*Problem solved, it was the crank position sensor*
What's up guys,
On my way home from work today cruising at about 60, the engine shut down with no warning. Pulled over and attempted to start it, nothing doing. I had recently switched ecm's and thought maybe that was the issue so I changed the ecm back on the side of the road. Cranked again, no start. As I'm contemplating where to tow it to, I thought I'd give it another try. Started right up.
Get home about 10 minutes later and go to back into my spot. As I'm backing up, bam...dies again. about 10 minutes later, started back up again.
So I know it's not ecm related. I'm thinking either fuel pump or relay. How would you determine which one though? My pump has given me no issues, and is completely silent. And after 10 minutes it starts up again. I know the fuel pump module might be over heating and shutting down, but there's no symptoms to think the pump is straining. Any ideas?
Thanks,
Chris
BTW, no MIL or faults in the system
