Results 1 to 11 of 11
    Aug 31 2008
    South Carolina
    Fuel filter replacement
    Just wanted some insight from other members on the forum. How do you replace the fuel filter on a B8 Audi A4 2.0TFSI Quattro? I know the filter is in the fuel tank, but I dont know if the fuel tank has to be dropped, or if there is a service port somwhere in the trunk or underneath the back seat, or even somthing else.
    Mar 02 2007
    Fresno, CA
    Slightly off-topic, but while we're on the subject of fuel... does anyone know if the dealership's fuel injector cleaning service is actually worth it? I'm imagining it's just another scheme to get more money from customers.
    Sep 14 2006
    I definitely don't think the fuel injector service from the stealership is worth it. Also, if the B8 is anything like the B6, the fuel filter is underneath the passenger side rear of the car. Once your remove the plastic shield you can access it, however I do remember that the clips that hold the fuel lines in place were fragile and annoying to work with. How many miles are on your car? I heard a buzzing around 50k and replaced mine.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Aug 31 2008
    South Carolina
    Currently the car has about 73K miles. I already got underneath the car and removed the all the plastic, the fuel filter was nowhere to be found. So I called ECS tuning (thats who I got the fuel filter from) and they told me that the fuel filter is located in the fuel tank. ECS also called there parts supplier to confirm this, however they did not tell me where the service port was located for the fuel filter. Im just trying to determine if there is a service port or if the gas tank actually has to be dropped.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    I think you access it from the trunk. Remove the felt trunk bottom to expose the metal.
    Looks like there is a hatch there.
    -cW
    2023 X3 M40i Alpine White
    Sep 06 2010
    Germany
    Why do you think the filter needs replaced? I believe it is a non serviceable filter and is more like a screen right?
    2011 A4 Avant S-line
    2016 TT Roadster
    Mar 26 2012
    Charlotte, NC
    Did you ever find the fuel filter ?
    Mar 26 2012
    Charlotte, NC
    Someone sent me this but I can't put heads or tails on this. Is this in the Fuel Tank?
    May 07 2014
    I just replaced mine, it's located beneath the rear seat. I followed a DIY posted on this forum...that I can't seem to locate at the moment lol
    May 07 2014
    Thats the one, thanks!
