Results 1 to 18 of 18
    Feb 25 2011
    Seacoast NH
    Question CLOSE FUEL TANK CAP! -wtf?
    I just got this warning message this afternoon (see pic below). I quickly pulled over, and my metal gas door was shut fine. I opened it, and clicked the gas cap a few extra times. I still had the warning message on my dash for probably 10 more miles, then it randomly went away. Wtf? Any ideas as to why I got this message?
    Senior Member Three Rings Boxmods360's Avatar
    Jan 14 2010
    refrigerator, tools, Audi
    Florida
    lol, I had the same thing happen to me.
    2008 A4 2.0T Quartz Grey - Vag-com - TSW Croft 19" 8.5F 9.5B - 10" Alpine Type R sub w/ PDX-M6 amp in a custom made fiberglass box - AUX mod - smoked reflectors - Plasti dip grill & window trim- 5000K Fogs - Red LED interior - Homemade Carbon Fiber trim - 640 mod - REVO ST1 - APR carbonio - OEM Xenon headlights w/ Phil's LED w/ 6000k Headlights
    My CF trim <-click-
    Veteran Member Three Rings grassrootz's Avatar
    Apr 01 2010
    Tampa, FL
    The person who filled you up prolly never clicked it and it was pulling in air not creating the vacuum it normally has once it equated it went away. Always listen for atleast 2-3 clicks.
    -GrassRootz
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    probably just a sensor bug. See if it comes back, if not I wouldn't worry too much about it.
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by grassrootz View Post
    I filled up my car myself, and I always click at least three times. In New Hampshire, most people fill up their cars with gasoline themselves. I know NJ has that law where you have to get "full-service," but just letting you know haha.
    Apr 01 2010
    Tampa, FL
    Quote Originally Posted by wildcat333 View Post
    Yea I noticed your sig when I posted. I actually hate to let them do it. I try to always do it myself(Learned in Md its simpler than waiting on 1 guy attending 5 cars). But maybe get a pressure check on the cap then. I know on my truck it happened and I knew I filled it properly and the changed everything just to realize the cap went bad.
    -GrassRootz
    Veteran Member Four Rings dumpedb5's Avatar
    Nov 22 2009
    B5 Imola Avant and a MK4.
    City Of Roses
    The seal on your gas cap could be leaking.
    SQUISHEDTWINKIE
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by dumpedb5 View Post
    x2 If it happens a "few" more times. If not, no worries. My light came on a few times so I ended up changing the cap.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Jun 06 2011
    Miami, FL
    Hey Guys, I've been having the same problem... I have already changed the actual gas cap, and cleared the message and $40 bucks later the message is still coming back.. Could it be a sensor?
    Veteran Member Three Rings saizero's Avatar
    Aug 11 2009
    Chicago
    You might need to replace your EVAP check Valve. do you have a hard time turning on your car after you fill-up the tank?
    -Simon
    Current AWE Boost Gauge : STaSIS catback : 034 HFC : ECS Snub Mount : Upgraded Piston DV : CTS Turbo Catch Can : ER FMIC : DTM Front/Rear Votex Side Skirts : Stasis/Ohlins SL Coilovers
    VAGCOM Owner
    AKA: vmSAi
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by vmSAi View Post
    -Simon
    I haven't had any similar issues since this one incident last week. I filled up my tank yesterday, and it started up normally with no issues. Maybe this was just a fluke.
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    Its a fluke....I had it happen about 5 laps into a track day session. Pulled off cap and put back on, no problems. Weird tho.
    "The important thing is not to stop questioning. -Albert Einstein"
    "Treat everyone like a million bucks; and always have a plan to kill them"
    2007 A4: APR, STaSIS/Alcon, Avant Garde, Hankook, Ohlins
    Established Member Two Rings AudiRay_722's Avatar
    Feb 28 2011
    Wisconsin
    I had the same thing. Then while I was driving, the message went away but a CEL came up simultaneously. Hopefully the CEL will go away after a few starts of the engine. If not then it's off to the dealer with my 2months of warranty left.
    2008 Audi A4 S-Line Ti. Pkg. FT
    APR Stage 1
    RS4 Grille
    Bilstein Sport shocks
    "A turbo: exhaust gasses go into the turbocharger and spin it; witchcraft happens and you go faster." -Clarkson
    Veteran Member Four Rings B7A4WD's Avatar
    Jan 27 2008
    B7 A4 2.0T Q S-Line
    New Port/ Fullerton
    My shit is doing this now.. anyone ever find out what the exact cause is?
    H&R SS CO, 034 MS REAR SWAY BAR, 034 MS TURBO INLET HOSE, 034 MS STREET DENSITY MOTOR MOUNTS, EUROCODE 3" TESTPIPE, APR CARBONIO INTAKE, APR STAGE 2, MAGNAFLOW CATBACK EXHAUST, BLACKHOUSED & CC MODDED HEADLIGHTS, STOP TECH STREET KIT BRAKES, DEBADGED, THULE ROOF RACK, 19X8.5 VMR 708S GUNMETAL
    Feb 28 2011
    Wisconsin
    Think it's the n80 valve. Dealer replaced mine years ago.
    Sent from my HTCONE using Tapatalk
    APR Stage 1
    RS4 Grille
    Senior Member Three Rings SwiftA4's Avatar
    Aug 20 2012
    Quote Originally Posted by AudiRay_722 View Post
    x2 ... N80 solved it for me as well
    2008 A4 S-Line | APR Stage 1 93 | Ibis White | 2.0T Quattro Tip | Koni FSD/Eibach | Debadged | R8 Coilpacks | BKR8EIX | OEM Roof Rack | VEI/Podi | 15% Side, 5% Rear | Rev. "D" DV | 034 Snub |
    Retrofits: S4 Power Folding Mirrors | Warning Triangle |
    Feb 25 2011
    Seacoast NH
    wow, a throwback to before I installed Sirius satellite radio!
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    caused by evap leak fault. replace n80 and clear fault, perform basic setting 71 with vag com.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
