Page 1 of 7 123 ... LastLast
Results 1 to 40 of 249
    Jun 30 2008
    Erie, Pennsylvania
    Using 2.0T coil packs on the 1.8T
    This has been quite a popular topic on the B6 A4 forums here and with the VW 1.8T guys. Just wanted to make sure the B5'ers weren't left out.
    Basically, it has been discovered that using coil packs from the "2.0T FSI" and "2.0 TFSI" can give an advantage over the 1.8T coils (Rev R and Rev D, etc). Because of the requirement for the 2.0T to do a leaner burn, the spark must be hotter. By using these more capable coil packs, 1.8T drivers have been able to increase the gap on their spark plugs to .040" or more. This gives a hotter spark with many advantages.
    The disadvantage is that the 2.0T coils are indeed longer than the 1.8T counterparts meaning that they don't seal off against the valve cover, and aren't held down very well.
    Just recently, coil pack adapters have been designed and are in production for the AWM and AMB engines. Even more recently, adapters have been designed for the AEB and ATW engine codes. These adapters bolt to the valve cover and allow the longer coil packs to seat properly.
    There is currently "intro pricing" available on the AEB/ATW adapters (Version 1.3's), so I wanted to make sure you guys were aware.
    Please feel free to discuss this here, but for the main thread for info, ordering, and inquiry on these adapters, please go here:
    http://www.audizine.com/forum/showth...-INTRO-PRICING
    And the main thread which explains this all:
    http://www.audizine.com/forum/showth...FSI-coil-packs
    Myself, I've ordered one set of the V1.2 adapters for my AWM car, and one set of the V1.3's for my brother's ATW car. I'll be running the red 06E-109-115E coil packs. My brother will probably be using the Cali emissions version.
    Jun 30 2008
    Erie, Pennsylvania
    Adding some pics for those who don't like to read:
    Apr 25 2011
    Auckland, New Zealand
    Hi, Very interested in this topic. I have been through the and some of the post on the other threads.
    I have a question. How would one fit these coils on an old AEB engine set up. I have noticed that all the coils are 4 pin but mine is a 3 pin. Is there an easy conversion to using the different plugs (ie a 4 pin plug etc) or is there an alternative way??
    1997 A4 1.8T Quattro (MTM)
    Full stage 3 MTM kit installed from new. Sold new in its current form from dealership in New Zealand. About 30 were bought into the country. Most have disappeared!!
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    good info walky. I'm saving this thread
    Life is too short to drive ugly cars.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Do like. So what kind of gains can we see?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 05 2007
    I'm about to pick these up myself.
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Quote Originally Posted by biketsai View Post
    Likewise
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    I work for VW and this looks like a sweet idea
    Enjoy yo self
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    SEARCH!
    LOL, Winston.Podi did a thread and gained 15whp/15ft-lb on a b6 gt2871 on 18psi.
    I'll be either running these or Aem pencil coils
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Feb 26 2010
    NOVA
    Quote Originally Posted by viceprp View Post
    SEARCH!
    this is a cheap upgrade, 80 bucks plus those adapters.....good thing i did the coilpack upgrade on my AEB...i need every horse i can wrangle.
    Jun 04 2007
    Austin/DFW, TX
    SEARCH!
    15WHP? Thats all I need to hear.
    My 5-Speed Swap DIY
    - B6 USP
    Apr 25 2011
    Quote Originally Posted by guy022077 View Post
    Can you please provide a link on how to upgrade the AEB coilpack harness?
    Thanks in advance!
    Jul 27 2010
    Queensland, Australia
    Interested. :)
    99.5 A4 1.8TQ MT
    1.9L built/blueprinted motor, JE assymmetrical pistons, IE Tuscan Rods-JNL racing custom ported head, IE CVA2 camshafts-BW EFR7064 .92 IWG-Full-race T4 manifold-1150cc injectors +++++++++
    Instagram : e85.A4
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Just skimming through on the original thread in the B6 area, it seems like a great idea. I guess its time to start saving, swap over my AEB coil wiring to the newer style, get the adapters, coils and hold downs for the push down coils and ride out. Plus if someone gained 15whp just from this, thats awesome.
