Page 6 of 7 FirstFirst ... 4567 LastLast
Results 201 to 240 of 249
  1. #201
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by Believer View Post
    Ok great, shouldn't be any issues then. Thanks for the write-up!
    Not a problem, I know its kind of confusing where I switched what harness it was in the thread, sucks I cant change the title. Just glad to hear people are still using the write up. My swap is still going strong.
    1998.5 A4 1.8TQM My Build
  2. #202
    Oct 02 2006
    Wadsworth,OH
    Thanks for the clarification Jason. I'm completely cool with splicing and soldering I guess I just wanted to be able to follow along with xdewaynex's write up but use the Jetta Harness instead of the ATW harness.
    No problem!
    Since your vehicle doesn't have an ICM you can skip the whole delete part. So all you should need to do is rewire the plug into the rest of the harness.
    Jason
  3. #203
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    No problem!
    Jason
    I'm in a 99.5, AEB vehicle so unfortunately mine does have the dreaded ICM..
  4. #204
    Oct 02 2006
    Wadsworth,OH
    My mistake, I confused you with U_know_me as he mentioned he has a 00 A4. I owe ya a soda!
    Jason
  5. #205
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    I know, I know... Let the dead thread bump jokes ensue. I just figured I'd update here rather than start yet another thread on the matter. (And at least you know I searched.)
    I am asking because the links I need in this thread are all dead ends at this point. Just the clarify, I bought coils p/n 06E905115E (red top), and harness p/n 1J0971658L. That is what I need for this pin out, correct? Car is 1999 AEB.
    Harness should be in tomorrow. Coils came today.
  6. #206
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Running MKV FSI : 07K-905-715F With (AWM motor) GTRS around 21 psi ( NGK BKR7EIX-11 gaped .43) Runs great!(1,000 miles on them) I got them on amazon 17 bucks, if you have prime free ship just have to find the prime seller.
    SOLD the GOINHAM A4 ---> GT2860 Project
  7. #207
    Veteran Member Three Rings Koldham's Avatar
    Aug 12 2012
    Walnut Grove, Georgia
    Quote Originally Posted by 034Motorsport View Post
    We carry those 4-wire plugs for for $11/each with 4 new pins.
    We can also supply them "flying lead" style with wires already crimped for an additional $4.
    Please feel free to PM or email me.
    whats the part number for those plastic plugs. its in one of these threads around here but i cant find it again.
    1997 A4 1.8QTM AEB Pearl DD
    Deer Strikes:0 HELLASTOCK...ish WTB: pearl white body panels.
    1973 Ford Maverick Project Car(first car)
    200 I6 -> 302 V8, 3spd column shift, 8.8 with traklock. Bright Ass Orange.
  8. #208
    Sep 10 2013
    Here is my final result.
    I am stoked by how it turned out. Runs so much better. And looks badass.
  9. #209
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
  10. #210
    Dec 25 2014
    2001.5 S4 (6MT)
    Toronto, Ontario, Canada
    Not meaning to nerco here, but I've read all 6 pages and also a few other threads and am still a little confused..
    I would like to upgrade to the 2.0T coils from where I am now with just the stock 1.8T coils. I have a 1998.5 A4 1.8TQS so a AEB engine and harness.
    From what I can make out, I have a few options:
    1) I get a Jetta 1.8T repair harness with the 4-wire ignition coils upgrade and just replace my old/damaged coil pack harness and call it a day. (which is found here: http://store.034motorsport.com/harne...wire-coil.html)
    2) Upgrade to the ATW harness and coils and then upgrade to the 2.0T coils?
    3) Upgrade directly to the 2.0T coils/ related components with this kit?...: http://store.034motorsport.com/coil-...fsi-coils.html
    I'm open to making my own sort of harness, I'm just sort of lost with all the options and would really just like a sort of straight-forward list of everything I'd need to do either option 1, 2, 3 or whatever you all throw at me. I'd like to approach this the simplest way, but if there's a much cheaper way, I wouldn't mind hearing it.
    Much appreciated!!
  11. #211
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I'm AWM so they are drop in for me and I've got 2.0 coils. From what I understand. Go with the 3rd option. Then you just need the coils and done.
  12. #212
    Jun 30 2008
    Erie, Pennsylvania
    Options 1 and 2 are the same thing. You can get a new harness or a used one. Your choice. Then you can use 1.8t coils or 2.0T coils. Also your choice. For 2.0T coils you can get adapters for fitment or not. Again, your choice.
    The third option is to just adapt your current harness (in place, without removing it) so you can run 4-wire coils (1.8T or 2.0T). This is fine if your harness is not compromised (aka: roasted). But if you want to renew your harness at the sane time, then option 1 is ideal.
