior air. This will close the butterflies where the cabin air filter is. Let that run on full heat for about 15-20 min and windows down. If you are still having the smell I would check your EVAP drain hose, that may be clogged and causing the smell. Good luck!
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    forgive me.....where is the cabin air filter to blow the lysol in to?
    "The important thing is not to stop questioning. -Albert Einstein"
    "Treat everyone like a million bucks; and always have a plan to kill them"
    2007 A4: APR, STaSIS/Alcon, Avant Garde, Hankook, Ohlins
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by aaron1085 View Post
    Cabin filter is:
    Passenger side, under the battery tray cover thing (if you have one)
    And then there is a plastic cover with two clips I believe. Pull up and out and the filter is there.
    Jul 19 2011
    Northern Minneapolis, MN
    Quote Originally Posted by Obsidian View Post
    Where is the drain tube? Mine might be clogged
    Cabin filter is:
    Mine doesnt have two clips but just sits held in place by the weather strip. And it is between the 1st and second firewall all the way on the pass side.
    Senior Member Three Rings typeslone's Avatar
    May 09 2011
    06 A4Q 2.0T, 91 GTI VR6 Drag car
    North Jersey
    Quote Originally Posted by Ramathorn View Post
    We call the special cleaning kit a mist service, mist is the name of the company that makes the tool. It works pretty good actually.
    I always recommend to everyone to change their cabin filter and wiper blades every 6 months. Always use the charcoal filter if its available, some of the older vw and audi's didn't have charcoal filters, it was just a plain filter.
    Jimrobbington, if you have a shop near you that sells BG products, you can see if they will sell you a can of frigi-fresh. It is a hvac deodorizer that BG makes, you spray it in the fresh air vent and run your system on full blast, then change the cabin filter. It smells pretty decent and does an ok job at cleaning the system for a while. If you have access to a dealer that will do the mist service for cheap, I recommend that though, it is much more effective. Any car we get in at the dealer for musty/moldy smell from the vents gets a mist cleaning service and a new pollen filter.
    Also always make sure your cowl is clean of debris, overtime that stuff has a tendency to smell. Once a crab apple somehow got stuck under the cowl covers right by the cabin filter housing, man did that thing smell after a week. Even with the full length cowl/battery covers it somehow made its way in.
    91 GTI VR6 - all motor madness 12.62@106mph and dropping.....
    06 A4Q 2.0T - Revo Stg2/APR HPFP/034 HFC/TT Downpipe/EuropaParts Exhaust/Eibach Springs/Bilstein Sport dampers/RS4 Rear Swaybar/Fluidampr/RS4 engine mounts
    10 WRX hatchback - Torqued performance Stg1/Perrin/Whiteline/Enkei BR7/The wifes daily is faster than mine!
    Caste Systems Performance
    Lugtronic
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Cabin filter
    Klima klean (twice)
    can you describe the smell? is it a bit sour? almost rotten?
    you can change the filters, and lysol until your blue in the face but if you have a dead mouse or family of mouses, that smell is not going to go away until you remove said mouses. (i know it;s mice btw)
    ask yourself if your car has been sitting for a week or so?
    given that you have lysol'd, klima kleaned, changed the filter, etc. AND the smell is still coming through with heat on, i am guessing you have a critter problem.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Feb 26 2008
    Damn, I never thought about that... Hmm
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    there are two different filters to choose from... paper and charcoal...
    Cabin Filter (Paper)
    Cabin Filter (Charcoal)
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Why you want to fix it? You're in a good mood while driving and if it becomes so funny that sometimes it makes you laugh, even better
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