    1998.5 A4 1.8TQM My Build
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Ordering a set of these today. It'll be GREAT to finally address my random misfires under WOT.......Really hoping these will have a good effect on my tri-electrode FR5DTC plugs
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jun 30 2008
    Erie, Pennsylvania
    The major advantage here is the ability to run a larger plug gap. If you run them with the same plug gap (.028 for most of us), then you won't see much benefit unless your coils were already bad. Of course these 2.0T coils may prove to be longer life than the 1.8T ones, especially if the gap is kept small (less stress on a stronger coil). But they are cheap anyway, so gap it up!
    Sep 16 2006
    '98 528i
    I think my coils are somewhat weak, so I was already planning on buying a new set. Once I get these installed, I may start hunting down a new plug for my setup......I can't believe the reported gains of these. Its amazing, considering the cost
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    SEARCH!
    Link?
    If I'm thinking what it is, that was Okada Project coils vs the Rev R.
    It made more hp because the Rs had a miss up top IIRC too?
    Other than that I do not believe ANYONE has tangible hard data yet. But very good obvious feedback. Smoothness in all driving conditions is enough for me. Even if power/tq was the same I'd still do this upgrade. Drivability aspect is often too much overlooked.
    Just clearing up before anyone gets disappointed...
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
    Sep 16 2006
    '98 528i
    Very good point! With this upgrade, driveability is far more important to me, as I've already got more than enough power ;)
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by JumboBlack1.8 View Post
    I wish that were the case for the rest of us ;)
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings Papa_Dios's Avatar
    Jul 01 2010
    fl
    How do the 2.0 coils differ from the 1.8t? I have an 01.5 and had mine changed under recall not to long ago. I'm interested but not if they are basically the same revised versions.
    Finally off jackstands!!!!!!!!!!!!!!!!!!!!
    My 5 speed swap thread
    Parts I have for sale!!!
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by Papa_Dios View Post
    If you want to wait it out, I should have some of that data for you. I just got a set of the "115 D" coils yesterday at the dealership under the recall. So I'll have fresh "D" coils to compare against the 2.0T coils at high plug gap settings. I'll be buying the red coils (which are actually the V6 FSI coils as used in the C6 A6, R8, etc), but I think my brother will probably get the black 2.0T california emissions "lean burn" coils. So I should have a bunch to compare.
    I've been running on some old "L" coil packs lately. I had some "R's", but I didn't want the dealer to throw away the ones I paid for. (They definitely won't give your old coils back after the recall, even for spares). So I dug out some "L" coils that barely worked. Car was running like poop, but runs so much better now with the fresh "D's". I can't wait to see the difference with the 2.0T stuff and a higher gap.
    Mar 04 2009
    Memphis, TN
    Subscribed - I'm thinking of going BT soon. This would be a great addition.
    The angle of the dangle is directly proportional to the heat of the meat!
    Feb 26 2010
    NOVA
    Quote Originally Posted by nzant008 View Post
    Thanks in advance!
    http://www.audigeeks.com/forums/index.php?topic=3181.0
    http://www.ecstuning.com/Flyer-Sprin...ance/ES477951/
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    idk. im kind of skeptical.
    i am running 034 IIc standalone, will i see gains simply by throwing these on and opening up my gap? will i have to re tune anything? how will i know what to gap it at?
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Jun 30 2008
    Erie, Pennsylvania
    The largest gap that your coil will support. I'm planning on starting at .040, then .045, etc. The larger the gap, the hotter the spark and (hopefully) a more complete burn. That leads to more horsepower, less emissions, and greater mpg. However, the larger you open the gap, the harder it works the coil as it is demanding more voltage before it jumps. This can shorten the life of the coil somewhat.
    Dec 05 2007
    Hey Walky, I have some spare L (not weak) and R version ignition coils if you want them for testing. I have 3 L and 2R, but want to keep a spare even though I may not need it (running the Hitachi E, and will keep one of the R versions if you want these. just better to have one than not to). Just pay shipping and they are yours. I should be able to flat rate ship them, so it should cost $5 and some change to get them to you.