  13. #213
    Jun 30 2008
    Erie, Pennsylvania
    2.0T coils are taller (ostensibly requiring adapters), cheaper, and provide a higher output voltage potential. This makes them able to deal with larger spark plug gaps, should one desire. They also seem to provide improved reliability.
    They are also what all the "Cool Kids" are running now. So, if you want to hang with us...<sunglasses>...you should probably get some. (j/k...but srsly, everyone's doing it).
  14. #214
    Oct 30 2009
    Miami, FL
    Only thing I don't like about 2.0t coils is the front one is too tall to fit under the stock engine cover. Since I like covers I had to trim mine quite a bit and it looks kinda weird.
    2018 S5 Coupe - stock for now
  15. #215
    Jun 30 2008
    Erie, Pennsylvania
    You can space up the cover mounts a tad with a washer or 2...if you're into that sort of thing. ;)
  16. #216
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by Mad Cow View Post
    I agree.
    Instead I went with a "coil cover" that 034 Motorsport sells. It still looks nice but instead of 3 quick-release fasteners it takes 4x M5 bolts to remove.
    2001 Corvette (C5) Z06
  17. #217
    Oct 30 2009
    Miami, FL
    But then there will be a gap between it and the t-belt cover, I could try it though in case it ends up looking less hacky than what I did.
    The 034 cover is pretty, but I don't feel like spending $60 on a (very nicely) bent and cut sheet of steel.
  18. #218
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by hippierapinc View Post
    Much appreciated!!
    Or you can save a bunch of money and buy a straight harness http://www.europaparts.com/coil-pack...j0971658l.html which will require either a little soldering or crimping.
    I thought the ECS cover plate was a nice addition when it was $60, now its $100
    So you can do this for $63(harness) +$80(coils) plus adapter plates.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
  19. #219
    Dec 25 2014
    2001.5 S4 (6MT)
    Noob question...looking at option 3 via the 034motorsport link, is the appropriate adapters for proper fitment included?
    Additionally, if I were to do the third option, and a fair bit down the road decide/ am forced to replace my harness, would it be possible to salvage an majority of the parts from the kit and simply 're-adapt' the replacing harness?? I imagine just going with option 1 and advancing from there would probably be the cheapest/ easier route, no? (Also thank you for your prompt response! )
    Last edited by hippierapinc; 08-18-2015 at 12:50 PM. Reason: Trying to be more clear about what I'm asking.
  20. #220
    Jun 30 2008
    Erie, Pennsylvania
    I think option 3 is a silly waste of money. If you want to do it right and yet not spend more than necessary, I would suggest:
    This harness:
    These coils:
    http://genuineaudiparts.com/parts/in...&siteid=214407
    These adapters:
    Check out said adapters here. http://www.ecstuning.com/Search/Site...658L/ES283074/
    Total with shipping to my house? $172.17 USD
    Total if I bought from ECS? $189.52 USD
    Way less than the 034 kit at $266.57 shipped. And you don't have to use your old crusty harness, or have a pile of adapters hanging out in your engine bay. Yes you will have to crimp a couple wires. It will be devastatingly difficult. (not really)
  21. #221
    Jun 30 2008
    Erie, Pennsylvania
    There are only 4 wires per coil. 2 of them are grounds and 1 is power. These are common between all the coils, just splice them up.
    So the only potentially tricky bit is the single trigger wire for each coil. 4 wires total that are specific, and there are plenty of charts and such to look up what goes where. Or you can just ask us "Hey guys I have these 4 wires on my car, which one goes to what cylinder?"
  22. #222
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Here is the DIY I used: http://www.audizine.com/forum/showth...WP-upgrade-DIY
    I have r8 coil packs and I think the AWP harness. Also had to do a ICM delete.
  23. #223
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    Reviving an old thread. I forgot what's the best plugs and gap to run for GT28RS with 2.0 coil conversion?
    Mind you car is running slight rich.
    Thank you very much in advance.
    IG:@steadysupreme
    Pics&Detail
  24. #224
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Im still running the NGK BKR7E plugs with about a .040 gap. 22psi on a Frankenturbo 440cc setup.
  25. #225
    Quote Originally Posted by xdewaynex View Post
    Perfect just ordered. Yah i remember vivdly i was running 0.040 too, thanks for the double assurance.
    IG:@steadysupreme
    Pics&Detail
  26. #226
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by $teady$upreme View Post
    No problem. .040 seemed like a good number to go with and Ive never had a problem in the last few years since I done the 2.0 coils. Ive been wanting to change the dwell time for the coils, but I honestly dont know what to switch it to.
