Results 1 to 13 of 13
    Senior Member Two Rings akim_hobo's Avatar
    Nov 25 2009
    bellevue WA
    sound deadening in trunk
    I'm contemplating whether to pull the trigger on getting my trunk lined up to soak up some of the exhaust 2k drone, and while I'm at it upgrade the sound with a 10" sub. Anybody do this already? I'm looking at prices and they seem to be extremely varied, what should I be expecting for this kind of mod, and will it even make a difference? (The sound deadening)
    TIA
    2011 S4 :: Prestige :: Stronic :: Meteor Grey :: Sports Diff. :: Carbon
    AWE res exhaust :: AWE Intake :: Alu Kreuz :: PSS10 :: USS
    Jul 07 2009
    Lebanon
    SOLD: 2010 A5
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Quote Originally Posted by akim_hobo View Post
    TIA
    You are still getting drone?
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    Looks like from that thread referenced above. People are putting insulation or Reflectix into the open area near the trunk light bulb and in the open areas of bare metal (eg spare tire well). They seem to be getting improved Bass from stock system and a lowering of the exhaust drone.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Senior Member Two Rings Daniel360's Avatar
    Apr 12 2011
    Miami
    i am doing this but i am going with an 8' jl w7 sub.
    2012 Boss 302 Performance White
    2011 Ibis B8 S4
    2008 F350 703hp Diesel
    2009 Hayabusa Custom
    2004 GsxR1000 Custom
    Apr 12 2011
    Miami
    i will be using dynamat though not that ^^^ stuff
    2011 Ibis B8 S4
    Established Member Two Rings xaser240's Avatar
    Apr 05 2009
    You should consider adding some type of closed cell foam product on top of the sound deadening you choose, it would probably combat the drone more effectively than just deadening alone I would think
    2011 S4 :: Ibis :: 6mt ::Sport Diff ::18's :: black/magma silk nappa :: carbon inlays :: nav
    MODS :: 35% Huper Optik :: Clear Bra :: Alu Kreuz :: H&R Coils :: Stoptech ST60 355mm :: TSW Bathurst 20x10 et40 :: 255/30 Hankook V12 evo :: AWE Exhaust :: JHM SS :: Roc Euro Intake :: DTM Carbon Lip :: ECS HK Spoiler
    Apr 05 2009
    http://secondskinaudio.com/noise-bar...liner.php#tab2
    I think this type of product is what your looking for. It should do a much better job at reducing drone/ exhaust noise than a sound deadening product will.
    Nov 25 2009
    bellevue WA
    Quote Originally Posted by NWS4Guy View Post
    Yeah, but I love the sound when I'm not in the 1.8-2.5k zone :/ What's a guy to do?
    Nov 25 2009
    bellevue WA
    Quote Originally Posted by Wah View Post
    Thanks! I'm not sure I want to go the duct tape route but it's nice to know that it helps with the drone :)
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    if you lift up your spare tire and tool kit you will see oem sound dampening on the sheet metal , audi knew there were vibrations from the stock exhaust. When adding an aftermarket free flowing exhaust you will run into more vibrations, i got some foam tape to deal with problem, i will probably add a layer of dynmat under the carboard trunk latch to kill the vibration going into the cabin.
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    Sep 29 2009
    I went APR
    LOL
    Nov 04 2010
    I went Miltek lol
    500AWHP/500AWTQ
    @Driven_Not_Hidden