    Jun 30 2008
    Erie, Pennsylvania
    I think I'm all set Seerlah. I've got a good set of R's so I can compare. I don't think it's worth it to compare the L's. I don't think you can even buy those anymore.
    Thanks for the offer, and I'll let you know if something changes.
    Oct 21 2005
    y
    Quote Originally Posted by Issam@INA
    FAQ:
    1. Why would I convert my 1.8T to use 2.0T coils?
    Allthough when we dissected the 2.0T Coil , internally it was the same as a 1.8T unit.
    Read the FAQ here:
    I don't get how a 2.0 unit can run hotter than the 1.8 if they're internally the same. Maybe the difference in length?
    Oct 02 2006
    Wadsworth,OH
    For the AEB guys to take advantage of this what mods do they need to do to the wiring harness to run the newer coils? Is it the same as the ICM delete?
    Jason
    Jun 30 2008
    Erie, Pennsylvania
    Yes, delete of the ICM, including the new coil pack harness/plugs. Using OEM replacement harness for the Jetta 1.8T would be the cheapest route. Or a used harness, but that's not advisable due to the way those harnesses get heat treated.
    Veteran Member Three Rings CamrideA4's Avatar
    Jan 05 2011
    Raleigh, NC
    I just put mine in. I can feel a pretty big difference between the MK VI coils and my ~2 year old R's. I've got my BKR7's gapped at .035 right now, I may push them out a bit tomorrow. I'll get logs tomorrow as well.
    BTW, can anyone tell me if I use the same procedure in this TSB to replace the wiring harness in my AWM engine: http://www.squarewave.com/army/andre...b.97-04-02.pdf It doesn't specify that engine code but I've read other threads that said that is the procedure to use. Just wanted to be sure.
    2001.5 A4 1.8TQ Tiptronic - FrankenTurbo F4 - 440cc Green Giants - TT225 MAF - Borla exhaust - ST Coilovers - Malone Tuning - Garrett FMIC
    Apr 25 2011
    Thank you.
    The DIY thread will need some digesting!!!
    Very excited now!!
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    humm i may upgrade to these in the near future!
    Thanks for posting man!
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Senior Member Two Rings malanca's Avatar
    Sep 20 2009
    A4 B5 1.8T (AEB) Quattro Avant | Opel A Corsa C20XE
    The Netherlands
    Great info! Thanks for posting, this is really a very good upgrade.
    And the best part: this is cheaper than replacing that f@ck'n ICM in case of failure!
    K03-0073 | APR 2.5" exhaust | Clutchmasters FX400 240mm | Milltek 200cpi | APR intake-hose | Autobahn88 FMIC | 240 chp | Eibach Pro-Street-S coilover | TAROX brakes
    Mar 01 2008
    '12 1M
    Sydney, AU
    Quote Originally Posted by Jason@ECSTuning View Post
    Jason
    By using the MK4/transverse repair harness you guys sell :)
    Just don't use one of the connections which only applies to transverse cars on that harness, and you're set.
    12 1M
    3090lbs
    Jun 30 2008
    Erie, Pennsylvania
    You could even get away with using this harness, from the newer 2.5 engine. Of course you'll need to remove the plug for cylinder 5! But the connectors are all there, for very cheap:
    Oct 02 2006
    Wadsworth,OH
    Keith not sure if this matters but I noticed it mentions this harness is for auto transmissions only. So be advised there may be complications other than just removing the 5th cylinder plug.
    Jason
    Jun 30 2008
    Erie, Pennsylvania
    Jason
    Certainly, you would be trashing most of that harness so it doesn't matter at all. You would just be "harvesting" the coil pack section of the harness: 4 coil connectors and the wires for them. Pretty sure that I'm going to do this before I put in the 2.0T coils. Definitely not plug-and-play, but neither is the Jetta 1.8T repair harness.
    Oct 02 2006
    Wadsworth,OH
    OK, I just didn't want people to get the wrong idea that all that would need to be done is remove the 5th cylinder wire.
    With how inexpensive these harnesses are I just might have to pick one of these up myself!
    Jason