  27. #227
    Jun 11 2014
    Atlanta
    This harness:
    These coils:
    These adapters:
    Would this harness not work?
    https://www.ecstuning.com/Audi-B5_A4...ion/ES3082311/
    ECS also has a nice write up on how to connect it here.
    http://bd8ba3c866c8cbc330ab-7b26c6f3...llation_r3.pdf
    I also wonder if you could use that wiring diagram/setup to simply change the connectors appose to the whole harness.. assuming the stock harness was in decent shape.. if you wanted to be really cheap
  28. #228
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by Rmartin View Post
    Yes that harness now appears to be THE BEST option assuming its quality is good. It wasn't available until a month or two ago (Walky's post was 8 months ago).
    Chances are the stock harness & connectors aren't in the best shape. i.e. cracking wire insulation, broken coil pack plugs.
  29. #229
    Dec 23 2009
    Boulder, CO
    Its crazy how the price has jumped on the repair harness at some vendors. $55 at Jim Ellis http://www.jimellisaudiparts.com/pro...J0971658L.html Seems like its out of stock most other places, maybe discontinued.
  30. #230
    Jun 11 2014
    Atlanta
    Yup, seems like a lot of items are a little over priced if you ask me. Anyway, the harness from ECS has free shipping and you get the supper cool crimping tool that goes with it!
  31. #231
    Feb 10 2009
    '01 A4, '87 Chevy 1 Ton
    Knoxville, TN
    This harness:
    These coils:
    These adapters:
    Slightly confused. I've read a number of threads so a lot of the info has been mashed up together in my head. I have an '01 that just had a coil pack go out. I had a spare good one from when I last replaced all 4 so I'm OK for now but since they have around 50k+ miles I know I'm on borrowed time.
    I can get these:
    http://smile.amazon.com/dp/B00KWGK0W...=IIHTPG3XBHRYT
    coil pack # 06H 905 115 B
    and gap BKR7E plugs to some where in the mid 30's and be good to go?
    Car stats are in sig. Mainly interested in running slightly larger gap for smoother idle I know there is no real power gains to be had. My factory harness is still fine so if I had to buy a new harness or wire in new clips i'll just replace my packs with what ever OEM packs I had before
    1988 Shelby Dodge CSX-T, 2.5L 4cyl, T04E 40 trim w/ .63 A/R, Stg2 Ported 8v Head (Sold) it was a torque monster!!! :(
    2001 A4 1.8T turbo back 2.5in exhaust, SB clutch w/ 17lbs SMFW, Forge splitter, Revo stage 1 flash, 4:1 Center diff, ST Coilovers, 034 RSB, Forge FMIC.
  32. #232
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by juxsa View Post
    You have an 01. FSI coils are plug and play for you. No need to get a different harness
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
  33. #233
    Junior Member Two Rings
    Feb 05 2016
    Barry/IL/USA
    I put those coils on my ATW and it runs great now...no misfires but I like those plate thingys...ECS has a solution too but it cost$$$$$
  34. #234
    Feb 10 2009
    Knoxville, TN
    Awesome thanks guys just put in my order
  35. #235
    Feb 10 2009
    Knoxville, TN
    Well I gapped the plugs to. 040 and idle is smoother than ever. There has always been a slight hesitation around 26-2700rpms and that's gone too. Great upgrade to do when it's time to replace coil packs
  36. #236
    Veteran Member Three Rings G.AUDI's Avatar
    Dec 07 2008
    MK6 GTI
    SGV, CA
    Quote Originally Posted by MetalMan View Post
    Bumping this thread to ask - The ECS kit has been out for some time now and was wondering if anyone could compare it to the kit that 034 sells. https://store.034motorsport.com/harn...wire-coil.html
    The ECS is definitely more price friendly but curious on the quality, opinions, etc. Are these kits better in quality that the oem repair kit Avant Nate listed in post # 231?
  37. #237
    Nov 03 2014
    Missouri, US
    They are both the same in concept but the 034 uses a different connector and plug to go to the body. I think it was deutsch. the ECS kit has a cheaper connector there but it works fine. Also, the ECS kit supplies a worthless wire tool with the kit, I would suggest getting the proper "W" crimp tool and an automatic stripper to make this and other projects in your life go more smoothly
  38. #238
    Apr 22 2014
    Aptos, CA
    I've got the ECS inbetween plate and I think it looks sweet and more importantly fills that gap well.
    1999 A4 FWD AEB 1.8T ~ Atlas
  39. #239
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Has anyone used the coils by "OriginalEquipment" that ECS sells, or your better of buying oem 2.0T coils?
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
  40. #240
    Dec 05 2007
    Not worth cheaping out on such an important item. If one craps out, you will be riding on one less cylinder. 2 crap out, and motor may not have enough in it to even keep running.
